ShivamPandey
1 Follower
100916 profile views
  1. Hi We are working on a project that needs certain parameters in the 8760 (image attached) GlobBak (Global irradiance on the rear side) and FHrzGl (Horizon shading factor on global) does not show up in the 8760-csv file. Is it due to the bifacial model being disabled as projects are canopies, and if there are no far shading losses for the project? FHrzGl only does not come up for the sites where far shading losses are zero. I just wanted to confirm before responding to the client
  2. If we need to connect 6 strings of 15 modules to three MPPT inverters, which option should we use between Power sharing between MPPTs and within the inverter Should we choose independent MPPTs and or a single inverter with power sharing within the inverter? Technically, no power sharing will be done as all MPPTs havethe same amount of power, but does choosing between these make or create any difference in simulations or productions?
  3. Hi I have an older Pvsyst project export zip file, but when importing it into PVsyst, it is showing the following errors. Older project is created witjh PVsyst 8.0.5 Zip Folder contains all the files exported. Same is the issues with the background image imported from map service within the near shading. Map is not showing up when imported into a different machine or PVsyst
  4. PVsyst Having the same issues, any solution for this
  5. How to import specific location imagery and terrain data if the weather station coordinate is different from the actual location. The location is outside the map limit in the Pvsyst interactive map. Also, can we crop the image or terrain map after importing it into the 3D scene?
  6. We need to maintain the plant unavailability in the PVsyst loss diagram between 1.45% and 1.50%, with no flexibility on this requirement. Currently, we are adjusting the date and time to achieve the correct values. Do you have any alternative methods to reach these numbers? The unavailability time fraction and periods are fixed at 1.5% and 1, respectively.
  7. After importing PVC file, getting this error, "Orientation #2 "Tracking horizontal axis, Azim. 0.0°, Average": No attached subarray in the System part!". But in the orientation tab, every parameter is the same. See below snip. There are two orientations one has backtracking and another with average. I deleted orientation 1 from the 3D scene and all trackers from orientation 1 to orientation 2 with average and selected average from the pop-up received. What is the reason behind it even when all parameters are the same?
  8. What should be the correct approach for the partition of half-cut cell modules in fixed-tilt tables. For 2P*13 table size, strung in U 4*number of modules per string i.e. 4 in the Y axis and 13 in X axis For 2P*26 table size, strung in U 4*1 i.e. 4 in the Y axis and 1 in X axis
  9. Just for reference, once opacity is set to zero again in the near shading, we need to simulate the project again (This might cost hours with larger size or module layout just to remove the background from the report). Please fix this also if possible.
  10. Logo was changed after doing simulations in another project with a different logo. Logo from the second project was retained in the first project instead of the correct logo. We have to change logos every time we need to work on different projects with different logos.
  11. Module mismatch losses keep changing after doing simulations. After doing simulations or making any changes in detailed losses, module mismatch losses changes for one of the subarray.
  12. How can I know if the horizon is correct in the pvsyst report or in the project?
  13. PVcase imported trackers do not have pitch defined when going in the modify object. Does it impact backtracking? I have heard from a few industry people that it does not do the backtracking as it does not have the pitch defined (or not an array of the trackers) and all the trackers are ungrouped and are not an array of trackers Also if I ungroup an array of trackers which was created in PVsyst near shading, does this affect the backtracking? See the below snip for reference Pvcase export An array of trackers was created in Pvsyst and then ungrouped
  14. Just for my understanding, is it possible to have different albedo for the far and bifacial model or it should be the same if we have albedo values available? Project setting albedo is used for simulation even if modules are mono-facial.
  15. Why Albedo from the project setting is not copied to the variant bifacial model, we always have to enter values two times. If we need to edit a variant albedo, we can do it manually later during variant design. What is the use of project setting albedo?
