Ivan L joined the community
Indeed, I have also been able to see confirm this on my side. I have added this to our internal discussion keypoints. We are working on another correction for 8.0.12 which depends on the number of rows. I think this will improve the noise that you see for low number of rows.
Unfortunately, I do not think there are sufficient studies on the aging of these types of modules for us to conclude on new guidelines on the dispersion of the aging. One way would be to contact manufacturers directly about that. In general, I would advise taking a conservative approach, and leave the default values when unsure. I personally would go on with the 0.4% by default.
JamesLenton started following Daily generation profile Irregularities
Hello, Please can you help explain why irregularities like the one shown in the image attached occur in PVsyst? In this instance power drops from 15 MW to 0 MW in 30 minutes, mid-day in the summer. To me this seems impossible, even with partial cloud cover. Could be a result of poor weather data, however I experience similar things with Meteonorm and PVGIS.
Dear Edwin, Thank you very much for your feedback and for taking the time to report this bug. Could you tell me how this situation occurred in your case, where the Medium Voltage panel remains visible even though you selected HV transformers? I need to reproduce this bug on my side in order to fix it. Regards,
fengche1915 joined the community
paulphillips joined the community
We are performing a simulation with an inverter brand XXX at a site in Spain. During the analysis, we observed differences between the simulation data and the DC current values defined in the OND file. - In the Main Parameters window the inverter has a rated AC power of 4504 kW, with a maximum DC current of 5002.6 A, for a voltage U_DC of 915V. According to the manufacturer's data sheet these values correspond to operating conditions at 40 °C. (See Figure 1) Figure 1 - In the Energy Managment tab, the "external ambient temperature (outdoor installation)" option is selected. See Figure 2. Figure 2 - In the simulation, the site shows maximum ambient temperatures of 43 °C, without reaching 50 °C. - However, when plotting the simulated DC input current and voltage points (extracted from the Uarray , IArray variables), it is observed that the maximum current values never exceed values expected for temperatures below 50 °C curve profile, not even close to the 40 °C profile (which would be the expected behavior). Next figure (Figure 3) shows inverter input curves (V,I) for different temperatures and in yellow (Uarray, Iarray) points from simulation. Figure 3 🔧 Additional details: - Tests have also been performed by manually modifying the temperature derating profiles, even at extreme conditions, but the DC current results in the simulation do not change. May be PVsyst is using the 50 °C inverter curve by default to limit the inrush current, regardless of the actual site temperature. Below we copy part of the OND file where the inverter operating limits are defined. Converter=TConverter PNomConv=4504.000 PMaxOUT=4504.000 VOutConv=660.0 VMppMin=915 VMPPMax=1300 Vmpp_PMax=915.0 VAbsMax=1500 PSeuil=20005.00 EfficMax=97.00 EfficEuro=95.00 FResNorm=3.00 ModeOper=MPPT CompPMax=Lim CompVMax=Lim MonoTri=Tri ModeAffEnum=Efficf_PIn UnitAffEnum=kW IDCMax=0.000 INomAC=3500.000 IMaxAC=3940.000 TPNom=40.0 TPMax=25.0 TPLim1=55.0 TPLimAbs=60.0 PLim1=4001.000 PLimAbs=2001.000 PInEffMax =1800.000 PThreshEff=49.90 HasdefaultPThresh=False ❓Question: - Is there any reason why PVsyst limits the input DC current according to the 50 °C profile even when the maximum ambient temperature conditions of 43 °C? - Is it possible that PVsyst is using an estimated inverter internal temperature different from the ambient temperature to apply the curves? - Why the simulation results do not show values with data at 40 degrees of the inverter? Attached is also the comparative graph between the inverter input curves (by temperature) and the simulated values. We thank you in advance for your attention and any clarification you can provide, we remain attentive for any additional information you may require.
lhr started following Why these two values are different
Dear pvsyst team, Hi,for the same item,Why these two values are different. How Globhor was transformed into Globinc?
