Alex Bande joined the community
Dear Nikhil Lokhande Thanks for your feedback! As you correctly analyzed, the battery is currently shared across the whole system, between the final MV transformer and the injection point. You could find some very far-fetched workaround (splitting your system into two variants and upscaling your inverters so as to not clip and use a variable grid limitation to reintroduce the clipping after the battery), but I'm not sure about the reliability of the results you may obtain that way. We have planned for more options in terms of battery connection, but it won't be before the next major version at the very least. Secondary Reporting Observations: SLD Visualization: The single loss diagram is currently under heavy rework and should be available in the next major version. System Overview: The chargers (Dynapower DPS-500) are omitted from the primary System Overview tab, which focuses only on the grid-feeding inverters. As mentioned, the battery can only be set on the AC side for the moment, so it is not possible to simulate a system with DC-DC converters. Questions for the Community/Developers: Is there a workaround to "un-assign" a specific sub-array from the DC-coupled storage bus within the same variant? : Not for the moment (DC coupling is not possible either) If we must run two separate projects and combine the hourly data in Excel to respect the 2.49 MW POI limit, how can we best account for the shared "Grid Power Limitation" within PVsyst’s energy management logic? When applying the grid limitation to individual inverters during the simulation, PVsyst is dispatching the total value based on the estimated AC power of each inverter. You could reproduce a similar strategy if you split your system into two variants. run the two variants without grid limitation Compute the relative production of each system Compute the grid limit for each system at each time step based on the total grid limit and the relative production Use the possibility introduced with PVsyst 8.1 to import a time series for the grid limitation Run the simulation again with the grid limitation activated. You can also create alternative strategies to reflect your system behavior if needed (e.g : prioritize one side of the system for example).
Hello PVsyst Team and Forum Community, I am currently modeling a 5.00 MWdc / 2.49 MWac utility-scale project in PVsyst 8.1.0 that utilizes a split-architecture. I am seeking guidance on how to accurately isolate storage to a specific sub-array or if this is a planned feature for future updates. System Architecture: Our design uses two distinct paths tied to a single 2.49 MW AC Point of Interconnection (POI): Path 1 (DC-Coupled): 4.364 MWp PV array connected via 4x Dynapower DPS-500 DC-DC converters to a 10 MWh BESS. This path uses 4x Solectria PVS-500 (1.992 MW AC total) bi-directional inverters. The ILR on this path is high (2.18) specifically to maximize clipping recapture. Path 2 (PV-Only): 0.641 MWp PV array connected to 3x Solectria XGI 1500-166 inverters (0.498 MW AC total). This path has no battery and should feed the grid directly. The Issue: In the current version (8.1.0), the Storage menu for DC-coupled systems appears to follow a "Global DC Bus" logic. I am unable to find a way to assign the battery and the DC-DC chargers exclusively to the DC bus of Sub-array 1 while treating Sub-array 2 as a standard PV-to-grid path. As a result, the simulation assumes the battery can "see" the excess energy from the entire 5 MWdc array, which does not reflect the physical wiring of the site. Secondary Reporting Observations: SLD Visualization: Even in 8.1.0, the Single Line Diagram tool does not render symbols for the battery or the DC-DC converters (chargers), making it difficult to present the architecture to stakeholders within the report. System Overview: The chargers (Dynapower DPS-500) are omitted from the primary System Overview tab, which focuses only on the grid-feeding inverters. Questions for the Community/Developers: Is there a workaround to "un-assign" a specific sub-array from the DC-coupled storage bus within the same variant? If we must run two separate projects and combine the hourly data in Excel to respect the 2.49 MW POI limit, how can we best account for the shared "Grid Power Limitation" within PVsyst’s energy management logic? Any insights on how to handle this "Hybrid" Path 1/Path 2 architecture would be greatly appreciated.
adebayo joined the community
Lim joined the community
Sub-hourly simulation Release note: Sub-hourly Simulation for Grid-Connected and Standalone systems The main feature of PVsyst 8.1 is the possibility to run sub-hourly simulations. It is therefore now possible to model a PV system with more accuracy. Several physical models have been adapted to this new time scale, as detailed in the next section. The granularity at which it is possible to simulate a project is directly that of the weather data file (.MET). To support this feature, it is therefore also possible in PVsyst 8.1 to import sub-hourly weather time series to generate sub-hourly weather data files. At this time, sub-hourly files can either be created by using the custom weather import or using the Meteonorm 9.0 DLL and choosing the `minute` option. All weather data files, independently of their time step, can also be used to run hourly simulations. A radio button, present both in the main project window as well as in the "Advanced simulation" window, allows you to easily switch from one granularity to the other. Sub-hourly simulations will correspondingly generate sub-hourly time series tables when using the "Output file" functionality. Hourly simulations retain the advantage of being much faster, since fewer steps need to be simulated. It is therefore recommended to run hourly simulations during iterative design phases. Sub-hourly simulations, which take longer to run, can be left for more final evaluations. Generally, small differences may appear between hourly and sub-hourly simulations. This is inevitable, since several physical models are nonlinear and are therefore sensitive to averaging in time. For the most part, sub-hourly models lead to small changes that can be considered small gains in accuracy. However, some models have required more work to ensure the accuracy of the simulation at all time scales (see section below) despite more important differences between hourly and sub-hourly calculations. Note also that the largest discrepancy, i.e., clipping effects, is still addressed in hourly simulations (since version 8.0) with underlying sub-hourly weather data with a dedicated correction. Improved physical models With the new possibility to run sub-hourly simulations, several models had to be adapted. The three main changes concern models that did not preserve sufficient accuracy when applied at sub-hourly scales. Release notes: Thermal model: PV module temperature is now computed using a transient thermal model for both hourly and sub-hourly simulations Weather data, custom file: new model to estimate diffuse horizontal irradiance from global horizontal irradiance. Dedicated coefficients for sub-hourly simulation are used in order to reduce the discrepancies with hourly simulations Transposition model: sub-hourly horizontal diffuse irradiance data with the Perez model now uses coefficients adapted to each time step. These adapted coefficients aim at reducing the discrepancies between sub-hourly and hourly simulations Each of these changes is detailed here below. Transposition model The default model used in PVsyst, the Perez model, relies on several weather data indicators (sky brightness, sky clearness, sun zenith angle), associated with a set of empirical coefficients, to decompose the horizontal diffuse irradiance into components that are to be transposed with different geometric rules. This decomposition leads to effective discrepancies when comparing corresponding hourly and sub-hourly time series. When studying an ensemble of sites across the globe, this granular discrepancy translates to a systematic discrepancy, averaging half a percent in terms of PV system yield. Since the empirical coefficients used in PVsyst (and in several other simulation software) have been fitted with hourly and quarter-hourly data, the sub-hourly results of the Perez diffuse decomposition using these coefficients can be considered biased. For this reason, a new set of coefficients, which corrects the bias observed over 113 sites worldwide, is used by PVsyst when running sub-hourly simulation with the Perez model. Note that the direct irradiance transposition also leads to discrepancies between hourly and sub-hourly simulations. While the exact cause is not yet understood, since the transformation is purely geometric, the sub-hourly simulation can be considered more accurate in this regard. Decomposition model When importing custom weather-data with only global horizontal or only plane-of-array irradiance, PVsyst must estimate the diffuse horizontal irradiance. This was done until now using Erbs model. This model, based on a single clearness indicator, is considered to have sufficient accuracy for hourly simulation. However, at shorter timescales, it fails to capture fast phenomena such as cloud enhancement and results in a systematic discrepancy compared to real measurements. To reduce this discrepancy, we selected a more flexible model from the literature, ENGERER2, whose additional indicators (clear-sky clearness, cloud-enhancement index, ...) allow one to represent sub-hourly dynamics more accurately. Similar to the adaptation of the Transposition model, we refitted the model coefficients to reduce the bias observed on the previously mentioned 113 sites dataset. Compared to Erbs, this new computation successfully mitigates the bias for all sub-hourly timescales. It also mitigates a small residual bias of the previous model at the hourly timescale. This small difference will slightly affect all irradiance loss components (IAM loss, shading losses, ...) affected by the decomposition of irradiance into components. Transient Thermal model In PVsyst 8.1, two layers of thermal models are used for the PV module: First, as in previous version, the thermal balance model outputs the steady-state temperature, represented by the PVsyst variable TArrSS. Second, a thermal inertia model uses the previously calculated steady-state temperatures to compute the actual transient temperature, represented by the PVsyst variable TArray. The user can modify the heat transfer coefficients and the mass of the module (affecting the thermal inertia) in the detailed losses and .PAN file menus, respectively. For hourly simulations of conventional PV systems, thermal inertia affects the production E_Grid by about ~0.1-0.3% annually. In particular settings, it can have a stronger impact. For example, if an inverter is designed to operate close to its over-voltage limit, production can be affected by 1-3 % annually, as the temperature change induced by thermal inertia mainly impacts the PV array voltage.
Indeed all tables need to have the same width and you need to have pitch (thus more than 1 row) to calculate the bifacial gain. A possible workaround for the issue of only having 1 row, is to duplicate the scene further away so that PVsyst can detect a pitch. Verify that the tables are well aligned so that indeed PVsyst detects the pitch in bifacial window. Note that the amount of tables in the 3D scene will be double what you have defined in the system and this will create a warning. You can increase this limit in the advanced parameters. In the first PVsyst welcome window, click “Settings” and “Edit advanced Parameters” and find the parameter that triggers the error message – “Shadings: absolute maximum shading/field area ratio”. This will allow you to run the simulation - Earlier
