JoaoReis Posted November 25 Posted November 25 Hello, In PVSyst 8.0.2, when defining a layout in the 3D scene, on a mountain with different orientations, I got the error as shown in the attached image. This error only appears when I use a tracking system. This error does not exist when I use fixed system. Can anyone help me solve this?
Linda Thoren Posted November 26 Posted November 26 Hello, Indeed, with PVsyst version 8, automatic mode for diffuse shading calculations for systems that involve trackers has indeed been removed. Now, users are required to manually define a representative tracker for diffuse shading calculations. You define a representative tracker by clicking “Tools”, “Trackers diffuse shading definition”. In this tool you can choose to calculate the diffuse shading factor for all trackers, or select a representative tracker that will be used to evaluate the diffuse shading factors You can find more details about this update and instructions in the PVsyst Help documentation here: PVsyst Diffuse Losses with Tracking Systems. Kind regards
