In the PVsyst versions 6.67 up to 6.70, thin film PV modules with custom values for the shunt resistance Rsh and the series resistance Rs were not always read properly in the database, causing these resistances to be set to default values. This can lead to different performance results in the simulation. In these cases, for a correct simulation, please use PVsyst versions up to 6.66, or PVsyst version 6.71 and higher. The concerned modules display different resistance values in the PAN file editor. To check if a given PV module is concerned or not, open the module definitions with the different PVsyst versions: The PVsyst versions with the erroneous behavior for these modules are : V6.67, V6.68, V6.68 and V6.70. An (incomplete) list of concerned modules is: FirstSolar CdTe modules Calyxo CdTe modules Masdar PV Gmbh uCSi-aSi modules Schueco aSi modules NexPower uCSi-aSi modules V6.67 - V6.70 <= V6.66, >= V6.71
Using MPPT Causing Inverter Loss Over Nom Inv Power to Increase
Bruno Wittmer replied to teopb's topic in Problems / Bugs
The difference you are observing could be caused by a number of strings that is no multiple of the number of MPPT inputs, or even not a multiple of the number of inverters. When doing a simulation with no multi-MPPT feature, PVsyst will just distribute equally the power of all strings on all inputs of the inverter. If the number of strings is not a multiple of the number of inverter inputs, you will get a fractional number of strings per input. This is a simplification, since in reality you cannot connect a fractional number of strings to one MPPT input, and the result will be an approximation in this sense. With multi-MPPT feature activated however, PVsyst will try to match an integer number of strings to each MPPT entry. By default, it is assumed that each MPPT input can handle the same fraction of the total inverter power. This can give raise to strongly overpowered MPPT inputs. There are inverters with multiple MPPT inputs, which can distribute the total nominal power in a non-equal way among the inputs. When there are different numbers of strings at each input, these inverters can make a better use of the total power limitation, by assigning more nominal power to the inputs with more (or longer) strings. To simulate this kind of inverters, PVsyst allows you to specify explicitly the power that each inverter input will handle. This is called 'Power sharing' in the system dialogue. You should only use this feature if you are sure that the inverter you are using is able to the different MPPT inputs with different nominal power. In such a case, to describe the system correctly in PVsyst, you need to create several sub-arrays, one for each type of input configuration. Different input configuration means that any of 'Mod. in series', 'Nb. strings' or the power share differs. After creating the sub-arrays, you can adjust the 'Power Sharing' that is accessible through the corresponding button in the 'system' dialogue. The smallest losses are obtained, if the Pnom ratio is the same for all inputs of an inverter. The overload losses will always be higher than in the simulation without multi-MPPT feature, which is a kind of 'theoretical limit' of perfectly balanced MPPT inputs. -
The behavior you are observing might be linked to the flag that controls the mismatch calculation before each simulation. Before a calculation involving ageing, PVsyst will, by default, do a Monte-Carlo calculation of the mismatch factor due to ageing. This leads to slightly different results every time you perform a simulation. You can also force the program to keep the same mismatch factor for each simulation. In the 'Ageing' dialog you need to check 'Keeps calculated Mismatch values'. In this case the mismatch values are kept fixed (also written to file) and the simulation will give always the same results. Keeping mismatch values fixed.
Can't load User Needs ( Not even the template given by PVsyst)
Bruno Wittmer replied to MajaG's topic in Problems / Bugs
Indeed the file selection has no effect, and no profile is being loaded. I corrected the error and in Version 6.6.1 it is fixed. This version is planned to be published beginning of the week of March 20, 2017. -
Yes, in principle the two should yield identical results. I will check this and post a reply.
The wrong unit display has been fixed for PVsyst Version 6.60.
There is an error with the units display. Although the label reads MWh, the values are in GJ. There is a factor of 3.6 between the two (1MWh = 1MJ/s * 3600s = 1GJ * 3.6). I will fix the error and post from which version on the fix applies. A comment on the work-around proposed by nickSHIFT: You can also retrieve the results from the Optimization tool in Excel. They are stored as CSV files in the PVsyst workspace in the subdirectory 'UserOptimization'. The file names are constructed from Project name, Variant Id, Scan Name and a counter. In those files, the energies are given correctly in kWh.
In PVsyst Versions up to 6.52, when a System is defined with PV modules of Jinkosolar together with Maxim optimizers, the default value for the 'Module Quality Loss' becomes 3%. This value differs from the case where the same modules are used without Maxim optimizers. In this case the default 'Module Quality loss' is 0.8%. The discrepancy is due to the fact that, by mistake, in the PVsyst Database, the Jinkosolar PV modules for Maxim optimizers, were not assigned a lower Tolerance for Pnom. The correct value of the lower tolerance should be zero, as for the modules without Maxim optimizers. The definition of the Jinkosolar Maxim modules will be corrected in PVsyst V6.53. Until then, the following approach will correct the problem: Correct the PAN file by opening it, and writing the value 0 in the field 'Tol. -'. Save under a new file name and use this new PAN file for the simulation. Once the PVsyst database has been corrected, these PAN files can be discarded.
The bug has been fixed for PVsyst V6.42, to be released in the coming days.
When doing the calculation according to strings, there is indeed a bug in V6.40 and V6.41, causing some of the shaded areas to be counted twice, resulting in too large electrical shading factors. The fix is being worked on.
Bug in batch mode version 6.3.9 of PVsyst?
Bruno Wittmer replied to spelland74's topic in Problems / Bugs
In fact the variants were not being properly restored after each batch run step. This is now fixed for the coming version 6.42. Thank you for reporting the issue. -
The electrical loss according to strings depends strongly on the specific details of the simulation. Could you send your project (or a minimal example where you observe the behavior) to support@pvsyst.com, so we can have a look at it? We did not introduce any fundamental change in this calculation, so we do not expect major differences in the results of V6.39 and 6.40.
Yes, there seems to be something wrong there. I will look into it right now. -
The procedure to import data from Solar Prospector is described in the PVsyst help 'Meteorological data -> Meteorological data sources -> Solar Prospector Data -> Importing Solar Prospector Data'. Did you follow the steps described there? Which tool are you using to uncompress the .gz file?
There is no simple answer to this question. You are absolutely right in saying, that a pitch of <2m with a shed width of 2m leads to large shading factors and subsequent losses. The ideal situation is to choose the optimal tilt for your latitude, and either to have all sheds side by side, so that there is no shading, or to put them behind each other with infinite wide spacing, which will also lead to no shading. Of course you cannot do this in practice, so you have to approximate to it, given your specific constraints, like availability of the area, clearance for access paths, etc. The optimum from an economic point of view will include also an assessment of the costs of the surface, installation and maintenance costs, and the expected revenues or savings per kWh that is produced. This is highly dependant on your specific project and has to be studied case by case. But as a general rule, you can take that you should put as much sheds as possible side by side and keep the distance between rows as large as possible. Remember, that the closer the rows are to each other (i.e. the smaller the pitch), the smaller you should choose the tilt angle to minimize shading losses. The tool that André mentions, will help you already with the geometrical optimization, for given surface constraints. We are also preparing a tool in PVsyst that will allow a more complex analysis, including economic variables. This should be available in a version within the coming month or two.
How to define a different Power Optimizer than SolarEdge
Bruno Wittmer replied to Alex Masolin's topic in How-to
TIGO Optimizers are available for PVsyst V6.27 or higher. In the 'System' dialog check 'Use Optimizer' (in the module selection group). A pull-down menu will appear below the module selection field, where you can choose the model of the optimizer. -
This problem happens on the southern hemisphere for two specific tracking cases: - Two Axis - Vertical Axis It is a bug that is caused by a wrong sign in the calculation of the diffuse shading. This bug has been fixed for Version 6.31.
shading area is far larger than the pv modules area
Bruno Wittmer replied to mnmasoud's topic in Shadings and tracking
This error means, that there is a mismatch between the total module area as specified in the 'System' dialog, and the total active area as defined in the 'Near Shadings' scene. You have defined more sensitive area in the 3D scene, than the sum of all modules areas. -
Near SHD According to module Strings
Bruno Wittmer replied to Fredy's topic in Shadings and tracking
The electrical shading losses account already for the shading losses, the loss is not computed twice. The percentage losses in the loss diagram always refer to the preceding amount of energy. You should read the loss diagram as percentages on top of each other, not as percentages of the total initially available energy. Since shading loss and electrical effect are conceptually something different, and since logically they happen at different stages, it is reasonable to display them separately. -
The linear shading loss is the fraction of irradiance that you loose due to shading. For the direct component this is just the fraction of the active surface that is shaded, but for diffuse and albedo it involves an integral over the entire hemisphere. This loss means, that less light is reaching the modules. The electrical loss caused by the mismatches due to shadows, is an additional effect that comes on top of this. If you do the simulation according to strings, you can define how much the impact of partial shading should be in a string. 100% means that a partially shaded string will produce no output, 50% that it will still generate half of the output, and so on. This is to account for the fact, that the production in a string will not drop to total zero, due to remaining diffuse irradiation. If you use 100% for this factor, then your comment is right, it would not be necessary to calculate the linear shadings, since you loose all the string production. But for factors less than 100%, this mismatch(!) loss has to be applied on top of the irradiance loss, and this is why you have two separate entries in the loss diagram. -
Intrerpretation of mismatch losses plot from PVsyst Tools
Bruno Wittmer replied to josealjim's topic in Shadings and tracking
The filled circles mark the MPP and in the legend you find the power loss at MPP which is the difference in power between the average (green) curve and the resulting one (black). In order to show, that the losses can become larger if you work at a fixed voltage, the graph also shows the difference in current for V = Vmpp * 0.9 (where Vmpp is taken from the black curve). This is marked by the open squares. -
For the SolarEdge architecture, when you want to connect different strings to the same inverter, you have to use the option 'Use fractional inputs'. In this way you can define different number of modules for each sub-array, but you should make sure, that you assign an adapted number of modules to each fraction of the inverter. In your case, you could define for example a fraction of 0.3 for East and West and 0.4 for South and assign a matching number of modules to each. The screenshot shows how the the system definition in the report could look like. SolarEdge Inverter with three different orientations
If you do not need all versions you created in all projects, you might want to consider using different workspaces to keep things organized. See also the Help under 'Technical aspects > File organisation > User data > Workspace'
Dear Vikram, if you would like to vary the plane tilt in the batch simulation, the end in your CSV file should look like the example below. Please note that the CSV file is an ASCII text file. You are not forced to use Excel, indeed you can youse any ASCII text editor. If you use Excel or a sophisticated editor like Word, you need to save the file as ASCII text. In Excel , when you choose 'Save As', you have an option 'CSV file', (wich stands for Copmma Separated Values). In Word you will have to choose 'Raw text' and remember to keep the .CSV ending of the file. Best regards, Bruno Table for varying only the tilt in a batch simulation: Ident;Plane;Simul;; ;tilt;Comment;; ;[deg];Y/N;; ; SIM_5;5;Tilt 5 ;; SIM_6;6;Tilt 6 ;; SIM_7;7;Tilt 7 ;; SIM_8;8;Tilt 8 ;; SIM_9;9;Tilt 9 ;; SIM_10;10;Tilt 10 ;; SIM_11;11;Tilt 11 ;; SIM_12;12;Tilt 12 ;; SIM_13;13;Tilt 13 ;; SIM_14;14;Tilt 14 ;; SIM_15;15;Tilt 15 ;; SIM_16;16;Tilt 16 ;; SIM_17;17;Tilt 17 ;; SIM_18;18;Tilt 18 ;; SIM_19;19;Tilt 19 ;; SIM_20;20;Tilt 20 ;; SIM_21;21;Tilt 21 ;; SIM_22;22;Tilt 22 ;; SIM_23;23;Tilt 23 ;; SIM_24;24;Tilt 24 ;; SIM_25;25;Tilt 25 ;; SIM_26;26;Tilt 26 ;; SIM_27;27;Tilt 27 ;; SIM_28;28;Tilt 28 ;; SIM_29;29;Tilt 29 ;; SIM_30;30;Tilt 30 ;; SIM_31;31;Tilt 31 ;; SIM_32;32;Tilt 32 ;; SIM_33;33;Tilt 33 ;; SIM_34;34;Tilt 34 ;; SIM_35;35;Tilt 35 ;; SIM_36;36;Tilt 36 ;; SIM_37;37;Tilt 37 ;; SIM_38;38;Tilt 38 ;; SIM_39;39;Tilt 39 ;; SIM_40;40;Tilt 40 ;;
Any text editor should do the job, TM2 files are plain ASCII text. If you are interested in the format of the file, a description of it can be found at: http://rredc.nrel.gov/solar/pubs/tmy2/data.html
