Lazare Fesnien
Administrators
  1. Dear Meurville, Thank you very much for your interest in a PVsyst training. We propose some online personalized sessions in the form of Consulting and PVsyst project support, to answer specific requests (no standard sessions for the moment). If you are interested in this service, you are kindly requested to request an online quote here: https://www.pvsyst.com/consulting/ We will establish a program relevant to your specific requirements. Our sessions last for 2 hours (including participants question time) and are charged CHF 700.- Our online sessions are limited to 5 participants per session. We do not provide any guarantee relating to your simulation results. In the meantime, we have designed several online video tutorials which we invite you to watch: https://www.youtube.com/channel/UCMzsEWHk3f7XD_dg1lngmzg or access our online course at: https://vimeo.com/pvsyst If you have a technical question, please feel free to send an email to support@pvsyst.com With best regards,
  2. Dear Michalis Angeli, In the absence of reliable measured data, PVsyst proposes default values without wind dependency (i.e. assuming an average wind velocity): - For free-standing (open-rack) systems, i.e. with air circulation all around the collectors), according to our measurements on several installations: Uc = 29 W/m²·k, Uv = 0 W/m²·k / m/s - Therefore for fully insulated backside (no heat exchange at the backside, only one side contribution to the convecting heat exchange), the U value should be divided by 2: Uc = 15 W/m²·k, Uv = 0 W/m²·k / m/s - For intermediary cases (semi-integration, air duct below the collectors), the value should be taken between these 2 limits, but preferably lower than 22 W/m²·k as the air heat removing is often not very efficient. The default value proposed by PVsyst for any new project is Uc = 20 W/m²·k, Uv = 0 W/m²·k / m/s We have chosen this value as general default, because we consider that it is more representative of usual rooftop systems, managed by "less professional" people who will not necessarily modify the PVsyst default. For big systems, we suppose that trained engineers will indeed adjust this parameter (for example at 29 W/m² for row-like big power plants). - For domes, a manufacturer has measured the U-value on several installations (height about 40 to 70 cm above the ground): Uc = 27 W/m²·k, Uv = 0 W/m²·k / m/s: Now if reliable hourly wind velocity data are present in the data, we don't have any reliable measured data with wind. PVUSA proposes the following thermal correlation, widely used for the free-standing (open-rack) situations when wind speed data are available. Uc = 25 W/m²·k, Uv = 1.2 W/m²·k / m/s This corresponds to our default 29 W/m2, when the average wind velocity is 3.3 m/sec (rather usual in continental - not coast situations).
  3. Dear Emi, If you can, you should mix orientation 1 & 2 and then separate orientations 4 & 5. Attention, its not at all conventional to put two strings of different length on a single MPPT input
  4. Is is indicated in the PAN file that this PV module is no longer present on the market. You must therefore choose "all modules" in the "availability" filter.
  5. Dear LFurzsina, Maybe there is a problem in the definition of the PAN file. Can you send the PAN file to support@pvsyst.com ?
  6. Dear Shashank Sharma, These losses appear in the following loss diagram:
  7. Dear Emi, You can simulate virtually your entire project. Attention it is not possible in PVsyst to mix two orientations with different lengths of strings. I just made your system under PVsyst, you just need to make a little change in the naming of the orientations in order to simulate your system correctly.
  8. Dear Gba, This is a project setting. By default the value is 50°C, you can modify it from "Project settings" :
  9. Dear Emi, In your configuration you must define orientation1 and 2 with "mix 1 and 2" the define your sub-array N°3 as orientation N°3. This will allow you to position three orientation on two MPPTs like the example below :
  10. You must use the "power sharing" tool to set the power distribution correctly
  11. Dear Emi, You set one string for two MPPT inputs, it can't work
  12. Dear Ynesse, VmppNom: Nominal MPP voltage is sometimes specified by the manufacturer. In this case this may be an indication for the optimal number of modules in series. Weakly used in the sizing tool in the present time
  13. Dear Meurville, To limit the inverter, you must click on "energy management" then "Grid injection limitation" Regards
  14. Dear Paaul, No, at the moment you cannot set multiple orientations in a standalone system. This feature will be developed later
  15. Dear Manos Dro, To do this, you must create sub-array and then check the multi-MPPT box at the line level of the inverter. Then, the "power sharing" option is unlocked and allows you to distribute your power correctly" Regards
  16. Dear Furkann71, Please send your questions to support@pvsyst.com. You ask a lot of different questions in the same subject, it's not how this forum works
  17. Our languages of communication are French or English. Please translate your message
  18. Dear Fofone, Theoretically yes, after it will be privileged the multiplication of cable like 3 x 3G500
  19. Dear Fofone, Yes PVsyst allows you to do this, you can look in the Commercial and Utility demos available from PVsyst.
  20. The ohmic losses behave in a quadratic way with the array current: Ploss = Rw · Iarray². Now if the array is not operating at STC, the wiring loss fraction will become: Ploss / Parray = Rw * Iarray² / (Varray * Iarray) = Rw * Iarray / Varray. i.e. proportional to Iarray. This means that at half the irradiance (half the current), the wiring loss fraction will be half, etc. Therefore the Wiring energy loss has to be evaluated at each hour of the simulation, and accumulated in terms of energy. The final result of the Ohmic wiring loss (in terms of percentage) as shown on the loss diagram will be from this hourly energy balance. It is usually of the order of 60% of the Loss fraction specified a STC.
  21. Dear Detroit Solar, Thank you very much for your interest in a PVsyst training. We propose some online personalized sessions in the form of Consulting and PVsyst project support, to answer specific requests (no standard sessions for the moment). If you are interested in this service, you are kindly requested to request an online quote here: https://www.pvsyst.com/consulting/ We will establish a program relevant to your specific requirements. Our sessions last for 2 hours (including participants question time) and are charged CHF 700.- Our online sessions are limited to 5 participants per session. We do not provide any guarantee relating to your simulation results. In the meantime, we have designed several online video tutorials which we invite you to watch: https://www.youtube.com/channel/UCMzsEWHk3f7XD_dg1lngmzg or access our online course at: https://vimeo.com/pvsyst If you have a technical question, please feel free to send an email to support@pvsyst.com
  22. Dear Wanderson Alves, Our discussion languages are French and English, please translate your email. Regards,
  23. The IAM model is defined with the PV module parameters, page "Additional data > Customized IAM". Here you should define the glass surface type, and PVsyst will attribute the corresponding IAM model. The PAN file of low light measurements, apart from the integration of this data, is extremely sensitive. The reference is that at 200 W/m2, the real efficiency is -3%.
  24. Dear Daniel, In the batch mode you can do this :
