ShivamPandey Posted October 9, 2025 Posted October 9, 2025 If we need to connect 6 strings of 15 modules to three MPPT inverters, which option should we use between Power sharing between MPPTs and within the inverter Should we choose independent MPPTs and or a single inverter with power sharing within the inverter? Technically, no power sharing will be done as all MPPTs havethe same amount of power, but does choosing between these make or create any difference in simulations or productions?
Linda Thoren Posted October 10, 2025 Posted October 10, 2025 Hello, If all the strings have the same length you can indeed use the Power sharing within the inverter. The two options should give the same result.
