Which PVsyst Version are you using? I just tested in PVsyst 6.26 for Auckland, New Zealand, and the azimuth -135° gives, as expected, a drawing facing south-east in the orientation dialog. Could it be that you mis-interpret the sketch? On the right side, in the view from the top, the red and black dots are on ground level! Best regards, Bruno
The bug has been fixed vor PVsyst Version 6.26.
The table calculation can occasionaly crash due to a bug in a log message call. If this happens, a workaround is to generate the output as ASCII file. In the simulation dialog ckick on 'Output File' and select the variables that you want to look at. You can get hourly, daily or monthly values. The results can be viewed with a text editor or spreadsheet application like MS Excel. The bug is being fixed.
Hi Iain, currently there is no way to get all the hourly result values from a simulation that has already been run, except for the method you are using. If you need these results often, I would recommend you to systematically create an ASCII output file, when you run a simulation. You can customize which variables should be written to the output file, and save this as a template to re-use it. PVsyst will not store the output filename for a given variant, so you will have to choose it every time you want to run a simulation and create the ASCII file. We will consider to change this behaviour. As for the possibility to run all variants of a project in one go, we are reworking and improving the batch simulation feature of PVsyst, and we will see if we can add this possibility. This would be for somewhen end of the year. Best regards, Bruno
How is incidence angle modifier calculated for diffuse component
Bruno Wittmer replied to Karjalv's topic in Simulations
Note also, that if you are interested specifically in the IAM, PVsyst can generate for you a lot of detailed intermediate results such as: - IAM factor on global - IAM factor on beam component - IAM factor on diffuse component - IAM factor on albedo component - ... and many more, that allow you to study in detail the effect of the IAM on the simulation results. In the program you need to click on 'Output File' in the 'Simulation' Dialog, and then choose the variables that you would like to have in the output. See also the online help under 'Project Design -> Simulation -> Export ASCII File' -
Which SMA Sunnyboy inverter exactly are you planning to use? The 8kW inverters have an operating voltage range between 300 and 480V. If you string up 11 SunPower 327 modules, you get operating conditions between 500V and 800 V, which is not compatible with these inverters. Also, using 4 strings of 11 modules would give you a nominal power of 14.4 kW, which is far less than 4 x 8kW on the inverter side. PVsyst will report errors with these design choices, and not permit a simulation.
Hi Mahnam, a PVsyst crash is definitely a bug, this should not happen. If you get a prompt asking to send a bug report, then it would be nice if you could do so, our support team will get the report and try to fix the bug. If you do not get the prompt, then I would ask you to export the project to a zip file (In the main window select 'Files -> Export Projects'), and send it to me (Bruno.Wittmer@pvsyst.com), we will have a look at it. Best regards, Bruno
With PVsyst V6.25 the handling of large and complex 3D scenes has been improved. The loading and saving of the different variants has been made faster. The editing of the 3D scene is much smoother. This makes the handling of large projects now much easier.
The files with meteorological data (.MET extension) are associated to specific sites. When you import the data, you specify the site, to which this file will be linked. When you want to use the imported file, you have to make sure that you first select the correct site, then the .MET file will show up in the dropdown menu. Note that you can associate more than one .MET file to the same site (for example to compare different data sources or different years). PVsyst will always compare the geographical coordinates of the meteorological data file (.MET) and the site for which you want to use it, and issue a warning, if they are too far away from each other.
For some of the crosschecks in PVsyst, two angles are considered to be the same, if they differ by 1° or less. For projects with multiple orientations that have small differences (<= 1°) between each other, this may lead to inconsistent behaviour, when Tilt and Azimuth are matched between the 'Orientation' dialog and the 3D scene. The problem is being adressed and a solution is envisaged for one of the next releases. To work around the problem, sub-arrays with tilt or azimuth differences equal or smaller than 1°, should be gathered in one single sub-array with the same average orientation. Note, that in the 3D scene, fractional angles will be rounded to integer values for displaying and crosschecking. Internally the fractional values are conserved.
Single-axis tracker and north-south tilt
Bruno Wittmer replied to jackattack's topic in Shadings and tracking
You have to make sure, that the axis tilt is the same in the 'Orientation' Dialog as for the trackers in the 3D scene definition. PVsyst will crosscheck those two values and give an error message, if they do not match, but only differences larger than 1° are considered errors. The report will show you the value defined in the 'Orientation' Dialog, and this is also the value used in the simulation. So you should change the axis Tilt to 1° also in the 'Orientation', to get the expected result. -
Output csv file for Excel in German version of decimal "comma"
Bruno Wittmer replied to asb's topic in How-to
PVsyst does not foresee to use decimal commas. You will need to set set decimal dots in Windows or in Excel: For Windows 8 you find the setting in: 'Region -> Formats -> additional Parameters -> Numbers' . You need to restart Excel for this to take effect.In Excel you find the setting in 'Options -> Advanced -> Editing Options' After importing the file you can change back to decimal commas. -
Hi Amir, the IAM is just a factor that is applied according to the incident angle. The details are given in the online help under 'Project Design -> Array and system losses -> Array incidence loss (IAM)'. You can find this page also on the web. The ASHRAE model used in PVsyst is a simplification, but should give good results in most cases. The transmittance of the glass cover is only relevant for multiple reflections, which contribute little to the overall loss estimation. The non-perfect transmittance is neglected by the model. In the attached picture you can see as an example the comparison between the ASHRAE model, a calculation with double reflection using Fresnel's law and the measurement from the manufacturer. If a better approximation than ASHRAE is known for your system, you can define a customized IAM profile in the dialog 'Detailed Losses', tab 'IAM losses'. The definition of the IAM profile can also be provided in the PV module definition file (PAN file). In this case the 'IAM losses' tab will display a checkbox allowing to choose the definition from the PV module file. Best regards, Bruno
The specifications of the module at STC (or any other irradiance level), includes the glass cover, so it is not necessary to add it separately. PVsyst assumes that the values from the module specifications are valid for an incidence angle of 90°. It then applies the Incidence Angle Modifirer (IAM) to account for the different incidence angles along the day and seasons.
This functionality has not been implemented yet, and unfortunately the checkboxes were not suppressed. Right now, PVsyst always supposes a partition in length in the module's definition. But you can modify this in the Module Layout, when effectively using this feature. See also the following forum post. This feature will be enabled in a coming version.
RETScreen Import Error - Value must lie between -20 and 50
Bruno Wittmer replied to Evan_CSSI's topic in Meteo data
There is a parameter to define this limit. In the main window menu choose 'Preferences -> Edit hidden parameters' Look for the category 'Miscellaneous'. There you can set 'Minimum monthly ambient temperature' (the default is indeed -20 °C). -
The error happens, when displaying IV-curves in rather extreme conditions at the beginning or the ending of summer days. To work around this, proceed as follows: 1. In 'Module Layout', in the Tab 'Shadings 3D' click on 'Calculate' 2. Once the calculation is finished, and before(!) moving to the tab 'IV curve', drag the time slider to somewhere around noon. 3. Switch to the tab 'IV curve'. You can change the time, but avoid the last and first time slots of the day. Note, that if you go too far with the slider, and the error happens, you will have to restart PVsyst to get again useful IV-curves. We will try to fix the bug for the next PVsyst release (V6.23)
The mnimum acceptable PV module area in PVsyst is defined as 0.1 m^2, which is apparently too large. For the next Version (V6.23) this has been reduced to 0.01 m^2. In the meantime, to work around the current size limitation, you can perform a simulation with module dimensions that are too large, as long as you do not define the 3D shadings. The results should be correct, with exception of the efficiency figures, which scale with the module dimensions. All other relevant results, like produced energy, losses, PR, etc. should not be affected. Thank you for reporting the issue.
Transforming the solar irradiance from the tilted plane (POA) back to the horizontal is a non-trivial problem, involving some modelling. If you have POA values that you want to use, the way to go is to import them through 'Databases -> Import ASCII meteo file' (check the online help and tutorial for instructions). This will do the transformation back to the horizontal plane, but be careful with some pitfalls described in the following two FAQ entries: Can I import POA measurements ? My transposed POA values don't match the imported values
At the bottom of the loss diagram you will find three values: 1. From grid: Is the energy that had to be bought from the grid to cover the specified load during times of unsufficient solar production 2. User: The part of the load that was covered by solar production 3. to grid: The energy that exceeded the user load at times of high solar production, and that was sold to the grid From these definitions you can do the following crosscheck: 1. + 2. should give the load that was specified 2. + 3. should give the Available energy at Inverter Output.
Importing ASCII Meteo Data - Update Tutorial/Help
Bruno Wittmer replied to sbhatti_midgard's topic in Suggestions
This limitation has to do with the internal representation of the dates in the program and cannot be easily changed. But it is noted, and this limitation might go away in one of the future releases. Meanwhile, the only workaround is to change the year in the data file with search/replace to a value between 1980 and 2060. I will include a clear remark on this in the online help. Thank you for reporting the issue. Bruno Wittmer -
Shading according to defined module location
Bruno Wittmer replied to maranden's topic in Shadings and tracking
Dear Martin, the sun height, which is at the input of the shading calculations, depends only on the date and time, and of course the geographical coordinates of the site. It is expressed as an angle, which is the same at all points of your shading scene. This means, that we treat the sun beams as a perfectly parallel bundle of rays, which is a fairly accurate approximation of real conditions. So the answer to your question is, that only relative placement of the objects with respect to each other is relevant. -
Chage to near shading for unlimted shed arrays
Bruno Wittmer replied to Chuck_Ladd's topic in Shadings and tracking
The discrepancy is due to a bug that was introduced in V6.13 and corrected in V6.19. The tilt for the calculation of the diffuse shadings was not correctly read from the file and lead to an error in the calculation. This error happens only for calculations with unlimited sheds. The results ov V6.21 are the correct ones. Best regards, Bruno -
You need to put the '.OND' file into your Workspace in the directory 'PVsyst6_Data\ComposPV\Inverters'. Then from the main window you choose 'Databases -> Grid Inverter' The inverter will show up in the list and you can have a look at it by clicking 'Open'. Best regards, Bruno Wittmer
The deviations you observe can be due to rounding errors, since the percentages in the loss diagram are displayed with a precision of one decimal. Your reasoning is correct, the losses reported in the loss diagram should match the result summary. If, for crosschecking, you would like to repeat the whole calculation, you can export all the intermediate results of a simulation by selecting 'Output file' in the Simulation Dialog. Here you can make a choice of the variables you would like to look at and have them written into an ASCII file. In this way you should get less rounding errors. Best regards, Bruno Wittmer
