Fotini Proko Posted March 15, 2025 Posted March 15, 2025 (edited) Hi, for bifacial systems, is it possible to use Unlimited Sheds in the 3D scene? Also, when I use Fixed Tilt, I get results very similar to monofacial systems. Does this mean Fixed Tilt is not suitable for bifacial systems? The information provided suggests using Unlimited Sheds or trackers-does that mean Fixed Tilt doesn't properly account for bifacial gains? Edited March 15, 2025 by Fotini Proko Privacy issues
Linda Thoren Posted March 18, 2025 Posted March 18, 2025 Hello, The Unlimited Sheds field type in the orientations management cannot be combined with the 3D scene, since you already will define layout parameters such as the number of tables, pitch etc. You can indeed define a fix tilt plane and instead define the layout in the 3D scene. The model that will calculate the bifacial gain is 2-dimensional calculation - similar to the unlimited sheds orientation and the layout parameters needed can be defined in the 3D scene or in the unlimited sheds in the orientation window.
