gonecrawfishin Posted August 3, 2017 Posted August 3, 2017 Hi,Does anyone know the exact definition of the following: - Pitch (spacing plus height of the modules, or projection of such to the ground base on tilt?)- Coll. band width (height of the modules or projection to the ground based on tilt?)- Top/bottom inactive band- Ground area occupatino ratio, or A(coll) and A(ground). It seems this is not equivalent to "ground cover ratio", an NREL term, correct? GCR is a comparison of horizontal projections, whereas GAOR seems to compare lengths at different angles? Anyway, a graphic in the help section would be useful. I'm trying to guess based on the little graphic but it's hard to really tell.-Jen
dtarin Posted August 3, 2017 Posted August 3, 2017 Pitch: Post to post distanceColl. band width: width of the modules regardless of angle, i.e. if two in portrait, coll. band width is length of module * 2 + spacing between modulesInactive band: distance the underlying structure extends past the module area. Often times this is zero. GAOR: collector width/pitch
AHSAN ALI Posted December 1 Posted December 1 Is no of sheds affected the performance, what means by no of sheds, plz elaborate
Linda Thoren Posted December 1 Posted December 1 Yes the number of sheds will have an impact of the performance, considering that the first and the last rows are not accounted for in the same way, since they will not experience the same shading patterns as the tables in the middle of the system. When there are many rows, this difference may be neglected. You can read more about the impact in the following help page: https://www.pvsyst.com/help/project-design/bifacial-systems/bifacial-systems-nbofsheds.html?h=number
AHSAN ALI Posted Sunday at 03:02 PM Posted Sunday at 03:02 PM Can we simulate in unlimited sheds orientation, elevated structures or ground mounted only, but if ground mounted only then can we simulate L2,L3 structure in this, because in orientation we can only give pitch, collect band width (What is this?). No of Sheds also, but If I've a wide roof can I only install a single panel in unlimited rows I can select panels in front row more than one and also behind the rows then how to calculate or simulate, shading angle, collec band width etc.I can't understand bcz I want to install a 10kW system of 645W panel, but I give 16 no of sheds bcz of unlimited sheds, how can I reduce the qty of sheds bcz I want to install 8 panels in 1st row and 8 in 2nd and that's all, but how will manage
Michele Oliosi Posted 21 hours ago Posted 21 hours ago @AHSAN ALI An important point here is understanding what "shed" means. A "shed" in PVsyst is one row of PV tables in a row arrangement. A "shed" is not the same as a module: Because one table may have several PV modules. Because one row of tables has several tables in it. In the diagram of the "Orientation" window, you can see three (generally) such rows depicted in blue. This is a cross-section or side view of the row arrangement. This also means that the size of the tables is what you will enter in the parameters "coll. band width" and "top/bottom inactive bands". What matters is the vertical size, in other words the "height" or "width" depending on your perspective, but usually the short side of a table. The "Orientation" window is not where you will define the total number of modules. Here only the geometry matters. The "System" window is where you will define the number of modules properly. In your example with 8 + 8 modules, you should define "Nb. of sheds" as 2.
AHSAN ALI Posted 4 hours ago Posted 4 hours ago Okay, good, but when panel install in portrait then collect band width is the length of panel and when panel install in landscape then collect band width is the width of panel. Is I'm correct? These Panels are installed in Portrait orientation and you suggest others if landscape orientation, and also tell that If I want to simulate this structure in unlimited sheds and pvsyst, because 2 panels gaps for albedo and air circulation , and there is no option in pvsyst that we select 23 panels, whatsever 1st guide about the collbandwidth of portrait and landscape, according to my suggestion when portrait then we take panel length and when landscape then we take panel width as collect band width, plz guide
