In PVsyst, you can get meteo data for anywhere on the earth. See our FAQ Which meteo data are available in PVsyst ? Now if you want very specific and good data, you can get them from companies like SolarGIS or 3Tier. But these are for pay.
Yes, this is the correct way of estimation the global irradiance with shadings on the plane.
The Focalization loss arises indeed when the trackers are not pointing to the sun. - In the simulation, this arises when the sun is outside of the tracking limits. - In the reality, this could be produced by any misrunning of the tracking system. Remember that with 500x concentration, the acceptance angle is less than 1° or even 0.5°.
As a general definition: Efficency = Pmpp [W] / (Incid. Irrad [W/m2] * Ref area [m2]). The reference area may be either the module area (usual module efficiency) or the sensitive area (which will give a "cell" efficiency, more related to the technology). In the specific case of the STC efficiency mentioned on the loss diagram: - Irrad = 1000 W/m2 - Pmpp = Impp * Vmpp issued from the application of the model at 25°C
The annual variability is the RMS of the normal distribution of your annual data. If you have 10 years of meteo data for your site, you can import them (create 10 *.MET files in PVsyst - each MET file is for one year). Then since version 6.37, you have a new tool in "Meteo tables and graphs" > button "Compare", for comparing different meteo files and establish the RMS of their distribution.
PVsyst works on an hourly basis. You can import 1-minute data, but they will be converted into a meteo hourly file *.MET, which is the only basis for PVsyst simulations.
For the first problem: the version 5 of PVsyst is not able to recognize network paths (beginning by \\). You should put your source file in a path beginning by a disk letter. For the second problem: The TMY format follows a very strict definition. PVsyst only recognizes files following the TMY2 or TMY3 protocol definitions. But perhaps something was not up-to-date in this very old version 5.59. You should update to the version 5.74.
Sorry, we will correct this in the next version 6.38, very soon. Please try to print to a PDF document, it seems that this problen doesn't appear in this case.
This arises at the first use of the version 6.35. You should simply create a new workspace. However this has been corrected in the version 6.37, please update.
Please explain exactly what you are doing, in which part of the program you are when this error occurs. Please send a screenshot of the error message (full screen) to support@pvsyst.com.
Some parts of the software are translated in different languages, including Spanish (switchable within the software). However this is not complete, we have still to translate many parts. But sorry, we don't intend to issue documentation in other languages than English in the present time.
In your first question, I don't understand which "Default value" you are talking about. The "number of strings" in the width of the row: if you have one only module, it will be one. If you have 2 modules in width, this will be two if the modules belong to 2 different electrical strings, and one if they belong to the same string. The cell's width is 15.6 cm if you have 6" cells, and 12.5 cm if you have 5" cells. I think you did not understand the meaning of the "fraction for electrical effect". When you calculate shading losses, you have the "linear" losses" (the real deficit of irradiancre due to shades) and the "Electrical losses" corresponding to the electrical effect due to string connexions (i.e. the yellow part on the 3D shading animation). The "Fraction for electrical losses" indicates to which extent the Yellow part is taken into account in the losses. For shed arrangement this fraction will always be 100% (i.e when the bottom cells row is shaded, there is no electrical production anymore for this string). Please see our FAQ How to evaluate the the effect of by-pass diodes in shaded arrays ?
These data will be difficult to accurately manage within PVsyst, as the time shift is highly varying along the year. This indicates that your datalogger's time reference has shifted, and the data are difficult to accurately recover (not possible in PVsyst). In this case the best choice would be to specify a time shift of around -15 min, so that the time variation of the data with respect to the average will be +/- 15 min. Now such a variation could be explaind by the fact that you imported the data using the "Solar time". Please make sure that you have specified "Legal time" in the second page of the import format.
Sorry, I don't understand well what you are doing. However mathematically, averaging PR for different periods doesn't make sense: you have to add the GlobInc and E_Incid values, and calculate the PR with these sums. Please see our FAQ "How is calculated the PR ?" Now I don't understand well why you have so low PR with low irradiations: for analyzing this you should study the detailed losses in hourly values.
The Clear day model shown in PVsyst gives a reference of the time at which the solar geometry is computed within the software. Imported data should match the internal time of PVsyst. This is usually a difficult question, explained in the help "Meteorological data > Hourly Meteorological Data > Time shift". When importing hourly ASCII files, PVsyst allows to specify a correction for the real measured data time with respect to the internal PVsyst time. But sorry, a correction of data written in UT is not yet available in this tool.
Yes, it is possible to simulate this situation. In the calculation version parameters, you have an option "net metering", which requires to define your self-consumption profile. After defining that, the simulation will evaluate de self-consumed energy, and the energy reinjected into the grid sepaprately. You can simply consider to discard the energy into the grid (E_Grid). However this cannot be explicitely shown on the report (the EGrid will always be mentioned in the result).
Generate missing data when importing PVsyst standard format
André Mermoud replied to ckoessler's topic in Problems / Bugs
The replacement of data is indeed not implemented in this tool. I have done this for the next version 6.36, to be released soon. The missig values will be replaced by an average of the corresponding values of the previous and the next day. -
In the version 6.35, we have implemented the new Meteonorm program (DLL) V 7.1. And we observe that indeed for some locations, this new DLL crashes. However this is not quite reproducible, and often trying a second time gives the correct result. We have to investigate this problem with the provider of the Meteonorm DLL.
Yes. In the menu of the 3D editor, you have an option "Tools" / "Ignore interpenetration of PV fields". This may result in errors when calculating the shades on the concerned table (not important im many tables).
Which tool are you using for importing these data ? Which value are you replacing (GlobH, DiffH, temp) ? How much values are to be replaced ? I think I have indeed not developed this replacement of values by a synthetic generation in the general ASCII importing tool. I have only done this with specific importing formats (like HelioClim or SolarAnywhere if I remember well). This means that the help is probably erroneous. However if you are not interested in the "integrated" results, you can either put null values, or simply suppress the concerned records in the ASCII source file and reimport it. -
This depends on the locatione where you are of course. The Timezone is an official specification for a given location. The summer Time Zone is usually a shift by +1 hour. Usually PVsyst (and people dealing with meteo data) use to define the Winter time for the whole year. Now in Australia there are half-hour (and even quarter hour?) time shifts. There may be errors either in the Meteonorm data, or perhaps also in the SolarGIS data. The important thing is that the hourly values are established for a given Timezone. If you change the Timezone you will have a shift in your data, with respect to the internal PVsyst time definition. You can analyze your data in "Meteo tables and Graphs > Check data quality", and here get explanations in the help by pressing F1 (Help: "Meteorological data > Hourly Meteorological data > Time shift").
This is a parasitic line appearing on the report by error. It is not significant. This will be repaired in the next version 6.36.
No sorry, this is not possible in the present time. The helios3D exporting tool to PVsyst doesn't define trackers, and it is not possible to convert tables into trackers in PVsyst.
Message en français: "Aucune imprimante par défaut sélectionnée". Sorry, this sometimes arises even if you have correctly installed printers (it is a Windows problem), and we don't know why. You can try to download the free tool PDFCreator (to be installed as a printer): http://www.pdfforge.org/products/pdfcreator and select it as default printer. To my knowing this works in any case. And after that every printer may again be recognized as default printer. Mysteries of Windows...
Long shading objects, perspective & wireframe view
André Mermoud replied to jammyc's topic in Problems / Bugs
I had indeed defined an Axonometry view mode in a very old time (see the main menu "View > Specify observer's position"), but it seems that this functionnality has been lost along the evolutions of the 3D editor... We will try to correct this in a next version. We have also to analyze the problem of very long objects, distorted when far outside of the screen.
