  2. Yes FShdBm = beam shading factor. FShdBm < 1 indicates that beam (direct) irradiance is being reduced by shading. 1.0 = no beam shading 0.95 = 5% beam shading loss 0.00 = fully shaded from beam irradiance ShdBlss = beam shading loss value. ShdBlss > 0 indicates a non-zero beam shading loss, so this also means shading is occurring. 0 = no shading loss
  3. Today
  4. Hi @Michele Oliosi, I am happy to see that you have implemented some changes in the new version! Could you clarify - is the modified coefficient Perez model and the Engerer2 model only used for 1-minute and/or sub-hourly data? Would it not make sense to also enable the new models for hourly data, and to add DIRINT as well. In your announcement, you say that "[the Erbs model is] based on a single clearness indicator, [and] is considered to have sufficient accuracy for hourly simulation. However, at shorter timescales, it fails to capture fast phenomena such as cloud enhancement and results in a systematic discrepancy compared to real measurements." This is only part of the problem with the Erbs model. It also can perform poorly under very clear skies, i.e. steady atmospheric conditions without fast phenomena, by simply overestimating the atmospheric turbidity. In this case it would make sense to add the DIRINT or DIRINDEX models, even for hourly data.
  5. Yesterday
  6. @Linda Thoren Just so I'm clear, can you elaborate on the significance of both terms? What do the values for FShdBm and ShdBlss mean? For capacity testing should the values of ShdBlss be zero? What happens when you get values > 1? is that just a simulation error? it makes sense to me that 1 would correlate to 100% shading. FShdBm = 1 means no shading?
  7. Dear Nikhil Lokhande Thanks for your feedback! As you correctly analyzed, the battery is currently shared across the whole system, between the final MV transformer and the injection point. You could find some very far-fetched workaround (splitting your system into two variants and upscaling your inverters so as to not clip and use a variable grid limitation to reintroduce the clipping after the battery), but I'm not sure about the reliability of the results you may obtain that way. We have planned for more options in terms of battery connection, but it won't be before the next major version at the very least. Secondary Reporting Observations: SLD Visualization: The single loss diagram is currently under heavy rework and should be available in the next major version. System Overview: The chargers (Dynapower DPS-500) are omitted from the primary System Overview tab, which focuses only on the grid-feeding inverters. As mentioned, the battery can only be set on the AC side for the moment, so it is not possible to simulate a system with DC-DC converters. Questions for the Community/Developers: Is there a workaround to "un-assign" a specific sub-array from the DC-coupled storage bus within the same variant? : Not for the moment (DC coupling is not possible either) If we must run two separate projects and combine the hourly data in Excel to respect the 2.49 MW POI limit, how can we best account for the shared "Grid Power Limitation" within PVsyst’s energy management logic? When applying the grid limitation to individual inverters during the simulation, PVsyst is dispatching the total value based on the estimated AC power of each inverter. You could reproduce a similar strategy if you split your system into two variants. run the two variants without grid limitation Compute the relative production of each system Compute the grid limit for each system at each time step based on the total grid limit and the relative production Use the possibility introduced with PVsyst 8.1 to import a time series for the grid limitation Run the simulation again with the grid limitation activated. You can also create alternative strategies to reflect your system behavior if needed (e.g : prioritize one side of the system for example).
  8. Hello PVsyst Team and Forum Community, I am currently modeling a 5.00 MWdc / 2.49 MWac utility-scale project in PVsyst 8.1.0 that utilizes a split-architecture. I am seeking guidance on how to accurately isolate storage to a specific sub-array or if this is a planned feature for future updates. System Architecture: Our design uses two distinct paths tied to a single 2.49 MW AC Point of Interconnection (POI): Path 1 (DC-Coupled): 4.364 MWp PV array connected via 4x Dynapower DPS-500 DC-DC converters to a 10 MWh BESS. This path uses 4x Solectria PVS-500 (1.992 MW AC total) bi-directional inverters. The ILR on this path is high (2.18) specifically to maximize clipping recapture. Path 2 (PV-Only): 0.641 MWp PV array connected to 3x Solectria XGI 1500-166 inverters (0.498 MW AC total). This path has no battery and should feed the grid directly. The Issue: In the current version (8.1.0), the Storage menu for DC-coupled systems appears to follow a "Global DC Bus" logic. I am unable to find a way to assign the battery and the DC-DC chargers exclusively to the DC bus of Sub-array 1 while treating Sub-array 2 as a standard PV-to-grid path. As a result, the simulation assumes the battery can "see" the excess energy from the entire 5 MWdc array, which does not reflect the physical wiring of the site. Secondary Reporting Observations: SLD Visualization: Even in 8.1.0, the Single Line Diagram tool does not render symbols for the battery or the DC-DC converters (chargers), making it difficult to present the architecture to stakeholders within the report. System Overview: The chargers (Dynapower DPS-500) are omitted from the primary System Overview tab, which focuses only on the grid-feeding inverters. Questions for the Community/Developers: Is there a workaround to "un-assign" a specific sub-array from the DC-coupled storage bus within the same variant? If we must run two separate projects and combine the hourly data in Excel to respect the 2.49 MW POI limit, how can we best account for the shared "Grid Power Limitation" within PVsyst’s energy management logic? Any insights on how to handle this "Hybrid" Path 1/Path 2 architecture would be greatly appreciated.
  9. Inverter/optimizer combination rules are directly sent by Huawei to PVsyst. Huawei's latest update indicates that this specific inverter can only connect to a total of two strings. As it seems different from what the data sheet in your screenshot suggests, I'd recommend that you contact Huawei to report the issue, and ask them to update their PVsyst database.
  10. Good morning, I think there is a bug in the Huawei rules for the new optimizers in the latest update. In PVSyst I'm not able to connect 2 strings of MERC-600W-PA0 optimizers on 1 MPPT while this is possible in the Huawei Smart design 2.0, so it should be possible. Please see the included image from Huawei Smart Design, and the fault from PVSyst. Kind Regards,
  11. Last week
  12. Adding figures. This is the original appearance.This is after going to "by modules."
  13. When I read in the most recent PVC files provided by our CAD team, some of the trackers are treated as "polygonal fields" instead of trackers. What does this mean and what can I do about it? I see that there is an option to define the polygonal field "By modules" in the "Draw poly" tab but it's not clear what this does. Even if I check that box and define partitions, no modules appear in any of the graphical representations and the type of object doesn't change, so I don't know whether this has solved the problem. Unfortunately, our design team doesn't have time to investigate this thoroughly, so I'm looking for a solution that can be implemented within PVsyst. Thanks.
  14. for now in PVSYST8 2026 possible?
  15. Sub-hourly simulation Release note: Sub-hourly Simulation for Grid-Connected and Standalone systems The main feature of PVsyst 8.1 is the possibility to run sub-hourly simulations. It is therefore now possible to model a PV system with more accuracy. Several physical models have been adapted to this new time scale, as detailed in the next section. The granularity at which it is possible to simulate a project is directly that of the weather data file (.MET). To support this feature, it is therefore also possible in PVsyst 8.1 to import sub-hourly weather time series to generate sub-hourly weather data files. At this time, sub-hourly files can either be created by using the custom weather import or using the Meteonorm 9.0 DLL and choosing the `minute` option. All weather data files, independently of their time step, can also be used to run hourly simulations. A radio button, present both in the main project window as well as in the "Advanced simulation" window, allows you to easily switch from one granularity to the other. Sub-hourly simulations will correspondingly generate sub-hourly time series tables when using the "Output file" functionality. Hourly simulations retain the advantage of being much faster, since fewer steps need to be simulated. It is therefore recommended to run hourly simulations during iterative design phases. Sub-hourly simulations, which take longer to run, can be left for more final evaluations. Generally, small differences may appear between hourly and sub-hourly simulations. This is inevitable, since several physical models are nonlinear and are therefore sensitive to averaging in time. For the most part, sub-hourly models lead to small changes that can be considered small gains in accuracy. However, some models have required more work to ensure the accuracy of the simulation at all time scales (see section below) despite more important differences between hourly and sub-hourly calculations. Note also that the largest discrepancy, i.e., clipping effects, is still addressed in hourly simulations (since version 8.0) with underlying sub-hourly weather data with a dedicated correction. Improved physical models With the new possibility to run sub-hourly simulations, several models had to be adapted. The three main changes concern models that did not preserve sufficient accuracy when applied at sub-hourly scales. Release notes: Thermal model: PV module temperature is now computed using a transient thermal model for both hourly and sub-hourly simulations Weather data, custom file: new model to estimate diffuse horizontal irradiance from global horizontal irradiance. Dedicated coefficients for sub-hourly simulation are used in order to reduce the discrepancies with hourly simulations Transposition model: sub-hourly horizontal diffuse irradiance data with the Perez model now uses coefficients adapted to each time step. These adapted coefficients aim at reducing the discrepancies between sub-hourly and hourly simulations Each of these changes is detailed here below. Transposition model The default model used in PVsyst, the Perez model, relies on several weather data indicators (sky brightness, sky clearness, sun zenith angle), associated with a set of empirical coefficients, to decompose the horizontal diffuse irradiance into components that are to be transposed with different geometric rules. This decomposition leads to effective discrepancies when comparing corresponding hourly and sub-hourly time series. When studying an ensemble of sites across the globe, this granular discrepancy translates to a systematic discrepancy, averaging half a percent in terms of PV system yield. Since the empirical coefficients used in PVsyst (and in several other simulation software) have been fitted with hourly and quarter-hourly data, the sub-hourly results of the Perez diffuse decomposition using these coefficients can be considered biased. For this reason, a new set of coefficients, which corrects the bias observed over 113 sites worldwide, is used by PVsyst when running sub-hourly simulation with the Perez model. Note that the direct irradiance transposition also leads to discrepancies between hourly and sub-hourly simulations. While the exact cause is not yet understood, since the transformation is purely geometric, the sub-hourly simulation can be considered more accurate in this regard. Decomposition model When importing custom weather-data with only global horizontal or only plane-of-array irradiance, PVsyst must estimate the diffuse horizontal irradiance. This was done until now using Erbs model. This model, based on a single clearness indicator, is considered to have sufficient accuracy for hourly simulation. However, at shorter timescales, it fails to capture fast phenomena such as cloud enhancement and results in a systematic discrepancy compared to real measurements. To reduce this discrepancy, we selected a more flexible model from the literature, ENGERER2, whose additional indicators (clear-sky clearness, cloud-enhancement index, ...) allow one to represent sub-hourly dynamics more accurately. Similar to the adaptation of the Transposition model, we refitted the model coefficients to reduce the bias observed on the previously mentioned 113 sites dataset. Compared to Erbs, this new computation successfully mitigates the bias for all sub-hourly timescales. It also mitigates a small residual bias of the previous model at the hourly timescale. This small difference will slightly affect all irradiance loss components (IAM loss, shading losses, ...) affected by the decomposition of irradiance into components. Transient Thermal model In PVsyst 8.1, two layers of thermal models are used for the PV module: First, as in previous version, the thermal balance model outputs the steady-state temperature, represented by the PVsyst variable TArrSS. Second, a thermal inertia model uses the previously calculated steady-state temperatures to compute the actual transient temperature, represented by the PVsyst variable TArray. The user can modify the heat transfer coefficients and the mass of the module (affecting the thermal inertia) in the detailed losses and .PAN file menus, respectively. For hourly simulations of conventional PV systems, thermal inertia affects the production E_Grid by about ~0.1-0.3% annually. In particular settings, it can have a stronger impact. For example, if an inverter is designed to operate close to its over-voltage limit, production can be affected by 1-3 % annually, as the temperature change induced by thermal inertia mainly impacts the PV array voltage.
  16. Is it possible to set inactive panels? Is it possible to run a simulation for FIX when there is a tracker running above them? And get 2 simulations at the same time? This is also important at a global radiation level and not just in production - how do you do it?
  17. I want to run 2 simulations in parallel, one of a single-axis track at a height of 2 meters, and static panels on the ground, and I want to calculate detailed parameters for each of the cases - that is, to know how much radiation lands on the static panels, but the panels in the track work above them. How do I do that?
  18. Hello, Indeed filtering out these two variables should be sufficient to remain compliant with the ASTM 2848-13 standard
  19. Hello, I am running a PV capacity test per ASTM2848-13 and it is important to filter out any data where shading is present. I am struggling to interpret the shading losses per the 8760 outputs. I have FShdBm and ShdBlss. Is there shading whenever FShdBm is < 1 and whenever ShdBlss > 0? Should I use any other 8760 outputs or is this sufficient? Thanks.
  20. Your data looks slightly shifted in time, did you define the time shift correctly when first importing your data? https://www.pvsyst.com/help/meteo-database/notes-on-meteo/meteonote7-time-shift-in-meteo-files.html?h=poa#time-shift-correction-when-importing-data When importing POA data, PVsyst will first transpose it to GHI and DHI which are required for shadings calculations. POA will be computed again during the simulation. Slight variations are therefore possible between input POA and GlobInc, but not to the extend you are observing.
  21. I am trying to compare the the Plane of Array Irradiance (POA) in w/m^2 i get from scada with the Global Incident in Coll. Plane from the PVSyst output knowing that the meteo file i used in simulation is generated using the scada data imported as a custom file so as i imported the POA to the PVSyst i expected that the POA should be identical with Global Incident in Coll. Plane but there is a differences in months starting from may to november attached a sample of the issue can any one explain why is this behaviour thank you in advance
  22. Earlier
  23. Indeed all tables need to have the same width and you need to have pitch (thus more than 1 row) to calculate the bifacial gain. A possible workaround for the issue of only having 1 row, is to duplicate the scene further away so that PVsyst can detect a pitch. Verify that the tables are well aligned so that indeed PVsyst detects the pitch in bifacial window. Note that the amount of tables in the 3D scene will be double what you have defined in the system and this will create a warning. You can increase this limit in the advanced parameters. In the first PVsyst welcome window, click “Settings” and “Edit advanced Parameters” and find the parameter that triggers the error message – “Shadings: absolute maximum shading/field area ratio”. This will allow you to run the simulation
  24. Hello, Can you also please share the Water Needs section and the pumping hydraulic circuit? Regards,
  25. Does that affect your summer days only? If yes, that's the sign of a wrong DST definition https://www.pvsyst.com/help/meteo-database/import-meteo-data/custom-meteo-files/conversion-protocol.html#summer-time-daylight-savings Otherwise, issues can arise from a discrepancy between your real tracker angle and the one computed in the PVsyst orientation. Do you have any way of comparing your tracker angle and the PVsyst tracker angle?
  26. Hi, Please stop rounding numbers to 0.1 and give us 0.01. Rounding makes for inconsistent values, and it's not possible to know whether a calculation has been done correctly. (I think sometimes a calculation does use the parameter value as entered, but the report shows it in tenths.) I've been unhappy with this for a long time, but I am motivated to write now because of difficulty I'm having interpreting the representation of mixed blocks as broken down over multiple MPPTs. There are 20 MPPTs used, so a resolution of 0.05 is needed. 75% of the entries are shown rounded and the totals don't add up. (See illustrations.) Thanks.
  27. Dear PVsyst Team, I am currently designing a solar-powered submersible pumping system; however, I am encountering challenges during the system definition stage; specifically in selecting and configuring a pump that meets my design requirements. As a result, I have been unable to successfully run the simulation. I would greatly appreciate your support in reviewing my setup, helping me define a suitable pump configuration, and enabling the simulation to run correctly. Thank you in advance for your assistance.
  28. Hi everyone, I enter the measured POA irradiation for the whole year based on every 10 min measured irradiation, we got shifted 2 hour POA irradiation for the results during summer time, how to solve this, I've seen that the GlobInc values sometimes lower from the POA values input.
  29. @Linda Thoren, Thank you for your suggestion. I've incorporated that, but after that, I am getting the new error as below. I assume, this was because of the 4 wide carport tables. To resolve this, I created another orientation for the 4 wide tables and created a separate sub-array too. But, then the new error was as follows. I think this is because there's only a single table of 4 wide array. Is that right? And what is the solution for this issue?
  30. Hi, The issue most likely comes from the definition in the 3D scene, if each panel is defined individually rather than as a table. As the red message in this window indicates (though not very clear so this can indeed be confusing), you can play with the shed's parameters as you like for parametric analysis, though the simulation will be done with the defined values in the orientations window and the table size in the 3D scene, only the pitch and number of rows can be overwritten. To solve this, you need to define tables rather than individual modules. If you are importing the tables from another 3D software, make sure you indeed draw full tables (as the alternative to the right), and PVsyst then normally will fill the total area with individual modules and the area will be considered a table.
