Farid joined the community
MassimoAEC joined the community
Raghu_Ram joined the community
LVG joined the community
- near shading 3d scene
- orientation
- 1 reply
- orientation
MinkeK joined the community
I received a shading scene in which all of the trees are included as a single ground object. This seems like an incredible way to represent many trees as one object. They do seem to throw shade. Q: If trees shouldn't be included in the ground objects, why are those options given for a PVC import? It looks like the tops of the trees will be considered the ground if you select the first box. Nevertheless, individual trees are depicted in the shading scene. Second screen shot shows that no trees are included in the object list. Thanks.
