Oliveira Posted October 21, 2024 Posted October 21, 2024 Hello, I hope you are well. My question is, I wanted to expand an existing solar system, at the moment there are 8 , 480Wp modules with a 6 Kw inverter with only one string used. I now wanted to expand the system with newer 580Wp modules up to the maximum of this inverter. But I don't understand how I do this in the software, inserting 2 different modules for the same inverter. Thank you
Linda Thoren Posted October 22, 2024 Posted October 22, 2024 Hello Oliveira, This can be done by creating a second sub-array (see the list of sub-arrays to the right in the system window) and use the multi-MPPT feature. Please see the tutorial below about how to create several sub-arrays and how to use the Multi-MPPT feature.
