Lazare Fesnien
Administrators
  1. Dear Joao, Please, try to enable the anti-aliasing rendering option:
  2. We are pleased to announce that our collaborators #BrunoWittmer, #MicheleOliosi and #AgnesBridel will be present at the 40th European Photovoltaic Solar Energy Conference which will take place in Lisbon (Portugal) from September 18 to 22, 2023. For more information : https://www.eupvsec.org/index.php We look forward to seeing you there
  3. Dear Andel, Usually we can estimate that 1 ha corresponds to 1 MWp of PV module.
  4. Dear Sana, To do this, you must create sub-array in the list on the right in the "system" window. Please read our FAQ : https://www.pvsyst.com/help/sub_arrays.htm?zoom_highlightsub=sub+array
  5. Dear HTC, Our communication languages are French and English, please communicate with these languages. To answer your question, here is our FAQ concerning the single-diode model: https://www.pvsyst.com/help/pvmodule_model.htm?zoom_highlightsub=one+diode+model Regards
  6. If you have made an orientation and azimuth choice with an annual irradiance optimization, the first estimates appear. When you click on OK and then return to the window, PVsyst does not change the Azimuth and tilt values but does not show the graph by default in Winter (the most unfavorable) this does not change the simulation or your parameters
  7. Dear Sharoff Dion, The "quick optimization" tool is a display tool, it has no impact on the simulation. By default PVsyst checks the "winter" box. Regards
  8. Dear Garf, To do this, please click on "PRINT" : Then check the box "include module layout on final report" : Regards,
  9. Dear Nio, In a project connected to the grid, this changes here :
  10. The absolute low temperature is not taken by the meteo file. You can modify it if you have data on it. Please read our FAQ : https://www.pvsyst.com/help/pvmodule_lowlighttool.htm?zoom_highlightsub=low+light
  11. Dear Moataz, In the system tab, when choosing the PV module, PVsyst displays the voltage Voc at -10°C. It is this value which is taken into account for the calculation of the maximum number of modules in series. Absolute Cell lower temperature for determining the Maximum possible voltage of the array. The default is set to -10°C for most European countries (best practice rule). For this limit, the cell temperature is considered as the ambient temperature (worst case when the sun suddenly appears on the field). You should define the lowest temperature ever observed during the day for this site. NB: these parameters are used for design only. They are not involved in the simulation in any way. Please read : https://www.pvsyst.com/help/inverter_array_sizing.htm?zoom_highlightsub=Array+voltage+sizing Regards
  12. Dear Sir, Can you send us your project in ZIP format to support@pvsyst.com in order to give you a precise answer?
  13. Dear Sir, Can you send us your project in ZIP format to support@pvsyst.com in order to give you a precise answer? Regards
  14. Bonjour, Cela est très étrange effectivement. Pouvez vous nous envoyer votre projet zip à l'adresse support@pvsyst.com ?
  15. Dear Said Allaw, The "Reactive power" is not a real electrical power: you cannot produce any movement or heat with it. Reciprocally, the production of reactive power doesn't consume any "real" (active) energy. Now the output electronic circuits of some inverters are able to "produce" a reactive power on the grid, by "absorbing" power from the grid and "reinjecting" it with a phase shift. They may behave in the same way as a capacitor for "absorbing" reactive energy (or possibly an inductor, but this is not useful). This feature is sometimes provided by PV plants to the grid, especially during night. This contribution is not treated by PVsyst, as it is not related to the PV production. PVsyst only treats the Reactive power associated with a PV "active" power production. The reactive power treated in PVsyst is always proportional to the Active power. The operating value will depend on the available irradiance. This always produces the active power (POutInv = Parray * inverter efficiency). Now if you have defined a phase shift, the inverter will also produce a reactive “power” POutInv_R = POutInv * Sin(Phi). But this doesn’t consume any additional power.
  16. Dear Said Allaw, PVsyst treats the Reactive power (or energy) linked to the PV production. This is done by a constant factor (Cos(Phi)) specified/required by the Grid manager. This reactive power is proportional to the produced energy. See the help " Project design > Grid-connected system definition > Power Factor". A reactive power may be created or absorbed, depending on your definition (Leading or Lagging power factor)
  17. Dear Said Allaw, Currently PVsyst does not allow pumping simulation without reservoir. You can either put a very large or very small tank in the system to get around this limit.
  18. Dear SSIRIS, Yes it's intentional. This function is under development by our teams. Regards,
  19. Dear Bendesa1962, Can you make me a screenshot of the window with this error to explain ?
  20. Hi, Below is a link to a PVsyst video explaining how to create an OND file. If you are stuck, you can send us your OND file and datasheet so that we can help you solve the problem (support@pvsyst.com)
  21. Dear Ayad, The ohmic resistance of the wiring circuit induces losses ( ELoss = Rw · I² ) between the power available from the modules and the power at the terminals of the sub-array. The relevant parameter for the simulation is the Rw value, which is an equivalent resistance of the wires, as "seen" from the input of the global sub-array (i.e. the set of MPPT inputs defined in this sub-array). You should define one Rw value for each sub-array in your system. A PVsyst tool allows you to easily calculate this information in "Detailed Losses" then "Ohmic Losses" then "Detailed Computation" Regards,
  22. Hi, You can account for the aging of the PV modules in ‘Detailed losses -> Aging’. This allows you to make a simulation for one specific year of operation. You can also make multi-year simulations in ‘Advanced simul. -> Aging tool’. PVsyst will not change the nominal power of the PV modules, but simulate with a model of degraded PV modules. This means that the performance ratio PR will decrease with time, since nominal power stays the same, but effective generated power will decrease. The aging of inverters is not modeled in PVsyst. For more explanations on how to use the aging tools of PVsyst, please see the corresponding help page : https://www.pvsyst.com/help/ageing_tool.htm
  23. Hi, It all depends on the characteristics of your system. There is no good or bad value
  24. Hi, This difference is due to several reasons : - In grid connected, the inverter has effective MPPT inputs to seek the maximum power point - Stand alone, regulators with MPPT don't have good efficiency. In the grid connected system, losses and gains are put by default in the tab "detailed losses" it's necessary to look at the two complete reports to visualize the differences.
  25. Hi, Can you send me an image of the error in order to understand the context ? Here are some explanations below while waiting for a complement : https://www.pvsyst.com/help/simulation_variables_standalone.htm?zoom_highlightsub=Array+oper https://www.pvsyst.com/help/simulation_process.htm
