dtarin
Everything posted by dtarin
  1. Hi Amy, From the help section, it recommends shading objects should be considered as "far" if they are a distance away from the array which is equal to 10x the size of the array. How this is determined is not known to me. Personally, for urban areas, I have modeled the buildings in the shade scene as near shading objects. It would be interesting to see the comparison between Suneye data converted to a far horizon profile versus the near shading method.
  2. I dont see how it is possible, since there is only one entry to define a partition dimension. Perhaps under module layout? But when working with large plants that option is not possible.
  3. MEF File attached NREL PSMv3.zip
  4. If you are at -59 minutes, add 1 hour to the time shift in the MEF file and re-run. Are you downloading in half hour intervals on the NREL side? This should be unchecked. I just downloaded a NY site (albany) and with a timeshift of 5 hours, the result is 0. See images.
  5. The result of the time shift is revealed after the conversion has happened. After complete, a box will come up asking for you to inspect the data, click yes, and select "check data quality" tab to see how far off you are, and if adjustment is needed. If your glob Hor is undefined, it might mean that depending on the variables you imported from NREL, it may not be matching up with the MEF file I provided. You will need to update the MEF to point to the correct columns. When I download PSMv3, I only download the variables I need for PVsyst (GlobHor, DiffHor, Tamb, Wspd) + DNI. When I download a UTC-5 site, and I check "convert to local time" when download NREL PSM, a time shift of 5 hours generally works. If you did not check convert UTC to local time, you may need to do something different. Since I haven't done it with that unchecked, I cant provide any help there. https://imgur.com/a/1mOXdl6
  6. I had in total three ground images and one ground object in the shade scene. I removed what was not being used (two images and the ground object), and the error went away.
  7. Hello, When I print reports in 6.75 I receive the following error. Any help is appreciated. Thanks.
  8. Hello, It would be help if trees or other solid objects had a parameter which defined their opacity. Often we have trees which are not very dense but whose branches span a wide area in a complex way. Defining a tree object which covers the area, but has <100% opacity could help capture the fact that some light passes through the branches. If this were implemented, you could also feature seasonal opacity factors, where in winter time the opacity is lower, and in summer it is higher.
  9. I recorded a video successfully in 6.7.3, large resolution, 3 sec. duration. Running windows 7. It may be an issue with your machine.
  10. This value has been updated to a default if 5% (as of v 6.7.4 I think), as it was believed to have been overestimated @ 10%. I dont have any info on the shading loss factor, so can't help you there.
  11. It is stated in the patch notes for 6.7.5 that this was corrected.
  12. Hello, We sometimes encounter stringing in the field which is asymmetric, and would like to know, would it be possible and useful to be able to model partition zones as such? Image attached for reference.
  13. Hello Nitin, I do not believe bifacial simulation for use with 3D scenes is yet available, and must use unlimited sheds at the moment. 1) Yes. 2) No See: http://forum.pvsyst.com/viewtopic.php?f=24&t=3544&p=8825&hilit=bifacial#p8825
  14. Posting a snapshot of both waterfall diagrams side by side would help. Is the energy going into the inverter the same for both simulations? How about inverter efficiencies?
  15. Thanks for this tip, it is something we will be doing ourselves soon.
  16. I would also like this feature, as I can't tell you how many times I've had to and will continue to set the report to 2 decimal places.
  17. Hello, It would be helpful to be able to upload low light data for PAN file modification either by copying/pasting or uploading an excel file, rather than entering each point manually.
  18. Enter the shade scene builder under Near Shadings > Construction/Perspective. Zoom in to the PV plant, such that the view you want on the report is showing on the screen. Once you have that, select "save this view for the report" and then select "load report view", then exit and generate pdf.
  19. With the anticipation of increased use of bifacial modules in the future, it would be useful to be able to include hourly albedo data which is used in the calculations, perhaps imported with the meteo data when creating the MET file.
  20. Does this mean it is now valid to model trackers with a misalignment?
  21. You may need to reach out to the manufacturer for the derated value, whether it be a curve or tool they provide. I dont see anywhere in the software (OND file) which allows for elevation derate. You might then clip post-process anything higher than the derate value @ your elevation.
  22. Hello, I am interested in understanding two of the bifacial modeling inputs better: rear side shading, and rear-side mismatch. Have there been any updates as far as research or studies go which shed light on providing realistic values for these inputs? It seems the PVsyst default numbers are 5% for rear-side shading, and 10% for rear-side mismatch. How were these values arrived at? Thanks.
  23. It is not possible to model trackers on a ground terrain. You can only slope them in the N-S direction using tilt.
  24. In version 6.7.2, when I select a tracker array in the shade scene and set azimuth to say 11, the array is adjusted accordingly. If I then deselect the array and reselect it, the azimuth is reset to zero. It seems to me the azimuth should remain to what it is set to.
  25. I would check graphics card drivers, install a different pdf program, and instead of saving to pdf, print it to pdf like cute pdf, etc.
