André Mermoud
  1. This is indeed not possible. PVsyst requires to ask for creating an hourly file explicitly before simulation, for avoiding filling your disk with a lot of dummy files. Now if you have several runs with different parameters for optimizations, you are advised to use the Batch mode. Here you can choose getting the hourly CSV file for each simulation. Your list of parameters is kept with your Variant file, and eventually for the next file you will create/open. You can also save it as a template, for reusing it in any other project.
  2. No, it is not possible. In the present time the bi-facial model is only useable with horizontal trackers. An extended model will not be available in PVsyst before several months.
  3. Yes of course. This is a question of averaging mode. The basic hourly values are TArray. In the "TArray" variable: we average these values over the operating periods, we get an average module temperature which has not a big meaning. In the "TArrWtd" variable, we calculate an average weighted by the GlobInc value. This averaging mode is much more significant, it is required for the evaluation of a weather-correctd PR. Therefore for these variables, only the daily or monthly averaged values are different.
  4. It is sometimes useful to read the Help ... See "Project design > Bifacial Systems > Bifacial systems procedure"
  5. No, when you are using a module with bifacial capability, it is not necessary to define a bifacial simulation. It is always possible to do a simple standard simulation: in the bifacial tool, choose "Don't use in the simulation".
  6. No, you should evaluate this by yourself. The soiling loss parameter is already extremely poorly defined (and not stable in time). Elaborating sophisticated corrections on such values doesn't make much sense.
  7. I don't know such an error, I really doubt that this can still exist in the version 6.74. Please check that your inverter is not defined with a nominal power increase up to PMax, according to the temperature (page "Output parameters").
  8. The easiest way is to open an existing similar inverter, modify the parameters according to the datasheets, and save it as a new filename. For the efficiency, you can simply define a Maximum and a EURO efficiency.
  9. Please explain what you mean by "Default hourly data storage parameters" ? Which list ?
  10. No, very fortunately Meteonorm 7.2 doesn't take an horizon into account. This kind of implementation/correction is very difficult to manage in the simulation. See How is treated the Horizon contribution in Meteo data ? However the Meteonorm Software allows to create an horizon line for your site, that you can import in PVsyst.
  11. This is now obsolete, you should put 0. In old PV systems, it was a common practice (and even a rule in some countries) of putting a diode in series with each string, for avoiding drawing current from one string to anothe weaker one. This is completely useless as the string voltages are quasi-identical, whatever the irradiance or electrical losses. Therefore the diode is never activated.
  12. Yes, it is possible since the version 6.73. Please use "Databases > Import ASCII Meteo files" and press F1 for the procedure.
  13. Sorry, there is indeed a big problem in the version 6.74 with the CSV Hourly files creation. Many variables are null, or are not available in the list. There is no workaround. Before the publication of the version 6.75, the only way for creating relevant Hourlx files is to revert to a preceding version.
  14. This limit is a safety condition for the inverter and system. The principles of the condition is explained in the FAQ "How to adjust the design temperatures ?" This is not an invention of PVsyst, it is mentioned in the IEC norms. Now you can adjust the Tmin value (minimum temperature ever measured at this site) in the project's parameters (button "Project's settings")
  15. Defining the South as 0° azimuth in the northern hemisphere, or the north as 0° azimuth in the southern hemisphere, is a choice, done in most of the software dealing with solar energy (and adopted by many meteo researchers). See our FAQ How is defined the plane orientation ?
  16. The Helios3D systems are usually defined with a baseline slope om a hill. This changes the true orientation of the plane of each table. Please see our FAQ With tilted roofs, PVsyst changes my orientation
  17. Solfocus modules have never been included in the database of PVsyst. For defining a CPV module, we have to closely work with the manufacturer, with very specific tests/measurements. This has only been done with Concentrix/Soitec up to now.
  18. When you perform a study for the forecast of a new installation, you should indeed use an average over many years. The period doesn't have much importance. Now you can get more recent data from private companies, but this will be for pay. Remember that a simulation performed with one only (measured) year - even recent - will be less reliable than an average, due to the annual variability of the meteo data.
  19. Yes sorry, this is a stupid bug in the version 6.73, which will obviously be corrected in the V 6.74. In the meanwhile, the only way for correctly defining this parameter is to revert to the previous version 6.72.
  20. If you are licensed, you can get any old version of PVsyst from our web site www.pvsyst.com. You can install several versions of PVsyst in parallel on a same machine. All of them will use the same license, and may be run independently without interactions. But be careful: if you try to read a file created by a newer version, the file may be unreadable with older versions.
  21. Yes sorry, this is a stupid but in the version 6.73, which will obviously be corrected in the V 6.74. In the meanwhile, the only way for correctly defining this parameter is to revert to the previous version 6.72.
  22. For importibng your meteo data you should use "Databases > Import ASCII Meteo files". For the calculation of GTI (usually named POA, or GlobInc in PVsyst), you can use "Databases > Meteo Tables and Graphs". Here you can get tables in hourly, daily or monthly values, with the GlobInc values ("Global Tilted Plane").
  23. For the orientations definitions in PVsyst, please see the FAQ PVsyst will not redfefine the azimuth you have chosen of course.
  24. For limiting the power, you have to redefine your inverter ".OND file with a new PNom value. There is no way in PVsyst for limiting the inverter power (as there is probably no way in your physical inverter for artificialy limiting the power !). NB: The simulation doesn't check the output maximum current. If you overcome the specified value, it is probably either because it is not well specified, or your output voltage is too low. PVsyst doesn't manage the grid voltage.
  25. The Rotation limitations are the mechanical constraints. You cannot overcome them of course. The "Phi limits" is the value for which the backtracking begins to be operational (i.e. when the mutual shadings begin). At any time, the Phi value will obviously be limited by the lower of these 2 limits. Now when the sun continues to go down, the backtracking angle will come back below 60°. You can visualize this behavior as function of the sun's position, in the "Orientation" part, "Horiz. axis Unlimited trackers".
