Jherche joined the community
Luca M joined the community
Auriane Canesse started following Annual Variability
jihun joined the community
dtarin started following How to configure a tracker to lock the rotation
Ana Sofía Lanza started following Annual Variability
apointmedia joined the community
It is easier to transform fixed tilt structures to trackers in the 3D scene, using the Transform menu. The other way around can be more of a hassle. The wind stow option is a good option. it necessitates however to import weather data from a file in which you prepare a wind speed time series > some number. Another option is setting the tracker limit angles to e.g. min X and max X+1° if you are okay to fix the tracker to this 1° range. X and X might work too, though I would double check the output with the X, X+1 to make sure it is consistent. -
yes this is because of the ratio of width and pitch (GCR) which ultimately controls the tracking algorithm. In your case the GCR is .5. which explains that these two modifications are equivalent (approximately). I would still suggest the remove 1 cm option as better since it mimics most correctly what pvsyst does and is more general to other GCR ratios. -
machinecoffee03 joined the community
It seems I get the same result whether I add 2cm to the pitch or subtract 1cm from the sensitive width: -
I would like to know whether it is possible to use an already existing PVsyst simulation configured with single-axis trackers and simply lock the tracker rotation, keeping the modules fixed at a single tilt angle (for example, by using the stow position). Specifically, is there a way in PVsyst to block the tracker rotation and manually define a fixed tilt angle for the modules while maintaining the original tracker-based geometry and layout? Or, alternatively, if the intention is to simulate the system with a fixed tilt, is it necessary to rebuild the entire model using fixed structures with the desired tilt angle instead of trackers?
Antonio Augusto Ananias joined the community
blarussa joined the community
HOSSOU joined the community
Hector Hernandez joined the community
- 8 replies
- irradiance
- rpoa
(and 5 more)
