Everything posted by dtarin
It depends on your design. I dont know about those Huawei inverters specifically, but some string inverters have jumpers which share the power input across all inputs, instead of running independently. Using the jumper will distribute the power when inputs are loaded differently. a) Do you have some inverters with a mix on the inputs? For example, there are 9 total inputs on an inverter, 7 of them are 2 strings each, and 2 of them are 3 strings each? b) Or do you have entire inverters with 3 strings per input for all inputs (i.e. 27 strings per inverter), and others with 2 strings per input (i.e. 18 strings per inverter) If it is a, separate the mixed inverters from non-mixed inverters (if it is the case): for the mixed inverters, count the total number of inputs with 2 strings per input, and set as one array. Count the number of inputs with 3 strings per input, and set as another array. These two arrays will use the multi mppt feature. The non-mixed arrays will not, and you will simulate normally. If your inverter operates the mppt channels independently, and does not power share between inputs, do not set the Pnom ratio to be the same. If they do power share, set Pnom ratios to be equal for the multi mppt arrays. If it is b, dont use the mppt option, and have two arrays with the total number of inverters for each design (2 strings/input, 3 strings/input)
Same procedure for daily and monthly calculation: 1. Get total energy output of plant for time period, Egrid (in kWh, MWh, etc) 2. Calculate hourly average of irradiance 3. Use basic calculation E_Grid/(Sum_of_hourly_POA*DC_Plant_Size) Example: Egrid = 4800 MWh DC size = 2990 kW Sum of hourly POA = 1940kWh/m^2 (4800*1000)/(2990*1940) = 82.7%
- Discriminating orient difference between shading planes I believe this can be thought of as the resolution to which PVsyst will define a unique orientation based on the difference with other sheds - Maximum orient difference for defining average spread orientation This parameter will be used to define the range for which an average value will be calculated and used for transposition. See: https://forum.pvsyst.com/viewtopic.php?f=3&t=2524&p=6730&hilit=Discriminating+orient+difference+between+shading+planes#p6730
Hm. I can readily design a system with 2 tables at 15 and 20 degree tilt. -I select multiple orientations under orientation and define the two orientations. -In system tab, I have two sub-arrays, each one assigned to one of the orientations. -In project settings/other limitations, I have defined the limits to be 1 degree and 10 degrees respectively (I have modified this in hidden parameters as well). -In the shade scene. I have created one table at 15 degrees and one at 20 degrees. -In tools > edit orientations menu of the shade scene, I confirm the tolerance is 1 degree, and that two orientations are defined, with modules allocated to each.
PVsyst is averaging/combining the two different orientations into one. Set a lower discriminating orientation difference and maximum orientation difference to keep the two orientations separate.
By curved surface I meant import ground data (.csv) which approximates a curved surface to give his modules tilt and baseline slope.
Create subarrays under system. Use the number field at the top left to increase. Enter the desired number , hit enter for it to generate new subarray.
Export the loss diagram waterfall to excel. Click report, then export. This will export the losses, irradiance, and energy values. You should be able to calculate using this.
You can download PVGIS data here: https://re.jrc.ec.europa.eu/pvg_tools/en/tools.html
Hello PVsyst team, It would be helpful if Power Factor was added as a variable to the batch simulation process. Is it be possible for users to modify row 12 and add a power factor variable here in the mean time? 1 PVsyst simulations Batch mode; 2 Simulation parameters definition; 3 File Created on 19/03/20 11:25; 4 ; 5 Project ;;;PROJECT_NAME.PRJ; 6 Variants based on;;VCZ;VARIANT_NAME; 7 ; 8 Please define the parameters to be varied for each run; 9 Don't modify anything in the column titles !; 10 Only the lines beginning by "SIM_" will be executed; 11 ; 12 Ident;Create hourly;Mod. quality;Simul; 13 ;file;loss;Comment; 14 ;File name;[%];; 15 ;
Unlimited sheds can. For one module in landscape, define Nb of strings in the width of one row as 3; but you're likely to get a better result if modeling in 3D shade scene (how much better I cannot say). This would only be true for landscape orientation. If modeling in 3D shade scene, with 1 in landscape, and a string size of 5, your partition size would be 3 in height, 5 in length.
Hello, It would be very useful if PVsyst were to allow inverter curtailment specific to each sub-array, such that a single project can contain a system where multiple inverters are curtailed differently.
This would be a nice feature and very useful at this time. For your initial issue of having all of your PVsyst files centrally located on a network, have you thought about using DropBox or some other similar app where you keep your teams PVsyst files, instead of your work network? It is pretty fast when your internet connection is decent, and changes to files would be saved pretty quickly. In the event you are without internet connection, they'll update any changes once connected. Copies are stored locally on your machine so there isnt any performance issue when accessing them.
need to maintain variants while changing meteo and site files
dtarin replied to drew.cates's topic in Shadings and tracking
Yes. Just select a different meteo and site file and re-save the project from within the project you are working in. On the Site line, select the magnifying glass ans search for a new site to open and select new site. It will then load and search for nearby meteo files. Select the one you wish to run, save project, and run. If you are running multiple meteo files, it might be easier to use batch simulations to run them. -
Two hours is not a long run time. You can run for half a day or more if needed. I've run 300 batch runs before. Dont use the PC while it's running and use something relatively up to date.
GlobInc is POA irradiance
Create the curved surface, import into PVsyst as ground data, drop modules onto the curved surface (under edit > set auto altitude). Use a .csv file with coordinates X, Y, Z (in meters) which define your surface.
It may not be supported on your version of PVsyst anymore.
Issue with shading model during batch simulations
dtarin replied to asboulton's topic in Problems / Bugs
Import Near shadings from Helios3D with trackers
dtarin replied to Eric's topic in Shadings and tracking
Last comment regarding helios 3d and trackers from PVsyst: https://forum.pvsyst.com/viewtopic.php?f=24&t=4188&p=9810&hilit=helios+3d+trackers#p9810 -
Not really. You can copy the first page and paste into excel as image (need to resize), or save pdf, and convert to excel. With Adobe it converts pretty well.
