Mike99 Posted January 21, 2025 Posted January 21, 2025 Hi, When I tried to import standard format CSV file into PVsyst, I'm getting the following error. Not sure what is the issue with my file. I'm saving the excel file as .CSV by using the save as option CSV(MS-DOS). Thanks,
Mike99 Posted January 21, 2025 Author Posted January 21, 2025 Just want to provide what is the last line in the CSV file. I have commas till the end of the file.
Linda Thoren Posted January 22, 2025 Posted January 22, 2025 Hi, If you have own measurements, please import them as a Custom file, there you can import a file with any separator or date format.
Mike99 Posted January 22, 2025 Author Posted January 22, 2025 Hi Linda, Actually after deleting all the commons at the end of the CSV file, I was able to create .MET file. When I check the graphs of the data versus clear day model. I have best clear days ktcc within 10%, not every day is in within 5% as suggested in Weather data Note 6, I'm wondering if I can still use those days with a ktcc index higher than 5%? I'm also attaching the all other 3 graphs for reference. Thanks,
Michele Oliosi Posted January 24, 2025 Posted January 24, 2025 It's difficult to say whether it's useable or not, there could be some cloud enhancement effect for example. Some locations also have higher extreme Ktcc values. But at the very least, it raises the question of the calibration of your sensors. If possible, I would suggest looking at possible problems on the hardware and data collection side. But before this, I would suggest correcting the time shift (as noted 61 minutes of time shift are found) directly in the file. As noted here: https://www.pvsyst.com/help/meteo-database/import-meteo-data/pvsyst-standard-format/index.html you can use the tags: “#Hour Shift;" and “#Time Shift;” to apply the time shift when importing. This may improve the results of the import.
