  2. Yes sorry, this is an error in the graph title. The values for the curves calculation are indeed those specified in the dialog. Thank you for pointing this out. We will correct this for the next version 8.0.16.
  3. Dear sir: I found that the inclination angles of the two are not the same. Is it a bug?THANKS
  4. Hi, The execution of the shading factor calculation may take some time, and has to be evaluated at each simulation hour. For speeding-up the simulation execution, we calculate a table of shading factors for specific sky orientations (every 10° in tilt and 20° in azimuth). Then at each step, the simulation can calculate the exact sun's position, and interpolate in this table ("Fast" shadings calculation"). This table is also used for the elaboration of the shading factor on diffuse and on albedo integrals. You find more details in our help, for instance the treatment of the Beam component: https://www.pvsyst.com/help/project-design/shadings/calculation-and-model/treatment-of-the-beam-component.html and the shading factor table: https://www.pvsyst.com/help/project-design/shadings/calculation-and-model/shading-factor-table.html Kind regards
  5. Dear Caio, Thank you for the suggestion. I will add it to our software development roadmap, but I can't guarantee when this feature will be implemented. Regards, Muhammed Sarikaya
  6. Yesterday
  7. Is there a detailed guidance on the differences between the "fast (table)" option and the "slow simulation" option for the near shading? In order to understand possible deviance and what is best for the project. Thanks
  8. Hi! Thanks for the feedback! In fact, PVSyst already has a free drawing tool. However, even in line with my feature suggestion, I believe an upgrade to this function is still needed. Currently, the standard tool in the software can only be activated in the standard Shading Scene Construction mode. In the Building Object mode, the “Pen – Extruded Polygon” option is not available.
  9. Dear Caio, Thank you for your suggestion to improve the 3D feature in PVsyst. For your first suggestion, I recommend trying the “Pen – Extruded polygon” tool (see below). It lets you draw a complex shape on the ground plane and extrude it to whatever height you need. Let me know if this helps. Regards, Muhammed Sarikaya
  10. Indeed, I confirm that this is the case and is quite misleading… and also not consistent with how PVsyst usually works. You should not be able to keep the spectral correction checked if it cannot be used for some reason. Thanks for this feedback @LauraH
  11. The "Module quality loss" represents the confidence you put yourself in the PV module real performance. See the help https://www.pvsyst.com/help/project-design/array-and-system-losses/module-quality-losses.html?h=module+quality The "Light induced degradation" affects only the P-type wafer-based cells. It is sometimes - rarely - mentioned on the datasheets. See the help https://www.pvsyst.com/help/project-design/array-and-system-losses/lid-loss.html?h=lid The "Module Mismatch loss" depends on the real module characteristics dispersion. See the Help https://www.pvsyst.com/help/project-design/array-and-system-losses/array-mismatch-losses/mismatch-loss-due-to-modules-dispersion.html?h=mismatch NB: you have little questionmarks buttons for getting help for each of these losses, please use them.
  12. Last week
  13. Hi PVSyst Team, Can we determine these parameters with the module info alone? I'm using Jinko Solar - JKM590N-72HL4-BDV and JKM595N-72HL4-BDV/ Please show how do we come up with the values. Appreciate your help, ~Aidenn
  14. 1 - Model Pen (Building Pen) The idea is to have a free-draw mode for creating complex or unusual building shapes, with the ability to adjust the height, length, and—if possible—the curve “resolution” (i.e., the number of lines used to form curves, similar to a cylinder’s segmentation). Ideally, this tool could be integrated into the Building / Composed Object section. Personally, I’ve found it difficult to create certain shapes and structures that could be done much faster with this improvement, especially roofs. Design Suggestion: Using software like SketchUp or SolarEdge makes this process easier because they include a pen tool and are not limited to predefined models, allowing for more flexible scene composition. If this feature were implemented—considering any software limitations—it would be extremely useful to combine it with the ability to configure any roof shape based on a drawn outline, merging the best features from other tools in one place. Design Example: This tool could work in two alternative ways: Building/Object Pen – Functions like a freehand pen to draw custom shapes. Building/Object Cropper – Used only to cut or reshape predefined objects/buildings into the desired form (simpler from a general perspective). 2 - Magnetic Measure Mode This idea is much simpler than the previous one 😄. The goal is to customize the measurement tool to work faster and more accurately in determining dimensions. It could have three modes: 1. Full Magnetic Measure (Grid-Based) – Snaps measurements to whole number values (e.g., 1m, 24m, 87m). 2. No Magnetic Measure (Standard) – Works as the current free measurement tool. 3. Full Magnetic Measure (Object-Based) – Click any object edge/line to automatically display its length. That’s all for now. I’ll be back with more ideas and suggestions. I really enjoy using this software and wish the best to its developers. Thanks for your attention!
  15. By default we recommend Uv=0 as this coefficient is trickier to measure and varies even more from one PV installation to the next. There can be a large difference between the wind speed from a data provider (measured at 10m above ground, not always close by) and local conditions at the module level. But yes to be more accurate you simply need to measure this coefficients on your installation. https://www.pvsyst.com/help/project-design/array-and-system-losses/array-thermal-losses
  16. Thanks for respond, How about Uv? is there anyway to model it more accurate?
  17. Hi, A near shading loss of 2.8% for the system layout shown in your screenshot is within a reasonable range and you probably have to increase the pitch by a lot to see an effect on the near shading losses. The most accurate diffuse shading calculation will be obtained by using the "All trackers" option, as in your current example. For an exercise to better understand the impact of diffuse losses, you can instead select the "Custom tracker" option and choose a set of tables located at the very edges of the system. This option calculates shading only for the selected tables, then applies the same shading pattern to the rest of the system. If you run the simulation with "Custom tracker" selected for tables that have fewer surrounding obstacles, you should observe a decrease in near shading losses. Note that this method is only for testing and exploring the effect of table placement on diffuse shading—it is not the recommended approach for an accurate production estimate.
  18. Hello Linda, Thanks for the prompt response. I tried doing it and increased pitches, but shading loss didn't come down. Could you elaborate more on this please?
  19. Good Afternoon, I'm just raising this topic again ; if possible to have a feedback from PVsyst support, at least a simple "yes or no" would help 🙂 Thank you, Best regards, David
  20. Hello, If you have no shading object or topography and have activated the backtracking, the near shading losses likely stem from the diffuse shading. The diffuse shading definition for trackers can be found in the Near shading window, Tools, Tracker diffuse shading definition. By for instance increasing the pitch, the diffuse shadings will be reduced.
  21. Hi Experts, I was trying to run a single axis tracker model with bi-facial modules. I have created the 3D scheme and no shadings are considered from surrounding buildings / obstructions and enabled the back tracking. Still in the results I am seeing 2.8% near shading loss. What could be the reason? Can someone help me out please. Thanks in advance, Job
  22. I am currently working on simulating a system involving energy storage systems, and I am wondering about the capabilities of PVSyst for modeling storage technologies beyond the typical lithium-ion and lead-acid batteries. Specifically, I am interested in the following: Electrochemical storage systems: Nickel-Hydrogen batteries Flow batteries Mechanical storage systems: CO2 batteries or similar technologies Could you please confirm whether PVSyst supports the modeling of these types of storage systems, or if there are any plans to include such models in future updates? If not, could you suggest any workarounds or integration methods that might allow for their inclusion in hybrid system simulations alongside PV modules?
  23. Hi When I run large batches (many simulations) PVSyst runs for a few hours then suddenly closes without an error dialog. I’ve tried smaller batches without problems and monitoring Task Manager but can’t find a clear cause (like memory spikes). Any suggestions on logs to collect, known bugs, or settings to stabilize long batch runs? PVSyst Version: 8.0.14. OS: Windows 11 (full updated). RAM: 16 GB. Thanks in advance
  24. Hi, The idea behind the unlimited sheds field type, is to allow for simulation of the shadings without the complexity of the 3D scene. Thus you are always simulating the mutual shading between the rows in a 2D representation (compared to the 3D scene). One simplification with this 2D representation is that the edge effect is neglected, that the rows are unlimited long. The number of sheds are important to define since the first and last row does not have the same shadings as the rest of the rows. Thus if you have 5 rows, 4 of the rows experience mutual shadings. If you have 500 rows, 499 rows will experience mutual shadings and thus this will impact the simulation results. Note that the unlimited sheds always include mutual shadings. To run a simulation completely without shadings, you should define fixed tilted planes and not define a 3D scene (though you can then define a bifacial project since the pitch and table size are needed for the bifacial calculation). You can read more about the unlimited sheds in the following help page: https://www.pvsyst.com/help/glossary/3d-editor/shed.html?h=unlimited+sheds
  25. Hello, I am running simulations in PVsyst for both monofacial and bifacial modules using the unlimited sheds configuration to avoid performing a shading scene simulation. I noticed that even when I keep the same spacing between sheds and only change the number of sheds in the layout, the simulation results (energy production and PR) still vary. I had assumed that in unlimited sheds mode, with shading simulation disabled, the number of sheds would not affect the results since the geometry is considered infinite in the transverse direction. I would like to better understand the logic and assumptions PVsyst uses regarding the number of sheds parameter, and why it impacts the results for both monofacial and bifacial modules. Thank you in advance for your help and clarifications. Best regards, Raouane Laila
  26. Earlier
  27. Hi Zahra, PVsyst has only one temperature model as described here: https://www.pvsyst.com/help/project-design/array-and-system-losses/array-thermal-losses/index.html?h=temperature#thermal-model Our recommendation is using Uc = 15 W/m²·k for modules with a fully insulated backside (eg. PV roof tiles). But BIPV has a very wide range of PV designs so no we do not have recommendations for BIPV in general. If you import cell temperature measurements they will be used directly in the simulation insteand of using the temperature model. For the long tem losses, the degradation factor is applied to Imp/Vmp. The one diode model is fitted again to compute the IV curve of the modules and these are used in the simulation. The mismatch factor on the other hand is an effective correction. Individual modules are expected to degrade at slightly different rates, hence increasing the mismatch losses over time. For each module, a degradation loss is drawn from a gaussian distribution (defined in the ageing tool). The modules are assumed to degrade at that rate over the years an the mismatch factor is computed from that. The mismatch factor is added to the array losses. Unfortunately, we do not have white papers describing these 2 points, only the help pages.
  28. Hello PVsyst community, I am working on a research project focused on the long-term aging and performance degradation of Building-Integrated Photovoltaic (BIPV) systems. To accurately model this, I need a more detailed understanding of PVsyst's internal calculations. I have already reviewed the official documentation, but I have a few specific questions that I'm hoping for some clarity on: Temperature Modeling for BIPV: I understand that PVsyst does not have a detailed building model for BIPV. The documentation suggests importing a custom temperature time series. Could you please provide more insight into the specific equations used in the internal thermal model for BIPV (or non-ventilated modules)? For example, are there any specific heat transfer coefficients or thermal resistance parameters that can be adjusted to better simulate the higher operating temperatures of BIPV modules? Losses and Aging Equations: I need to understand how the software models long-term performance losses. Could you elaborate on the mathematical models or equations used for Thank you in advance for any documentation, white papers, or detailed explanations you can provide. Your insights will be invaluable to my research.
  29. Dear Zahra, For a stand-alone project, which is generally small and simple, we don’t represent the inverter, because the main focus is to understand how the PV modules, along with the batteries, will meet the users’ electricity needs. This is why it’s not possible to define an inverter with specific parameters for each MPPT in such a project. For your first question: No, this is not possible in PVsyst. The software does not allow you to input pre-calculated PV production as an input. In a stand-alone system, you must define the PV fields, and PVsyst will calculate the production based on those components. For your second question: Could you tell me which parameter you would like to modify? Regards,
