  1. Yesterday
  2. Last week
  3. It uses the last two points.
  4. PVsyst usually takes the minimum pitch as default value for the backtracking algorithm. If only one of your trackers has a pitch of 6.24 this may explain what you observe. Note that you can anyway override the backtracking parameters from the 3D scene > Tools menu > Backtracking management.
  5. Hello, I suggest that you run a simulation with the bifacial parameters and export an hourly output file with all the relevant parameters, such as overload losses etc. This can not be done for individual strings but for the full system. Running several iterations should give you a good estimate of the losses.
  6. Hi Linda, Thanks for the response. The requirement arises in order to optimally size no. of strings to MPPT of central inverter while complying to maximum current limitation of MPPT. Since the rear side current in bifacial is highly variable parameter I wanted use PVsyst to get fair estimation of it so that MPPT can loaded optimally, avoiding clipping losses. Can you suggest some solution here? Also can we find the single string current from IArray with total no. of strings
  7. My PVsyst report is showing a pitch of 6.24 even though I have set the pitch to 6.25 in the Shading Scene. How can I fix this? Thank you, Vera
  8. Thank you for your response. Does the linear extrapolation you mention use all points or the last two points of the table? Regards,
  9. Hello, The most straightforward way to evaluate bifacial gain is to run two simulations: one with bifacial parameters activated and one without. While the current itself does not differ between the front and rear sides, the rear side does contribute to the overall energy production. In PVsyst, the results are presented for the entire system and not broken down per string.
  10. Hello, PVsyst is calculating the sun position based on the exact year accounting for leap years, when specific years are simulated. Thus, if you import a specific year that is a leap year though the 29th is missing in the data set, it will be considered as missing data and values will be 0 (similar to as if any other date of the year was missing). So values for February 29th will be zero (e.g., no irradiance), but the date will still be included in the simulation. March 1st will correctly follow as the next day.
  11. Hello, You can read about how to adapt you PVsyst simulation to a floating system in the following post: https://forum.pvsyst.com/topic/1346-how-to-adapt-pvsyst-to-floating-pv-systems/
  12. Hello Tyler, Essentially, the Global incident in the collector plane will be calculated for each sub-array for the assigned orientation (or possibly a mixed orientation). The GlobInc as the total result is an weighted average based on the Pnom PV
  13. Hello, You can use the lasso selection (Ctrl+Shift+L) to mark all the tables that belongs to the concerned orientation and in the "List and management if objects" window (Ctrl+G) you can change the orientation of all the marked tables.
  14. Hi, I am trying to understand the Bifacial gain for my system in terms of electrical output for each string. The simulation results gives me I (Array) which i think is total Imp of plant both including front and rear contribution and not on string level. I understand PVsyst follow one diode model for Bifacial module but still is there any way PVsyst providing the value of this rear side and front side Imp separately for each string.
  15. If I want to simulate FPV system in PVsyst, for the temperature coefficients Uv and Uc, how much should I insert for each value?
  16. Hi Linda, I'd like to circle back to the original question, as I have a similar project with multiple azimuths and tilts, resulting in eight distinct array orientations. Since there is only one GlobInc value on the 8760, I am trying to determine how that GlobInc value is calculated. Is it a weighted average based on the DC capacity per each orientation? Thank you.
  17. Hi, thanks for the answer. My problem is that when I import the pvc file with the shading scene I do not know how to associate the different pitch to the two system sub-arrays. Like in this case, I have already created two sub-arrays in System design for the two pitch values, but how can I associate them correctly? If I click on one of the two group of the 3D fields, it highlights a mix of trackers with the two different pitch values.
  18. Yes indeed, one only other user reported this error. The error is indeed the unit's name, which should be MWh/year. With this the value itself is correct. I really don't know the origin of this error. I tried to secure some initializations, but I really cannot reproduce this problem, so that I can't be quite sure that it has been corrected. The user who had reported it cannot reproduce it, too. If you get this problem in a stable way, please send us you whole project, using "Files => Export project" in the main menu. Please send it to support@pvsyst.com.
  19. I have a variant of a project in which the 8760 file shows that E_Grid column is not reaching the defined "Grid power limitation" of 25 MW in "Energy Management" and yet there is some energy discarded as EGRdLim in the 8760 file. What makes it more confusing is that I'm copying from a variant that is working well, and just changing the orientation to domes. I'm attaching a capture of some of those cases. Any thoughts on what I may be missing? Thanks!
  20. Hi Greg, In PVsyst the grid-tied systems with storage will never charge the batteries from the grid. The non-zero values for EFrGrid are situations where PV generation and battery discharge together are not enough to cover the load, and therefore power needs to be imported from the grid. This typically happens at the end of the night and early in the morning when batteries may be discharged and PV generation is still low. It can also happen after a series of cloudy days that did not allow to fully charge the batteries.
  21. Hello, It seems to be linked to one of the new tolerances put in the new version that when the angle between your average orientation and at least one of your PV table is too high compared to the settings of your projects. To fix this error you need to increase this tolerance. From the main window of your project, click on "Project settings" at the top of the screen: Then you need to select the "Other limitations" tab and increase the value of the "Maximum orientation difference for defining average (spread) orientation" parameter: Once the value has been increased the error should disappear.
  22. Hello, The clearness index will be evaluated and compared with the clear day model for the same time period. Thus having only a few months of data will not be an issue. If you compare the data for 2025 with data for 2024, are they similar or are indeed the values for 2025 much lower?
  23. Hello, Indeed the workflow would be to precisely define the coordinates for where the site, define the MEF file and run the conversion of the data. If PVsyst suggest a time shift, go back to the MEF file and define the indicated time shift and run the conversion again. If the issue persists, please send your data to support@pvsyst.com and we can have a closer look.
  24. Hi, I am simulating a large-scale ground mounted PV project with fixed tilt orientation. Due to the slope of the terrain, each PV table has a slightly different orientation. When importing the H2P file, I get the error as shown below. In Version 7, I remember I was able to adjust the tolerance in the Orientations Management tab. That seems not possible now. Could you please let me know how to resolve this? Many thanks!
  25. Hello, This is possibly by creating two "orientations". Thus create one orientation for each pitch (even though they have the same orientation) and assign the bifacial parameters individually for each orientation.
  26. Hi, you can export an Output File with any relevant parameters through the Advanced simulation window.
