Distribución de Potencia Salida del Sistema
Michele Oliosi replied to AlvaroRuiz's topic in Simulations
The difference is related to clipping here. In the first variant, you have some grid limitation or inverter clipping, which leads to power peaks being all concentrated to the 12175-12200 kW bin. -
Hi, There is nothing to do at the moment. Unfortunately, PVsyst cannot add a slope to the bifacial backside irradiance calculation. However, in the simulation, the front side irradiance is computed accurately with the 3D scene data, this doesn't change. Only the backside irradiance evaluation will suffer from not being a correct representation of the 3D scene. We will need to improve the model to correctly cover these situations, but it will take some time.
No the two questions are not really related I think. Here you are dealing with 3 things: The iso-shading diagram comes from the shading factor table. The table has discrete values. This is why the lines are "squared". Moreover the angles at which the table is evaluated is 2, 10, 20, ... which means that for 15° PVsyst will interpolate shadings from 10° to 20°, i.e.,the iso-shading will show non zero shading all the way to 20° even though the limit angle is 15°. If you want to avoid using interpolation, you can still switch to the "slow mode". If you use that, in the simulation, the shading will be accurately calculated for each simulation step. You are showing the electrical shadings table, which behaves more extremely. Even though you shade a small area, this means a lot of shading. In your case the shading at 10° is therefore close to 100% (electrical shadings).
In principle, you cannot input all of GlobHor DiffHor and GlPMeas when importing data. Which ones did you select in your MEF ? In order to use the GTI you need import only the GlPMeas. Where did you change the values manually ? I do not clearly see how to do that in PVsyst.
Diferencia Producciones entre Informe y Excel Bachsimulation.
It may be due to the aging mismatch losses. Please check whether you have saved the mismatch values or not. If you can check the "Keeps calculated Mismatch values" box, please do so. Another way to investigate the problem is to display more variables in your output file. You can also define output files with monthly values and several variables, for the regular PVsyst simulation. Comparing them will lead you to the source of the issue. I notice that the units in the batch file output are incorrect, we need to address this. -
Hello ! I'm leaving a translation in English - the forum communication language. ---- Good morning; After running several simulations of a certain project, I find that in several of the simulations, there is a difference in E_grid between the report and the Batch simulation. In the default simulation I have year 1, Pitch 6.5 meters, exactly the same parameters that I include in Excel BatchParams for the same conditions. I attach photos corresponding to the same simulation variable and without changing any data. I don't understand why this difference between report and Batch simulation, please if someone can help me I would appreciate it. Greetings to the entire community. -
Hi, here the main error is related to the bifacial modeling. Once the backtracking in the 3D scene and orientation agree, there should be no issue with backtracking. Please see the following help page https://www.pvsyst.com/help/bifacial-conditions.htm It should help you proceed with your simulation and see what is wrong.
3D SCENES- MULTIPLE ORIENTATIONS- BIFACIAL MODULES
Michele Oliosi replied to raulserr33's topic in Simulations
Horizontal and vertical PV modules as a system problem
Michele Oliosi replied to Filimena's topic in Shadings and tracking
Hi, At the moment, the bifacial model for the backside irradiance works only with a single orientation. You will have to split your system into two variants. -
Yes, PVsyst does at the moment recalculate the GTI from a GHI and DHI values. GHI and DHI may be generated from an input measured GTI. This is because as things stand, a MET file can be used with any orientation, i.e., it should be useable with an orientation other than that of the measured device. Moreover, the GTI itself does not have all the needed irradiance information, we need to decompose into diffuse components and direct component in order to make all calculations e.g., IAM or shadings. However, recomputed GTI and original GTI will in general differ by at most 1%.
How to calculate the irradiance on ground?
Michele Oliosi replied to squeezer's topic in Simulations
Hi, as far as PVsyst goes, this is not yet possible. The only variable that can be exported currently is the GlobGnd which gives you the average irradiance on ground in the system area (i.e. removing shading from the PV tables). But there is no spatial distribution. However we will indeed implement features that can help with agrivoltaic plants in the future. These features may come as soon as next year, although the schedule has not been set yet. -
V7.3.1 diffuse shade on trackers - issue with tracker selection
Michele Oliosi replied to Debbie's topic in Problems / Bugs
Actually the "automatic" selection is the historical way that was used in previous versions. We added the window for people to be able to have more control on the choice of trackers, while being able to use the "old" way. It became clear we had to propose other ways when we noticed the issue you point out. The related help page https://www.pvsyst.com/help/tracking_diffuse.htm -
Dear Brij, It is incorrect to refer as the LID loss with respect to the nominal energy value. You have to consider the loss diagram flow: The LID is only accounted after the irradiance level, temperature, module quality losses (and other losses that may appear in your project). I.e. you need to change the value you use in B in your equation to account for these.
It is possible but it will only work if you use "arrays of tables", in particular if you have arrays that share the same pitch, orientation, and table sizes.
Correct partition layout for tables
Michele Oliosi replied to dennis.stu's topic in Shadings and tracking
Yes this looks ok ! -
@NIken if you can, in "Orientation" define two orientations each with their azimuth (e.g. -90° and +90°). Mixed orientation is the correct setup in the "System" window
PR correction on tracking systems
Michele Oliosi replied to Esteban1990's topic in Shadings and tracking
What is meant is the following: the tracking motion will exacerbate the seasonal variation of the PR, indeed in great part due to shadings. This is the corresponding graph in the documentation: In practice, this means that the goal of having a more stable PR throughout the year is missed. You can see in the graph that the usual PR is more stable. I am not sure what the results are with backtracking though, it may be worth checking. -
Indeed, currently the custom import is limited to handling only a single year (i.e. you need to split your data into 10 files). The only way currently to import a series of years at once is if the data is in standard PVsyst format (https://www.pvsyst.com/help/meteo_pvsyst_standard_format.htm), so that it can be imported via the "Known format" import tools.
Yes of course, if you are estimating the production for several years, you should implement a degradation rate. 0.4%/year is the standard value in PVsyst and shown to be a typical value by various studies.
You can change the "lower temperature for absolute voltage limit". This should be the minimum temperature recorded over multiple years.
It is not possible currently sorry. Note that a second decimal place means between 0.01% and 0.1% depending on the GCR. This is well below the usual precision of the simulation; moreover, isn't this well below the typical significance of geometric measurements?
