popog21704 joined the community
- back-contact
- bc
- (and 5 more)
SAMET joined the community
- grid power limit
- power factor
thanks!
Good to know it works ! Actually I was not sure if [X,X] worked, I seemed to remember that at some point in the past the trick did not work unless there was a difference between min and max. - Earlier
There is a known issue where the total AC power in the report is not accurate with SolarEdge subarrays. This is due to the way the total is computed in the report, based on individual MPPT powers. With SolarEdge and its specific way to attribute (and distribute) strings to inverters, the computation is sometimes incorrect. This issue is on our roadmap, but as it does not impact the simulation results, it has been scheduled for a later version. -
