Farid joined the community
MassimoAEC joined the community
The precipitable water data is used to estimate spectral corrections in some cases. https://www.pvsyst.com/help/project-design/array-and-system-losses/spectral-correction.html?h=spectral#first-solar-spectral-correction-model-management If that data is not present in the weather input, relative humidity is used instead. This warning is more of an information. - Last week
Raghu_Ram joined the community
LVG joined the community
- near shading 3d scene
- orientation
- 1 reply
- orientation
MinkeK joined the community
