Swonno
Everything posted by Swonno
  1. Good morning Hizir Apaydin, Thank you for your help many time. I think I success to import topography csv file into PVSyst near shading. So at this stage, Would you mind if i have another questino? I'm sorry to bother you. Q1. I'm checking generaiton hour and those tophography affect to generation hour? or it is just for notifying the mountain range or just view purpose? and if it affects to the generation hour result, It is effecting as a near shading? (because I'm adjusting far shading now by Horizon optional feature) Q2. ground object is working differently in the shading effect? for example, if i don't change to ground object from building object that PVSyst offers, It is not working as a shading purpose? Could you explain the different effect as a generation hour affecting please? Thank you for your attention on this matter. Happy friday.
  2. @Hizir Apaydin and sorry for many questions. I'd like to check this is right clearly. in the manual importing topography, in google earth, not drwaing lines in only edges but all the inside areas as many points as possible right? this is the business project site that i'm reviewing. so is it okay like this?
  3. Dear Hizir Apaydin Hello, I really appreciate that you shared how to import topography with Google earth. I think it is based on excel file, This is the excel file that i got from Google Earth. But comparing with the manual post , I can see the differences between it and mine. I removed any other column and imported into PVSyst. But did'nt work. I think I need x,y,z basis column data but somewhere i think it was stucked and worked in a wrong way. I think the column value has to be differed but I don't know how to do. If you have an idea please let me know. Thank you for attention on this issue.
  4. Thank you for the good tips and kind explanation with pictures. I really appreciate it. I think PVSyst team are really kind. Happy Tuesday ! Auto altitude feature is really helpful when there are many pv arrays. But also setting Align to Lowest point will be adjusted same height to all pv arrays yes those are really helpful. Thanks again.
  5. Dear Muhammed Sarikaya I'm proceeding roof top solar project now, and I manually made many sets of array groups and because of this reason , i wanted to check it is similiarly right in x,y,z basis. So that`s why I posted this article. Thank you for your kindly explanation. If you don't mind would you like to introduce some comfortable feature that automatically arrange pv module based on system based capacity. especially, I'm trying to simulate on the top of the object(building, factory). If you know like more efficiently method for designing , please let me know. however I learned how to design mountain pv simulatino easily by before the post using Google map pro and designing the mountain ground object. but in roof top case , i'm not sure how people usually design. Thank you for getting attention on this. (ref: )
  6. This is really helpful! Thank you for your kind explanation. Always be happy and healthy 🙂
  7. Hello PVSyst team, How are you ? I'm trying to see the objects in an exact front side but I can't set it by moving my mouse. I think there is some feature or Is there any mistake i did? Pls give comments of this issuse. Thank you for your attetion on this.
  8. @MicheleANEHello MicheleANE, I'm looking for template feature but it seems like doesn't support this feature in this program. I would like to adjust the default datas in my project in losses especailly by the feature you mentioned. If you don't mind , Could you tell me how to access the option? I don't know where to go from the main page in the program.
  9. This is really helpful. I really appreciate it! Thank you very much! but also Thank you for the tips for designing mountain too!
  10. Hello PVSyst team, I'm trying to describe range of mountain with the So I can model mountain with the width & height. But to design degree(tilt) of the mountain with this element 4sided root, I was wondered the red box i remarked in the file i attached, I think the tilt degree is the tilt for diagonal direction based. I understand and what is the under box feature that then? Can you tell me what is this purpose for? I tried write numbers there but nothing changed so, I don't know how to use this option. Thank you.
  11. I used GPS coordinate from Google Earth but right after it was solved by using GPS coordinate from google map. Thank you for getting attention about this article everyone.
  12. Good morning everyone, I'm trying to search a site that i wanna run PVSyst with the GPS coordinate but It showed me wrong place in the map. I think I missed something, Do you have any advice to solve this problem? Does PVSyst does not support Google GPS coordinate?
