dtarin
Everything posted by dtarin
  1. To add to this suggestion on the same feature, it would be helpful to edit the perimeter of the extruded poly in the shade scene and not in the separate menu. Ground images are brought into the shade scene and the extruded polygon is used for obstructions. When the layout changes, the polygons have to be redrawn.
  2. Hello, It would be helpful if PVsyst were to modify the data which are imported from an NREL TMY file to included relative humidity.
  3. Hello, I have a question on PF implementation and thought I would keep it in this post. I have a Power Electronics central inverter which requires a 0.97 lagging PF. In PVsyst, do I select "limit in active power", or "limit in apparent power" on the "Grid Power Limitation" tab? Inverter Pnom is defined as apparent power.
  4. I dont believe it is contradictory. Simply deleting the file does not change the already existing SIT data in the PRJ/VCi. The SIT data is stored in the variant and project file (you can see this in text editor) . If the project is updated with new site data and the simulation variant is saved, the variant/project will update with the new values. You can delete the SIT file and still run because there is still the site data in the PRJ/VCi file. I just tested changing the site file, and checking in text editor the PRJ and VCi files. The update to contain the new data. edit: I see the error I wrote; in a way it is backing up the SIT file, so yes that was incorrect. Edited for correction. However MET files need to transfer with projects.
  5. NSRDB ground station data is a bit old, and varies in uncertainty (Class I-III, with III having highest uncertainty). Class II-III are generally not used due to the uncertainty and quality of data. However the other issue with this source is the proximity of these stations to your site and how representative it might or might not be. PSMv3 compared to some commercially available satellite data providers (for TMY data) has been quite high in GHI in my experience (3-6%). You are able to select your location however, which is a benefit compared to NSRDB. Perhaps look at both and consider the result might be somewhere in between the two (NSRDB is often lower GHI compared to PSMv3 and other sources).
  6. The PRJ does not backup MET. If a project is transmitted without the MET file, you will not be able to run the project with the same meteo source. Also, it stated that the variant stores SIT data (not MET data), and not the PRJ file. But when viewing a PRJ and SIT file, both contain SIT information. If a SIT or MET are updated, and the PRJ/SIT are saved, the next simulation will run with the updated values. This is easy to check. Pick a location for your site next to a steep hill or mountain and run with a site file on the low ground and high ground. Your elevation will update in the report, and also if the coordinates change more than two decimal places, they will update also. Another check is to use the PVGIS horizon feature with two different SIT files. This function pulls coordinates from those listed in the SIT file.
  7. P = I*V, so 91,000 W/400 Vac = 227.5 A
  8. That article is quite old. Perez is the default transposition model. Using measured diffuse irradiance will result in higher transposition accuracy for GlobInc.
  9. Defining a wall will still cause beam loss as a solid object. The poles holding up the net could be modeled. You can account for shading of netting by adding more support poles as thin objects.
  10. Each variant will save it's shade scene within itself. Exporting the shade scene is more of a backup method in case the variant is compromised, you wish to transmit outside, or use in other variants, etc.
  11. It does not. Different manufacturers will have different tracker designs, and PVsyst would not know which value to use. The distance PVsyst considers is only from the module. The axis refers to the axis of rotation (X location on the module); the Y component (height) is defined by user from the module. Your input into this field should take into account the tracker design. Have a look at the bifacial input settings page to see this. Image attached for reference.
  12. Hello, Multiple trackers on the market have a significant gap in the middle for 2P bifacial tracker systems to limit shading on the rear side. It would be nice if PVsyst had an option to define a center gap distance, separately from the module X & Y spacing options we have. Currently, if we set Modules X spacing in the shade scene, it adds that distance divided by two to the left and right side of each module. This causes the table width to be larger than what is designed, and extends past the edge of the modules.
  13. Hello, It would be helpful if object positions were to the third decimal place. When placing an object at a specific coordinate, there is only the first decimal available. Measurement goes to the third decimal, so too should object position. Thanks.
  14. Click Report > Settings > Printed pages and units > Nb Decimals for %
  15. You can use zones. Once modules or tables are populated you can edit by removing specific modules/tables, change baseline slope, etc.
  16. Not sure why that may be. Clear existing horizon, click Read / Import. Then Select PVGIS from left menu. Click the line "PVGIS horizon from WEB. Click import from PVGIS WEB. I just tried and it worked for me. Double check that your .SIT file has proper coordinates.
  17. Take your inverter output from PVsyst, apply your losses from there in order to the POI
  18. (P_actual/P_rated -1)*100 Positive result indicates gain, and is entered as a negative in PVsyst
  19. Try emailing support for faster response.
  20. A little late responding here. 1. Update to 6.8.3, PVGIS is working in that version. Or visit that link, get the horizon profile in txt format, convert to PVsyst readable format, and then import as PVsyst internal file. 2. It is not automatically included in the meteo data.
  21. Have you found a solution for this? If you run a simulation, you can get the meteo data from the 8760 output.
  22. My guess is that it has to do with equipment safety and protecting the inverters. A low pnom ratio might not function the most efficiently, but I dont think it's going to break the inverter, whereas too high of a pnom ratio can. Most inverter manufacturers only list max ratios (when they do list them) and not min ratios.
  23. This is likely due to severe terrain changes in slope. There are a couple things. Keep increasing table spacing until it goes away Manually move each table off of the adjacent one where there is overlap, then reset the table height according to terrain. Do a check under tools to move to the next error. Once the validity check returns no results, you are finished. Ignore table interpenetrations in tools (I never do this personally)
