  2. Hello, Sorry for this warning message, it is nothing to worry about. It doesn't impact the simulation and can be ignored. It will be removed in 8.1.01. It is related to the thermalisation time of your subarrays compared to the simulation timestep. But it should not have been classified as a warning, only an information for internal use at PVsyst - because it should be present in the back for conditions that are actually suitable for a good simulation.
  3. I would like to suggest allowing the Bifacial Mismatch Factor to be defined individually for each PV module type within a project, rather than as a single global value. This would provide greater accuracy for simulations using multiple bifacial technologies or module architectures in a single variant. Thank you for considering this enhancement to the bifacial modeling workflow.
  4. Hi, We have defined the DC Ohmic losses to be 2.00% of STC for each subarray. However, in the report, it is presented as differing values 1.94-1.96%. We haven't used the detailed calculation tool. The calculated Ohmic values are the same in the Detailed Losses configuration and the report for each subarray, which suggests that the model is calculating the % loss with different STC powers to the report? In case it is relevant, it's a SolarEdge system with multiple orientations spread across multiple inverters. Thanks.
  5. Yesterday
  6. PVsyst will use the value specified as the inverter AC power, in this case 33.3kW. If a difference of 0.1% on the total AC power is a problem, you could copy the inverter, change the max AC power to 33.4kW, and replace 1/3 of your inverters with this new one. As long as the inverter name is unchanged, it will be usable with the same optimizers.
  7. Hello @Robin Vincent, I had a quick question related to a similar scenario. The system I’m working on has a target AC capacity of 900 kW. In PVsyst, I’ve modeled this using 27 units of 33.3 kW (SE100KUS equivalent), which corresponds to 9 inverters. However, PVsyst reflects the total AC capacity as 899 kW (27 × 33.3 = 899.1 kW, rounded). I wanted to clarify the following: Does PVsyst internally use 899 kWAC or 900 kWAC for generation calculations in this case? What would be the best way to model the system so that the AC capacity reflects exactly 900 kWAC instead of 899 kWAC? Appreciate your guidance on this. Thanks!
  8. Hello , after last update som error accures. What does it mean?
  9. Thanks a lot for your help, this worked.
  10. Hi, I've contacted Huawei, I will let you know of the answer.
  11. Last week
  12. Hello, Indeed it is on our roadmap to quickly implement an option to run the simulation in additional time steps intervals, for instance 15minutes. This will indeed allow for the simulation to run faster. At the moment, a good workaround is to to create a custom file with 15 minute data.
  13. Hi PVSYST Team, Thank you for the implementation of the sub-hourly simulation feature in PVsyst 8.1. It is something many of us have been waiting for. I am currently trying to generate meteorological data with a 15-minute resolution using different sources in PVsyst, and I have tested the following approaches: Pull with Meteonorm 9: it seems to only allow hourly data or minute-level data. While minute data could technically work, generating datasets at that resolution can become quite heavy and time-consuming for large projects with complex topography. Synthetic data generation: https://www.pvsyst.com/help/meteo-database/synthetic-data-generation/execute-generation.html From what I can see, this option also only allows hourly or 1-minute frequency. At the moment, the only way I have found to work with 15-minute data is by using the “Import a custom file” option. With the new import tool it is possible to specify a 15-minute timestep, which works well if the dataset already exists externally. My question is the following: Is there any option within PVsyst meteo databases (e.g., Meteonorm or tool synthetic generation) to directly generate sub-hourly data with a specific timestep such as 10, 15, or 30 minutes, instead of only hourly or 1-minute resolution? Or is importing a custom dataset currently the only workflow for these intermediate time resolutions? Thanks in advance for any guidance.
  14. Hi Robin, Thank you for your quick awnswer, do you maybe have an contact by Huawei for these kind of issues? I would think that if PVSyst contacts them the issue will be resolved a lot quicker. I expect it to take a long time for the information to end up at the right place if I would just contact the general Huawei support. Kind regards,
  15. Yes FShdBm = beam shading factor. FShdBm < 1 indicates that beam (direct) irradiance is being reduced by shading. 1.0 = no beam shading 0.95 = 5% beam shading loss 0.00 = fully shaded from beam irradiance ShdBlss = beam shading loss value. ShdBlss > 0 indicates a non-zero beam shading loss, so this also means shading is occurring. 0 = no shading loss
  16. Hi @Michele Oliosi, I am happy to see that you have implemented some changes in the new version! Could you clarify - is the modified coefficient Perez model and the Engerer2 model only used for 1-minute and/or sub-hourly data? Would it not make sense to also enable the new models for hourly data, and to add DIRINT as well. In your announcement, you say that "[the Erbs model is] based on a single clearness indicator, [and] is considered to have sufficient accuracy for hourly simulation. However, at shorter timescales, it fails to capture fast phenomena such as cloud enhancement and results in a systematic discrepancy compared to real measurements." This is only part of the problem with the Erbs model. It also can perform poorly under very clear skies, i.e. steady atmospheric conditions without fast phenomena, by simply overestimating the atmospheric turbidity. In this case it would make sense to add the DIRINT or DIRINDEX models, even for hourly data.
  17. @Linda Thoren Just so I'm clear, can you elaborate on the significance of both terms? What do the values for FShdBm and ShdBlss mean? For capacity testing should the values of ShdBlss be zero? What happens when you get values > 1? is that just a simulation error? it makes sense to me that 1 would correlate to 100% shading. FShdBm = 1 means no shading?
  18. Dear Nikhil Lokhande Thanks for your feedback! As you correctly analyzed, the battery is currently shared across the whole system, between the final MV transformer and the injection point. You could find some very far-fetched workaround (splitting your system into two variants and upscaling your inverters so as to not clip and use a variable grid limitation to reintroduce the clipping after the battery), but I'm not sure about the reliability of the results you may obtain that way. We have planned for more options in terms of battery connection, but it won't be before the next major version at the very least. Secondary Reporting Observations: SLD Visualization: The single loss diagram is currently under heavy rework and should be available in the next major version. System Overview: The chargers (Dynapower DPS-500) are omitted from the primary System Overview tab, which focuses only on the grid-feeding inverters. As mentioned, the battery can only be set on the AC side for the moment, so it is not possible to simulate a system with DC-DC converters. Questions for the Community/Developers: Is there a workaround to "un-assign" a specific sub-array from the DC-coupled storage bus within the same variant? : Not for the moment (DC coupling is not possible either) If we must run two separate projects and combine the hourly data in Excel to respect the 2.49 MW POI limit, how can we best account for the shared "Grid Power Limitation" within PVsyst’s energy management logic? When applying the grid limitation to individual inverters during the simulation, PVsyst is dispatching the total value based on the estimated AC power of each inverter. You could reproduce a similar strategy if you split your system into two variants. run the two variants without grid limitation Compute the relative production of each system Compute the grid limit for each system at each time step based on the total grid limit and the relative production Use the possibility introduced with PVsyst 8.1 to import a time series for the grid limitation Run the simulation again with the grid limitation activated. You can also create alternative strategies to reflect your system behavior if needed (e.g : prioritize one side of the system for example).
  19. Hello PVsyst Team and Forum Community, I am currently modeling a 5.00 MWdc / 2.49 MWac utility-scale project in PVsyst 8.1.0 that utilizes a split-architecture. I am seeking guidance on how to accurately isolate storage to a specific sub-array or if this is a planned feature for future updates. System Architecture: Our design uses two distinct paths tied to a single 2.49 MW AC Point of Interconnection (POI): Path 1 (DC-Coupled): 4.364 MWp PV array connected via 4x Dynapower DPS-500 DC-DC converters to a 10 MWh BESS. This path uses 4x Solectria PVS-500 (1.992 MW AC total) bi-directional inverters. The ILR on this path is high (2.18) specifically to maximize clipping recapture. Path 2 (PV-Only): 0.641 MWp PV array connected to 3x Solectria XGI 1500-166 inverters (0.498 MW AC total). This path has no battery and should feed the grid directly. The Issue: In the current version (8.1.0), the Storage menu for DC-coupled systems appears to follow a "Global DC Bus" logic. I am unable to find a way to assign the battery and the DC-DC chargers exclusively to the DC bus of Sub-array 1 while treating Sub-array 2 as a standard PV-to-grid path. As a result, the simulation assumes the battery can "see" the excess energy from the entire 5 MWdc array, which does not reflect the physical wiring of the site. Secondary Reporting Observations: SLD Visualization: Even in 8.1.0, the Single Line Diagram tool does not render symbols for the battery or the DC-DC converters (chargers), making it difficult to present the architecture to stakeholders within the report. System Overview: The chargers (Dynapower DPS-500) are omitted from the primary System Overview tab, which focuses only on the grid-feeding inverters. Questions for the Community/Developers: Is there a workaround to "un-assign" a specific sub-array from the DC-coupled storage bus within the same variant? If we must run two separate projects and combine the hourly data in Excel to respect the 2.49 MW POI limit, how can we best account for the shared "Grid Power Limitation" within PVsyst’s energy management logic? Any insights on how to handle this "Hybrid" Path 1/Path 2 architecture would be greatly appreciated.
  20. Inverter/optimizer combination rules are directly sent by Huawei to PVsyst. Huawei's latest update indicates that this specific inverter can only connect to a total of two strings. As it seems different from what the data sheet in your screenshot suggests, I'd recommend that you contact Huawei to report the issue, and ask them to update their PVsyst database.
  21. Good morning, I think there is a bug in the Huawei rules for the new optimizers in the latest update. In PVSyst I'm not able to connect 2 strings of MERC-600W-PA0 optimizers on 1 MPPT while this is possible in the Huawei Smart design 2.0, so it should be possible. Please see the included image from Huawei Smart Design, and the fault from PVSyst. Kind Regards,
  22. Adding figures. This is the original appearance.This is after going to "by modules."
  23. When I read in the most recent PVC files provided by our CAD team, some of the trackers are treated as "polygonal fields" instead of trackers. What does this mean and what can I do about it? I see that there is an option to define the polygonal field "By modules" in the "Draw poly" tab but it's not clear what this does. Even if I check that box and define partitions, no modules appear in any of the graphical representations and the type of object doesn't change, so I don't know whether this has solved the problem. Unfortunately, our design team doesn't have time to investigate this thoroughly, so I'm looking for a solution that can be implemented within PVsyst. Thanks.
  24. for now in PVSYST8 2026 possible?
  25. Sub-hourly simulation Release note: Sub-hourly Simulation for Grid-Connected and Standalone systems The main feature of PVsyst 8.1 is the possibility to run sub-hourly simulations. It is therefore now possible to model a PV system with more accuracy. Several physical models have been adapted to this new time scale, as detailed in the next section. The granularity at which it is possible to simulate a project is directly that of the weather data file (.MET). To support this feature, it is therefore also possible in PVsyst 8.1 to import sub-hourly weather time series to generate sub-hourly weather data files. At this time, sub-hourly files can either be created by using the custom weather import or using the Meteonorm 9.0 DLL and choosing the `minute` option. All weather data files, independently of their time step, can also be used to run hourly simulations. A radio button, present both in the main project window as well as in the "Advanced simulation" window, allows you to easily switch from one granularity to the other. Sub-hourly simulations will correspondingly generate sub-hourly time series tables when using the "Output file" functionality. Hourly simulations retain the advantage of being much faster, since fewer steps need to be simulated. It is therefore recommended to run hourly simulations during iterative design phases. Sub-hourly simulations, which take longer to run, can be left for more final evaluations. Generally, small differences may appear between hourly and sub-hourly simulations. This is inevitable, since several physical models are nonlinear and are therefore sensitive to averaging in time. For the most part, sub-hourly models lead to small changes that can be considered small gains in accuracy. However, some models have required more work to ensure the accuracy of the simulation at all time scales (see section below) despite more important differences between hourly and sub-hourly calculations. Note also that the largest discrepancy, i.e., clipping effects, is still addressed in hourly simulations (since version 8.0) with underlying sub-hourly weather data with a dedicated correction. Improved physical models With the new possibility to run sub-hourly simulations, several models had to be adapted. The three main changes concern models that did not preserve sufficient accuracy when applied at sub-hourly scales. Release notes: Thermal model: PV module temperature is now computed using a transient thermal model for both hourly and sub-hourly simulations Weather data, custom file: new model to estimate diffuse horizontal irradiance from global horizontal irradiance. Dedicated coefficients for sub-hourly simulation are used in order to reduce the discrepancies with hourly simulations Transposition model: sub-hourly horizontal diffuse irradiance data with the Perez model now uses coefficients adapted to each time step. These adapted coefficients aim at reducing the discrepancies between sub-hourly and hourly simulations Each of these changes is detailed here below. Transposition model The default model used in PVsyst, the Perez model, relies on several weather data indicators (sky brightness, sky clearness, sun zenith angle), associated with a set of empirical coefficients, to decompose the horizontal diffuse irradiance into components that are to be transposed with different geometric rules. This decomposition leads to effective discrepancies when comparing corresponding hourly and sub-hourly time series. When studying an ensemble of sites across the globe, this granular discrepancy translates to a systematic discrepancy, averaging half a percent in terms of PV system yield. Since the empirical coefficients used in PVsyst (and in several other simulation software) have been fitted with hourly and quarter-hourly data, the sub-hourly results of the Perez diffuse decomposition using these coefficients can be considered biased. For this reason, a new set of coefficients, which corrects the bias observed over 113 sites worldwide, is used by PVsyst when running sub-hourly simulation with the Perez model. Note that the direct irradiance transposition also leads to discrepancies between hourly and sub-hourly simulations. While the exact cause is not yet understood, since the transformation is purely geometric, the sub-hourly simulation can be considered more accurate in this regard. Decomposition model When importing custom weather-data with only global horizontal or only plane-of-array irradiance, PVsyst must estimate the diffuse horizontal irradiance. This was done until now using Erbs model. This model, based on a single clearness indicator, is considered to have sufficient accuracy for hourly simulation. However, at shorter timescales, it fails to capture fast phenomena such as cloud enhancement and results in a systematic discrepancy compared to real measurements. To reduce this discrepancy, we selected a more flexible model from the literature, ENGERER2, whose additional indicators (clear-sky clearness, cloud-enhancement index, ...) allow one to represent sub-hourly dynamics more accurately. Similar to the adaptation of the Transposition model, we refitted the model coefficients to reduce the bias observed on the previously mentioned 113 sites dataset. Compared to Erbs, this new computation successfully mitigates the bias for all sub-hourly timescales. It also mitigates a small residual bias of the previous model at the hourly timescale. This small difference will slightly affect all irradiance loss components (IAM loss, shading losses, ...) affected by the decomposition of irradiance into components. Transient Thermal model In PVsyst 8.1, two layers of thermal models are used for the PV module: First, as in previous version, the thermal balance model outputs the steady-state temperature, represented by the PVsyst variable TArrSS. Second, a thermal inertia model uses the previously calculated steady-state temperatures to compute the actual transient temperature, represented by the PVsyst variable TArray. The user can modify the heat transfer coefficients and the mass of the module (affecting the thermal inertia) in the detailed losses and .PAN file menus, respectively. For hourly simulations of conventional PV systems, thermal inertia affects the production E_Grid by about ~0.1-0.3% annually. In particular settings, it can have a stronger impact. For example, if an inverter is designed to operate close to its over-voltage limit, production can be affected by 1-3 % annually, as the temperature change induced by thermal inertia mainly impacts the PV array voltage.
  26. Is it possible to set inactive panels? Is it possible to run a simulation for FIX when there is a tracker running above them? And get 2 simulations at the same time? This is also important at a global radiation level and not just in production - how do you do it?
  27. I want to run 2 simulations in parallel, one of a single-axis track at a height of 2 meters, and static panels on the ground, and I want to calculate detailed parameters for each of the cases - that is, to know how much radiation lands on the static panels, but the panels in the track work above them. How do I do that?
  28. Hello, Indeed filtering out these two variables should be sufficient to remain compliant with the ASTM 2848-13 standard
