nickSHIFT Posted January 13, 2017 Posted January 13, 2017 (edited) I have produced a few Tilt VS PItch scans, which are very helpful, but the units don't specify a time scale. EG: in the attached scan, maximum of 624MWh is produced, but over what period of time? My annual production is about 2200MWh.Is the 624MWh representing an average or total?It doesn't seem to fit with daily or annual numbers.Thanks.*Edit* I think this is possibly a glitch or it is missing some digits. Andre can you weigh in on this please? Edited February 1, 2017 by nickSHIFT
dtarin Posted January 20, 2017 Posted January 20, 2017 I am also curious to know the answer to the question above. I also have a question regarding this same feature, so I hope you dont mind me piggybacking on your post. I ran a parameter optimization with a tracker system varying pitch, and the result does not give me different energies based on the pitch. Is this feature properly working for tracker systems?
dtarin Posted January 20, 2017 Posted January 20, 2017 I have produced a few Tilt VS PItch scans, which are very helpful, but the units don't specify a time scale. EG: in the attached scan, maximum of 624MWh is produced, but over what period of time? My annual production is about 2200MWh.Is the 624MWh representing an average or total?It doesn't seem to fit with daily or annual numbers.Thanks. While I cant answer your question, I did notice that when I go to 1-D, it shows the proper yearly production.
nickSHIFT Posted January 30, 2017 Author Posted January 30, 2017 I ran a parameter optimization with a tracker system varying pitch, and the result does not give me different energies based on the pitch. Is this feature properly working for tracker systems? I believe so. I think your pitch spacing at 5m is already large enough to not have any shading. Run it again from 1 to 5m and you should see a curve of some sort.
nickSHIFT Posted February 23, 2017 Author Posted February 23, 2017 For those interested, A work-around is to find the User Optimization File or use the Batch Simulation mode, and manually plot the data in MS Excel. :)
Bruno Wittmer Posted February 24, 2017 Posted February 24, 2017 There is an error with the units display. Although the label reads MWh, the values are in GJ. There is a factor of 3.6 between the two (1MWh = 1MJ/s * 3600s = 1GJ * 3.6).I will fix the error and post from which version on the fix applies.A comment on the work-around proposed by nickSHIFT: You can also retrieve the results from the Optimization tool in Excel. They are stored as CSV files in the PVsyst workspace in the subdirectory 'UserOptimization'. The file names are constructed from Project name, Variant Id, Scan Name and a counter. In those files, the energies are given correctly in kWh.
dtarin Posted February 28, 2017 Posted February 28, 2017 There is an error with the units display. Although the label reads MWh, the values are in GJ. There is a factor of 3.6 between the two (1MWh = 1MJ/s * 3600s = 1GJ * 3.6).I will fix the error and post from which version on the fix applies.A comment on the work-around proposed by nickSHIFT: You can also retrieve the results from the Optimization tool in Excel. They are stored as CSV files in the PVsyst workspace in the subdirectory 'UserOptimization'. The file names are constructed from Project name, Variant Id, Scan Name and a counter. In those files, the energies are given correctly in kWh. It would be nice if the units were included in the column header.
Bruno Wittmer Posted March 8, 2017 Posted March 8, 2017 The wrong unit display has been fixed for PVsyst Version 6.60.
Soldnerkugel Posted July 5, 2017 Posted July 5, 2017 Currently I'm using PVsyst Version 6.45, but I cannot find the "Parameter Optimization Tool".Where can I find it? or is it available only in higher versions of PVsyst?
Pnom Posted March 8, 2022 Posted March 8, 2022 While trying to use the optimization tool, I have encountered the following problems:1. In some projects, there are only 2 optimization parameters(azimuth and tilt). I wish to carry out out other optimization like pitch optimization.2. The scan aborts after a few seconds with an error message "The scan was aborted by the user"Anyone with an idea on how to solve the above?Thank you.
Aaron3707 Posted August 17, 2022 Posted August 17, 2022 On 3/8/2022 at 12:18 PM, Pnom said: While trying to use the optimization tool, I have encountered the following problems: 1. In some projects, there are only 2 optimization parameters(azimuth and tilt). I wish to carry out out other optimization like pitch optimization. 2. The scan aborts after a few seconds with an error message "The scan was aborted by the user" Anyone with an idea on how to solve the above? Thank you. Hi guys, I am also facing a similar issue, where the scan aborts saying it was aborted by user when that is not the case. Anyone have any ideas on what could potentially be the issue?
jacob Posted March 8, 2023 Posted March 8, 2023 Same issue here. I was running a scan to optimize the tilt of a project. It kept aborting. I have no idea why
Thanida.Ch Posted February 5, 2025 Posted February 5, 2025 I have a question about optimization tool in prayer as well. I tried to vary tilt, pitch and/or height, the result show only maximum value. And when I change the range of parameters, the maximum value also change. So please help for following; 1. How to show graph and trend of both 1-D and 2-D ? 2. Why maximum value is changed according to difference range?
Michele Oliosi Posted February 6, 2025 Posted February 6, 2025 You seem to have defined only one iteration step ? As a consequence, you cannot have any trends. You need to increase the number of "steps" to evaluate the simulation over a scatter of parameter space points.
