Comparison of "Near Shadings" value in version 7 and 8
Michele Oliosi replied to FUJITA_ANE's topic in Problems / Bugs
There has been a very small improvement to the way the shadings are interpolated at low sun heights and close to the “behind the plane” thresholds. However, the change seems rather large in your case. We would gladly take a detailed look at it, if you can send us your project over at support@pvsyst.com if possible. Thank you ! -
This does not seem related to the domes, actually. This type of error usually stems from how the module has been defined. However, the exact cause cannot be known from the message alone. There can be multiple reasons for it. If you could export and send us the project at the email written in the message, it would allow us to take a deeper look and find the underlying cause. Thanks in advance !
Which one is POA value from PVsyst Results Raw data?
Michele Oliosi replied to Mike99's topic in Meteo data
GlobBak is not technically weather data, since it depends on the system definition. You should instead run the simulation and create an output file: https://www.pvsyst.com/help/project-design/simulation/create-a-csv-file-of-hourly-daily-values.html So is BackShd. Note that if you have defined an horizon profile, you should rather use GlobHrz, instead of GlobInc, for the frontside POA. Indeed, the horizon also affects the solarimeter. -
PVsystCLI: Changing Simulation Parameters
Michele Oliosi replied to Gustavo Pianovski's topic in How-to
Right now we are looking at the next minor version of PVsyst (8.1), but that could still change (before or after) of course. -
At the moment, changing the parameters programmatically can only be done via PVsyst (by using the batch mode to create and/or simulate new variants). In the future, we will extend the use of CLI so that parameters can be changed programmatically only using PVsystCLI. -
I have checked further, and the pitch seems to be effectively changed, even for the backtracking algorithm. This is despite the message saying otherwise. The message seems to stem from a check, before updating the backtracking algorithm. It is therefore not relevant. Note that this does not happen in version 8 anymore, in principle. Have you checked ?
You still have the column "Pitch" in your batch file. Since there are only trackers in the scene, the pitch cannot be changed, which triggers the warning. What matters is the other column, "Trackers pitch EW". I would recommend removing the "Pitch column" and rerunning the batch. Note also that you should be mindful of how the backtracking parameters were set (3D scene > Tools > Backtracking management): Here the mode is manual (automatic unchecked). This means that if the batch mode changes the pitch, the backtracking algorithm will not follow, and the yield may decrease (either from being suboptimally oriented or from shadings). Instead if you choose "Automatic", then the backtracking will adapt to the changes from the batch.
Do you want to have the theoretical plane of array irradiance without shadings, horizon, etc, or the effective irradiance you would measure front side / back side ? The backside POA irradiance (without applying shadings or horizon) is GlobBak + BackShd (GlobBak has had shadings applied, so some irradiance needs to be reintroduced). GlobInc is the POA irradiance on the front side (without applying shadings, etc). -
Near Shading Loss in Version 8 Showing as Zero?
Michele Oliosi replied to JStief's topic in Problems / Bugs
Okay, this seems to be a new bug. We will take a thorough look into this. Could you send us your project at support@pvsyst.com? This would be extremely valuable to fix the issue as quickly as possible. -
You should check the following window : 3D scene > Tools > Tracker diffuse shadings definition. There you can check whether the representative tracker has shading masks (neighbors), if the loss is zero it probably is not identifying masks properly. You can switch to "all trackers" which is slower but is more accurate and robust. Let us know if that fixes the issue. -
Thank you ! This may or may not be the reason, but now it is important to go through all the sub-arrays in the system window, to make sure the different bifacial models are active and well-defined. Indeed, there is a bifacial model per orientation now, to allow for different sets of bifacial parameters.
Indeed, the process is only manual for now. At some point we will get a tool to quickly assign orientations. PVsyst CLI will help with automatizing the "simulation" step, but for now no other steps, so it won't help here. By the way, what is your case, i.e., do you have more than two orientations in parallel electrically ?
Hi, yes that is technically possible, to associate each tracker to a different orientation. The basic TF losses are then obtained orientation by orientation so that works as well. The module layout will help in terms of shadings. One possibly missing feature is if you have more than two strings in parallel on the same MPPT and these are on more than two orientations, it is not possible to define that properly in the System part. Currently, string-to-string mismatch is possible to evaluate only for two different orientations connected in parallel. Finally, moving in the territory of custom tracker movement is more complicated. Indeed, you can apply a backtracking algorithm to each tracker movement, but that does not depend on the relative height. At the moment, only the ideal algorithm that avoids shades on a regular array of trackers is applied. Of course, we are working on a solution for custom movement, but that will take several updates before its release.
Thanks @Maruyama. Indeed, this is the way to go. We need to give better guidance on this point including in the UI side of the software. We will be working on this.
@dtarin yes there are actually plans to completely rewrite the weather data import, to address these two issues and others in one go.
If you import sub-hourly data you can then use that as an enhanced MET file in your simulations. Here is a help page that breaks it down: https://www.pvsyst.com/help/physical-models-used/grid-inverter/subhourly-clipping-correction.html
Generally, smaller (rooftop) installations are more complex in terms of shading than large, regular ground mounted systems. In the latter case, strings are usually distributed on one or two large tables, and this pattern repeats, which makes it possible to use the “partition model” which is a simplified model to estimate electrical shadings. In the former, smaller rooftop case, it is best to use the most detailed modeling of electrical shadings. This is the module layout option, which necessitates to determine exactly which module 3D model is connected to which string. Even though your system is simple electrically, given the 3D scene, shadings will have a non-trivial aspect and necessitate this more advanced calculation. You can see one such complex shading pattern in your first screenshot.
Hello, the forum language is English, but if you send your query to support@pvsyst.com we will happily reply in French. If this period is continuous within the interval of January 1st to December 31st, then you can use the following tool. From the project window, go to “Advanced simulation”. There you can change the start and end date of the simulation. If you then run the simulation by clicking on the “Run simulation” button in the “Advanced simulation” window directly, the correct dates will be set. However, the method you suggest will also work, i.e., importing weather data that covers a shorter period (possibly with holes).
Hi, not sure what you mean by using a CSV to build the 3D scene. Could you send your project at support@pvsyst.com? We would then be able to look at the 3D scene. In any case, take a look at 3D scene → Tools → Backtracking management. There you can verify the backtracking parameters.
Hi ! Actually, you do not need to have an "array of tables" in the 3D scene to apply the bifacial model, but there are a few regularity requirements that have to be met: https://www.pvsyst.com/help/bifacial-conditions.htm However, it cannot be expected that you modify the pitch of your plant just to run the simulation. For that reason, it is possible to modify the threshold for the activation of this error. Since this error stems from the evaluation of the standard deviation on the pitch distribution, the threshold can be changed in the advanced parameters : Home window > Settings > Edit advanced parameters: Please be aware that while this won't modify the results of the simulation, it will allow you to simulate a situation in which the bifacial model (which is a regular idealization using the average pitch and table size values) will not fully represent the complexity of the 3D scene. However, usually, unless you have a very strange setup, the error from this discrepancy is minimal.
There is a problem with the trackers created by zones. These end up having +-90° of maximum and minimum rotation angles. To correct this, once you created all trackers, you can either go to Tools > List and management of objects, or simply press CTRL+G in the 3D scene. There, you can find the column with the min / max phi and edit them to be compatible with the orientation.
@Loïs Masson Yes it is possible to use partitions with a non-rectangular PV table. Honestly, with non-conventionally wired modules such as the voltec ones, there are no other solutions with the current PVsyst version. Finding equivalent modules, to run the module layout calculation, and using that to adjust the results of the partition calculation, as suggested at the beginning of the thread, seems like a reasonable idea.
