popog21704 joined the community
- back-contact
- bc
- (and 5 more)
SAMET joined the community
EnriqueC joined the community
mohomar.qaid joined the community
- grid power limit
- power factor
William.F joined the community
thanks!
There is a known issue where the total AC power in the report is not accurate with SolarEdge subarrays. This is due to the way the total is computed in the report, based on individual MPPT powers. With SolarEdge and its specific way to attribute (and distribute) strings to inverters, the computation is sometimes incorrect. This issue is on our roadmap, but as it does not impact the simulation results, it has been scheduled for a later version. -
