Everything posted by dtarin
abdulrahman95 , Is this what you mean by curved suface? You can create a ground object which matches the terrain, then create a zone of tables/modules on top of the ground object, and then select position tables on scene. This doesnt work for every PV field (ie tracker).
The measuring tool was modified in the newest release, and I think it is now missing one of the most useful features. It does not lock onto objects in the same manner as before, such that when you snap it to two corners and move one of the objects, it does not stay locked and show you the distance as it changes. Placing objects around the array or setting the pitch for PV sheds/tables make use of this now missing feature.
Hello, Is it possible to modify the module type for more than one PV table at a time? Selecting multiple and pressing ctrl+m to modify does not work for me. For complex array layouts with many independent sheds, this is a very tedious task. Using 6.6.1. Thank you.
I have also had an error in 6.61 importing ground images. The image covers up the array, but does not cover objects like trees or buildings.
It would be nice if the units were included in the column header.
single axix tracker // electrical losses acc. to strings
dtarin replied to Stefan Albrecht's topic in Problems / Bugs
I have seen older versions of PVsyst project higher losses compared to newer versions when running the same project. -
Hi Andre, The PVsyst help section states, "...you should be aware that the resulting simulation will not be valid for the first production year..." Could provide some additional information or explanation on why the light-soak gain is not valid for first year energy? I was thinking it might have to do with the time it takes to stabilize, but would like to hear from you on the matter. Thank you.
Hello, According to this page, http://forum.pvsyst.com/viewtopic.php?f=20&t=1594, it states, "...Now it is often believed that when the bottom cell row is shaded, the by-pass diodes will limit the electrical loss to the sub-module row, i.e. the string electrical production will remain 2/3 of the normal production. This is only true (about) if you have one only string per MPPT (violet curve)..." With microinverters, we have one module/string each with its own MPPT. Is it correct then to create the partition size in the shade scene based on the submodule size, as in for a single module, creating three strings in height x 1 in length?
Thank you for the reply. The help does not provide much guidance in determining this weight factor. I am more concerned with how and when to utilize the according to module method for calculating shading losses. I cant seem to get an answer on if it is the most accurate method to estimate shading losses, or if it is something else. If the according to strings method is the upper limit, is the according to module layout the lower limit, and the best estimate somewhere in between?
Is using the method you described above a reliable or accurate method to generate global incident energy for multiple orientations? I have sites with multiple orientations but only 1 weather station, so I am curious to know if this can be used to create a simulated POA for system performance testing for multiple orientations.
Using different sized modules for expansion projects
dtarin replied to karaokemasta22's topic in How-to
Thank you for the reply, that was my guess for approaching the implementation (hadnt gotten to trying it out). As for your comment on overproduction, I cant think of a way to test or benchmark this. Perhaps Andre or someone at PVsyst with a better understanding of what is happening could comment on this. -
There is a setting in hidden parameters you can set to get rid of this error, so your 1MW block can be used for a 100MW plant. See attached.
How accurate is this method - creating a dummy multi MPPT device? I have a PE inverter which is being spec'd with two different modules, but does not have the multi mppt capacity. How do you size the number of MPPT inputs when doing so, is it just arbitrary? -
Andre, Do you have any comment on why there is at times a large difference between the according to module layout and according to strings method, and which is the most accurate method of approximating shading losses? I have rooftop systems where the according to strings method projects shading losses 1.5% to 2.0% higher or more compared to according to module layout. For an entire portfolio, this is significant. I have read elsewhere about running both methods: 100% elec. effect according to strings and module layout, finding the ratio between the two, and using that as the new electrical effect. Is this the proper method for utilizing the according to module layout method? Am I misunderstanding the use of the according to module layout method as a standalone method for calculating shading losses?
Inside the ZIP file is the MEF file. You will need to extract that into the meteo directory. You will need to have a site created first for your location. Then you will go to Import ASCII meteo file, under ASCII source, select your PSM weather file, change your names if necessary under "Hourly file to be created", and under conversion, select the MEF file (I have named it NREL PSM 5, but you can rename it to anything), click start conversion. You will want to see 1990 grayed out in reference year. After you convert, view the meteo file and check the quality. You will most often need to implement a time shift. Re-run the conversion by adding the time shift by opening the conversion template and entering the shift under the date tab. Sorry if this was very brief or repetitive.
While I cant answer your question, I did notice that when I go to 1-D, it shows the proper yearly production.
I am also curious to know the answer to the question above. I also have a question regarding this same feature, so I hope you dont mind me piggybacking on your post. I ran a parameter optimization with a tracker system varying pitch, and the result does not give me different energies based on the pitch. Is this feature properly working for tracker systems?
I have selected module layout, and a particular attribution method. It seems that for a specific section of the array, the attribution method changes. In the image provided, the bottom 3 rows are properly filled according to the method selected. However the top 5 rows do not follow this method. I have tried it several times, regardless of which string I start on, the result is the same. What would cause this and Is there a way to make the filling method consistent? The shade scene is 5Hx6L in landscape.
Does PVsyst take into account the frame around individual modules as area which doesnt produce power, or does it have the ability to define this region? It seems to me in most cases shed frame should be set to zero.
Here is my MEF file you can try. NREL PSM 5.zip
If I am understanding correctly, the inverter must have the MPPT share feature, and you can distribute your power that way across multiple arrays. For example, if the inverter has 8 MPPT inputs, and you enable MPPT share with two arrays, each array will get N MPPT inputs (whichever is the appropriate split). In number of inverters, you will select N. The chint inverter shown has three mppt inputs, so if I have one inverter and two arrays, I have to distribute the three inputs between them, and then press adjust to balance. Looking at the attached image with 15 MPPT inputs, I am specifying that there are 5 physical inverters (5*3) for this array. -
I use the module quality field in batch mode to simulate DC degradation over time. I dont get PDFs, but have a macro to assemble the csv files together into a spreadsheet.
I have a PAN file in which Pnom does not match Vmp*Imp with a discrepancy of 0.75%. The parameters match the datasheet, however. Does this have any effect on the simulation apart from calculating the performance ratio? I dont typically use it for anything, I am only concerned with specific production and the energy estimate.
What I have done is created a ground object to reflect terrain conditions (hills, slopes, etc), and then created a zone on top. When you fill the zone with modules, they will be placed onto the ground object. You may need to select "place tables on scene". If you have certain parameters to adjust like frame size and module spacing, you will want to adjust these in hidden parameters first.
