Luca Antognini started following Arev factor of BC modules in string level simulation
Dear Jianguo Chen, Thank you for your feedback. I share your understanding : both dialogues, with those parameters, should lead to the same results. For me the correct plot is your top screenshot, from the menu "One shaded Module". I noted that this problem seems to happen only with "Twin-half-Cut" module: If I select a "In length" module, both dialoguess give me the same results I think therefore there is a problem with the calculation of the electrical layout in this specific dialog. I will create an issue to investigate it further and fix this problem in a future version. - Yesterday
Andreacuellar26 joined the community
Pramod joined the community
Mikael joined the community
Andy T. Baraka joined the community
