Everything posted by Nils Lang
				Cannot see any component from component database
Nils Lang replied to gayatri's topic in Problems / Bugs
Dear Gayatri Patil, The content of the "Availability" box is unexpected in all your screen captures. May be your installation is corrupted. Please perform the following repair actions: 1. Restart your computer 2. Uninstall PVsyst, then download it again from our web site ( https://www.pvsyst.com/download-pvsyst/ ) and re-install it. If the problem persists then please email your PVsyst LOG files at: support@pvsyst.com Best regards.- 1 reply
- components
 - database
					(and 1 more)
Tagged with:
				PVSyst freezes when trying create an array fo trackers
Nils Lang replied to Cyrus Titina's topic in Problems / Bugs
Dear Cyrus Titina, Please send us your PVsyst LOG files (using menu <File> <Export logs>) and your PVCASE file so we can try to reproduce the issue you reported. Our email adress is: support@pvsyst.com Best regards. -
				Problema para gerar relatórios após simulação
Nils Lang replied to Alessander's topic in Problems / Bugs
Dear Alessander, It looks like PVsyst is freezing when it uses your computer graphic card driver. Please email us your PVsyst LOG files (using menu <file> <Export logs>) so we can have a deeper look. In the meantime, you can already try to update your graphic card driver by following the procedure documented in our FAQ: https://forum.pvsyst.com/topic/1253-updating-your-graphics-card-driver-pvsyst-660-and-above/?do=findComment&comment=3402 Alternatively, you can try to run PVsyst with another graphic card driver of your PC if you have one. This selection is available in Windows settings (in Graphics settings) after you have chosen PVsyst program file: I hope this will help you to resolve this issue. Best regards. Nils Lang PVSYST SA - Technical Support -
	Dear Irakli Bezhuashvili, Please email us at support@pvsyst.com your PVsyst LOG files (menu <File> <Export logs>) so we can analyze the issue you reported. Best regards.
	Dear Frederic Juanico, Please read our related FAQ: https://forum.pvsyst.com/topic/2524-web-services-for-all-pvsyst-functionalities/?do=findComment&comment=6420 Best regards.
	Dear Kahoula Rahrah, In order to investigate the issue you reported, we would need the log files that PVsyst generated on your computer. For this, please follow the following steps: - go to menu Files > Export Logs - check if the Export path is convenient for you, if not choose another place to save your log file with the "Browse" button. - click on "Export" button (your zip log file will be save where it is indicated at Export path field) - attach your zip log file to your email and send it to us at the following address: support@pvsyst.com Best regards.
				PVSyst crash when try to generate report
Nils Lang replied to roberto.bissanti's topic in Problems / Bugs
Dear PVsyst user, If you are running PVsyst on a virtual machine hosted by a MAC then please read our related FAQ: Best regards. -
	Dear Ricardo Moreno, In order to investigate the issue you reported, we would need the log files that PVsyst generated on your computer. For this, please follow the following steps: - go to menu Files > Export Logs - check if the Export path is convenient for you, if not choose another place to save your log file with the "Browse" button. - click on "Export" button (your zip log file will be save where it is indicated at Export path field) - attach your zip log file to your email and send it to us using our support address: support@pvsyst.com Best regards.
	Dear PVsyst Users, In case of error, please press the <Send bug report> button of PVsyst error dialog and send us the prepared email (including the attached files) to our support address: support@pvsyst.com so we receive all the information needed to analyse the crash. Best regards.
	Dear Michalis Angeli, At this point, you should press the "Send bug report" button and send the prepared email to support@pvsyst.com. This message contains all the information we need to analyze what happened. From your screen capture, I can already tell you that the error you reported is most probably a known issue for which we have planned to publish a correction as soon as possible. Sorry for the inconvenience and best regards.
	Dear Nina Lindholm, Thanks for your error report. Please email to our support address (support@pvsyst.com): 1) your PVsyst LOG files (using menu <File> <Export logs>) and 2) your PVsyst project files (using menu <File> <Export project>) so we can try to reproduce the issue you reported. I’m looking forward to hearing from you. Best regards.
				PVSyst freezes before starting a batch simulation
Nils Lang replied to yildizipekci's topic in Problems / Bugs
Dear Yildiz Pekci, Thanks for your detailed error description. In order to help us to try to reproduce it, please email us your batch CSV file and the files related to your project at our support address: support@pvsyst.com Note that you can easily export them in a ZIP file using Pvsyst menu <Files> <Export projects>. I'm looking forward to hearing from you. Best regards. -
	Instead of restarting PVsyst, you can refresh your databases using menu <File> <Refresh databases>. You can also directly import your inverter file in PVsyst using menu <File> <Import components> <Import components from a folder>. You can find more detailed information about this command in PVsyst help: https://www.pvsyst.com/help/index.html?file_import_projects_and_components.htm Best regards.
	Dear Andreza Maranhão, You should get the same results. Please email us at support@pvsyst.com: 1. Your PVsyst LOG files (menu <File> <Export logs>) 2. Your project files (menu <File> <Export projects>) so we can analyze and try to reproduce the error you reported. Best regards.
Dear Jackson White, Please check for updates the other software components you are using on your Mac. You should verify first hand that you have the latest macOS update installed. You can also have a look at: https://kb.parallels.com/128970 You can also try the Windows Compatibility Troubleshooter on ARM : https://learn.microsoft.com/en-us/windows/arm/apps-on-arm-program-compat-troubleshooter You should also read Parallels Desktop KB about: Limitations of running Windows 11 on Apple M-series Mac computers in Parallels Desktop for Mac Finally, please keep in mind that we cannot guarantee that the virtual machine you are using emulates correctly all the Windows functionalities PVsyst is using. Best regards. -
				I am using PVsyst 7.0.15 and I am getting an error
Nils Lang replied to waltergarcia's topic in Problems / Bugs
Dear Walter Garcia, You can start by updating PVsyst. The list of corrections is available in our release notes: https://www.pvsyst.com/release-notes/ If you can still reproduce the error after the update then you should send a support request to: support@pvsyst.com attaching to your email your PVsyst LOG files (menu <File> <Export logs>). Best regards. -
				Problem with Direct Import of PVGIS SARAH2 data
Nils Lang replied to Declan's topic in Problems / Bugs
Dear Hughes Declan, Maybe this service was temporary not available. If this error persist then you may have an issue with your security settings not allowing PVsyst to access this web service. Please read our related FAQ: https://forum.pvsyst.com/topic/2524-web-services-for-all-pvsyst-functionalities Best regards. Nils -
	Dear Carl, Please send us also to our support address (support@pvsyst.com ) : 1. Your PVsyst LOG files (menu <File> <Export logs>) 2. Your project files (menu <File> <Export projects>) so we can analyze and try to reproduce the error you reported. Best regards, Nils
				Interactive Map coordinates don't identify Portugal as a country
Nils Lang replied to dfialho's topic in Problems / Bugs
Dear User, Please email a support request for this issue at: support@pvsyst.com with your PVsyst LOG files (menu <File> <Export logs>). Best regards, Nils -
	Dear PVsyst User, Please send an email to: support@pvsyst.com with your PVsyst LOG files (using menu <File> <Export logs>). Best regards.
	All PVsyst V7 versions are now available for download using the following link: https://www.pvsyst.com/previous-versions/
	Please remind that the elements under recent files are shortcuts. You can also load your projects using button <Grid-Connected> then the Project <Load> button. Note also that you can find more detailed information on how to operate PVsyst in the Help at: https://www.pvsyst.com/help/ under topic <Project design> <Project definition>. Best regards.
	In this case, you should email us a support request at support@pvsyst.com with your PVsyst LOG files (menu <File> <Export logs>) so we can analyze what happened. Best regards.
	Please read the related entry in our FAQ using the following link: https://forum.pvsyst.com/topic/2524-web-services-for-all-pvsyst-functionalities/?do=findComment&comment=6420
	Dear Raul, Pvsyst is not designed to read files from a later version (the same way as Excel 97 – 2003 cannot read .xlsx files). You can always read all Pvsyst file formats when you use the last version of Pvsyst but there is no guarantee that you can read new files using an old Pvsyst version. The file format has mainly evolved between version 6 to 7 to support new features. It has also changed between 6.79 and 6.80 to support international characters (utf8). Here is a reminder of the files format evolution copied from PVsyst help: Up to PVsyst version 6.39, all PVsyst files (project, variant, meteo, etc.) were saved in binary format and it was not possible to read or edit those files. Starting with PVsyst version 6.40, the format of all PVsyst files has changed to text. This new format will simplify PVsyst upgrades. Starting with PVsyst version 6.60, the format of PVsyst project version (VCi) has been improved. Starting with PVsyst version 6.80, the encoding of all PVsyst files (*.PRJ, *.VCi, *.PAN, *.OND, etc.) has changed to UTF-8 to support international characters. For each of these evolutions, the new formats are incompatible with older versions. This is the reason why the corresponding workspaces have different names (PVsyst6_Data, PVsyst640_Data, PVsyst660_Data, PVsyst680_Data, PVsyst7.0_Data). You can find more detailed information in PVsyst help: https://www.pvsyst.com/help/ in topic: Technical aspects > File organisation > User data For the specific case of PV modules and inverters files, PVsyst V7 has a saving mode compatible with old versions: Best regards.
