Yes, it’s possible, what you’re describing is essentially a ramp-rate limitation at the plant controller level. In your simulation, you’d need to introduce a dynamic constraint on active power output, such as a maximum % of MEC per minute (or per second) change rate, rather than letting inverter output instantly track irradiance. This can be modeled as a ramp limiter or first-order lag on the power setpoint coming from the PPC. By applying that rate-of-change constraint, the simulated output will lag during fast irradiation increases, reflecting the real-world limitation and associated energy losses.
popog21704 joined the community
- back-contact
- bc
- (and 5 more)
SAMET joined the community
EnriqueC joined the community
- grid power limit
- power factor
thanks!
There is a known issue where the total AC power in the report is not accurate with SolarEdge subarrays. This is due to the way the total is computed in the report, based on individual MPPT powers. With SolarEdge and its specific way to attribute (and distribute) strings to inverters, the computation is sometimes incorrect. This issue is on our roadmap, but as it does not impact the simulation results, it has been scheduled for a later version. -
