Hi @ayoub96, no you are not missing details I think. Can you give some sample of your values and sums ?
Tilt angle of fixed tilt and tracker arrays
Michele Oliosi replied to laurahin's topic in Shadings and tracking
Hi can you give some examples on the differences you find ? Indeed you may be in a situation that has almost the same angles and therefore leads to slightly different results. The PhiAng is the angle used for the whole time step, so in principle both results should match. Some other geometry factors may be at play: do you have exactly the same geometry of the tables ? (Module spacing, frames, etc) and are you using the same shading calculation ? Finally, the diffuse shadings for trackers are done a bit differently, so comparing values after the shading loss may not lead to the same results, albeit the results should be close. -
Shadings calculations for multi orientations fields
Michele Oliosi replied to Nicolas T's topic in Shadings and tracking
Dear Nicolas, Your understanding is correct. The results at the end of the simulation are for the whole system. No at the moment, is not possible to get results for each orientation as a single simulation output. -
Dear IgLoo, unfortunately no. You can change the report settings but at the moment TArray is not an option for that table. I'd add that since TArray may widely during the day / night, the monthly average value may not be very informative.
Need advice for complex shading scene
Michele Oliosi replied to Helioworks's topic in Shadings and tracking
Yes, it technically is less accurate to modeling things with one orientation instead of having all orientations of your tables. But unless the RMS of the differences between planes is extreme (e.g. 20°) there should not be a huge impact. -
Is it a PAN file provided by a manufacturer or a module from the database ? You can check whether the parameters do not have any of the default checkboxes checked (one of them is already good). E.g. If you are not sure you can send your PAN file to support@pvsyst.com. Personally I am not quite confident about giving good advice on modules, but my colleagues should help with that.
Failed to generate: Custom weather data file
Michele Oliosi replied to Jhonny R.'s topic in Meteo data
Looking at your data it seems that the irradiance values are too high. First of all please make sure that all the parameters of the import are correct. Try to double check all the units so that they match the units in your measurement. If in trouble you can also assign a multiplier to each value. I see you have a time sihft issue, I'd recommend setting the time shift (30' + or -, I am not sure of the needed sign) in the conversion protocol as well. -
If you need to distribute strings over multiple tables, you can only do that with the module layout. At the moment we do not support partitions on multiple tables. I would advise the following: run the module layout once to get an estimate of the electrical shading factors. If your scene is too large, you can create a smaller scene with similar shadings. Then when using the partitions, start by defining 100% for the electrical effect fraction. If you see that this overestimates the shadings compared to the module layout, you can reduce the fraction. Apart from that there is no failproof way to define the electrical shading fractor whenever you have both regular (row-to-row) and complex (e.g. trees) shadings.
Pr different in report and hourly data file
Michele Oliosi replied to IgLoo's topic in Problems / Bugs
Ok then that is likely the reason. The PR is basically a ratio between yield and incident irradiance. These values are different at every hour. Now, you should remember that the ratio of averages is not the average of the ratios. The correct way would be to sum the yield (E_Grid) and average the global incident irradiance (GlobInc) separately and then recalculate the PR based on the two resulting values. -
On the main window, try going to File > Reload databases. As a second point, please check that coordinates do match closely. Let us know if either helps.
Can you explain your calculation for the monthly average PR ? -
how to set the string configuration in this case
Michele Oliosi replied to garf's topic in Simulations
At the moment you cannot set different strings on the same MPPT within PVsyst. However you could modify the inverter and add an extra MPPT. As long as you are careful with the "power sharing" configuration, it can be a good representation of your system. -
Polygonal field edition: module spacing and padding edition
Michele Oliosi replied to sunway's topic in Problems / Bugs
At the moment the workaround is to switch directly to "by modules". Adjust the spacing. Go back to "by summits" and redesign the polygon. I have submitted a ticket to improve the functionality at some point in the future. -
I see, I will check whether we can create a similar functionality in the newer PVsyst as well. -
How to download the month wise expected module temperature in deg c
Michele Oliosi replied to winothkanna's topic in How-to
As far as I know, in the context of PVsyst they are the same (cell and module temperature). I will add a note in the help. -
If you click on "by modules (adjust sizes)" instead of "by summits" you should be able to change the module spacings. -
Orientation > Tracking, horizontal axis N-S
Michele Oliosi replied to julmou's topic in Shadings and tracking
Thank you for the feedback. This is a known bug for the drawing only and its correction is in our roadmap. It does not affect the simulation in any way. -
Hi, Please provide your question in english if possible. The language of the forum posts is in english (see forum rules). You can send us your questions at support@pvsyst.com you can turn on these settings by clicking on "by modules (adjust sizes)"
