Jherche Posted 22 hours ago Posted 22 hours ago Hello, I am running a PV capacity test per ASTM2848-13 and it is important to filter out any data where shading is present. I am struggling to interpret the shading losses per the 8760 outputs. I have FShdBm and ShdBlss. Is there shading whenever FShdBm is < 1 and whenever ShdBlss > 0? Should I use any other 8760 outputs or is this sufficient? Thanks.
Linda Thoren Posted 1 hour ago Posted 1 hour ago Hello, Indeed filtering out these two variables should be sufficient to remain compliant with the ASTM 2848-13 standard
