  2. Yesterday
  3. I am seeing difference of 0.15% in 8.0.12 which is non-trivial. Aging tool on top, PVsyst report result on bottom.
  4. Useful Out and Egrid are the same. I suggest including InvOut It seems IL Pmax will include grid limitation loss when there is a limit applied in the IL Pmax figure, even if it is set to account for loss separately under energy management. I suggest quantifying IL Pmax as its defined in energy management, or by default include POI loss as a separate value, and let users add together if they want. EArrayMPP is more useful than EArray, I recommend adding it or replacing EArray with it.
  5. PVsyst doesn't output 8760 files past year 36. It will complete the simulations and generate the pdf report, but not the excel output. v8.0.12
  6. Last week
  7. Simulate with as few trees as possible. Take into account things like the total elevation at the top of the trees (tree height + ground elevation) and the distance relative to the panels.
  8. export simulations to excel. output the variables you need and analyze from there.
  9. This doesnt look off but not enough info here. The difference between 100m and 50m is .07%. Between 8.5m and 50m, energy plateaus. Since you havent included those simulations, it looks linear there.
  10. Hi, I would suggest looking at more variables. I strongly suspect that the dominant loss factor is the losses on the diffuse component. These will have a less sharp decrease than other losses, especially in the case of backtracking, which zeroes-out the direct shading losses. You can take a look at ShdDLss and ShdALss.
  11. Dear Carlos, I don’t recommend importing a detailed 3D forest file into PVsyst. The more detailed the 3D scene is, the longer it takes to calculate the shading impact on the PV tables. For the horizon line, you can already import the mountain line in PVsyst using the horizon feature. In the 3D scene, if there is a forest at the edge of your terrain, I suggest drawing a wall to represent the last row of trees. Regards,
  12. The Voc does not change very much with irradiance. At -10°C, going from 1000W/m2 to 500 W/m2 will change the Voc only around 2%. The irradiance chosen for the worst case scenario is not necessarily the one when the inverters perform a regular self-check in the morning. It could happen that the DC is connected at a time when there is already a significant irradiance, but the ambient temperature is still low. There are two settings in PVsyst that will control the check of the maximum array voltage: In the project settings it is possible to set the temperature at which the check will be performed. If the single diode model parameters in the PAN lead to a temperature coefficient for Voc that is larger than the one specified by the PV module manufacturer, it is possible to introduce this value in the PAN file, and then in the project settings tell PVsyst to use that coefficient instead of the single diode model calculation.
  13. Dear JNutter, It’s difficult for us to understand why you are encountering this issue. Could you please send us your project at support@pvsyst.com so we can examine it? Also, please explain the issue in your email. Regards,
  14. Dear Andrés, Can you please send us your .ond file at support@pvsyst.com so we can examine it? Also, could you explain your issue in your email? Regards,
  15. Dear Alex, Is it possible for you to send us your project at support@pvsyst.com so we can test it and compare the results between V7 and V8? In your email, could you also explain the procedure you followed that led to these differences? Regards,
  16. Hello, do you still experience this issue? It seems the grid square size is huge (500m). Can you please zoom in untill you get 1m ?
  17. Hello, A floating system is rather similar to a conventional PV system. Following forum post describes how you can adapt your simulation to a floating PV system: To start a PVsyst project, we have several tutorials in PDF and on youtube: https://www.pvsyst.com/wp-content/pdf-tutorials/pvsyst-tutorial-v8-grid-connected-en.pdf
  18. Hi everyone, I’ve run into something odd in PVsyst and I’m hoping someone can help clarify what’s going on under the hood. The situation: I’m using an inverter “.OND” file supplied by the manufacturer. In both the Main Parameters and Output Parameters tabs, the inverter’s Maximum AC Power is listed as 1265 kW (at low temperature, so no derating). However, when I look at the DC-to-AC performance curves (DC input power vs. AC output power), the data only go up to 1100 kW—which is the nominal power rating. My questions are: Which number does PVsyst actually use when simulating maximum AC output? Does it honor the 1265 kW value from the parameter tabs, or is it capped at 1100 kW based on the performance curve data? If PVsyst does cap the AC output at 1100 kW, is there a way to override this (e.g. by editing the curve or adjusting settings) so the full 1265 kW is available under ideal conditions? I appreciate any insights or experience you can share—thanks in advance!
  19. Sorry, no progress in the present time.
  20. Background: I built a simple single inverter model to investigate energy vs tracker row spacing. In all cases, I kept the array consistent and only increased the tracker spacing in increments of 0.25M. I expected to see that annual energy would plateau at some point and not increase, indicating the MAX optimum space. There is more to my analysis but, this is the background for the issue at hand. As I increased from 6 through 8.5 meters, energy continued to increase. I then jumped to 50 meters and the trend continued! Similarly, I used 100M and the results continued to climb. I have no HV transformer or other losses and the consistent system definition below:
  21. Dear Ishan, Real sorry, your question is taking some time to answer. Unfortunately, there are some details that need to be understood. We are trying to provide as informed an answer as possible. We should be able to reply by the end of the week.
  22. Hello, Yes, the zone tool will be improved in a future version. In the meantime, by defining a fixed tilted plane with the all the parameters you wish for your trackers (orientation, pitch, size etc.) and tick the option "Create tracking fields" (as you have done in image 4), the zone will be filled with trackers with the correct definition.
  23. OK,thanks!
  24. Thank you for the reply 🙂 Regarding your answer, I would like to have a better understanding on how to apply your procedure in order to visualize and quantify the shadowing impacts of turbines. First, I get that I shall generate two simulation variants one with and the other without them and from the two loss diagrams see the corresponding near shadings and electrical losses. In order to calculate those losses in MWh, if I understand correctly, I should multiply the energy production values with the near shading and electrical losses expressed in %. Am I right? Secondly, in order to calculate the overall energy impact on different timeframe basis (monthly, daily...) I would like to understand if there is a way in PVsyst to extract the production values with respect to such timeframes. Did you have in mind another way to compute and identify those losses ? Thank you.
  25. Dear Sarikaya, I am still awaiting the response on the above topic for the project files emailed on multiple occasions at support@pvsyst.com.
  26. Losses due to specific objects are not isolated. Shading from turbines will be included in both near shadings and electrical loss in the loss diagram. To isolate the turbines run models with and without them, take the delta of shading losses and you can calculate whatever you need. You will also have energy with this, so you can easily calculate overall energy impact monthly, etc.
  27. we will need cobiner boxes
  28. Hello Johann, The simulation and corresponding energy balance are calculated using hourly time steps. To determine how much of the generated solar energy can be self-consumed, the simulation must be run. For example, in the DEMO project “DEMO Commercial Installation at California” (VC3), the report shows: E_User: the total energy delivered to the user (reflecting the self-consumption profile), E_Solar: the portion of E_User that is covered by solar production, EFrGrid: the remaining energy that must be imported from the grid to meet the user's demand, E_Grid: any excess solar energy that is injected into the grid. These values are also illustrated in the annual loss diagram, giving a complete overview of the system’s performance over the year. Best regards
