Hello, I did a similar test in version 8.0.18 and is seems to work as it should on my side. The zone to the left is places 0.5m above the ground the the zone to the right 5m above the ground. If the issue persist, please describe further how to reproduce it. Kind regards, - Today
mariem joined the community
NEILPD joined the community
Meklit joined the community
SONA joined the community
