Hillary123 Posted September 19, 2024 Posted September 19, 2024 Hi, I am generating an 8760 and would like for it to only include positive generation values (no consumption during night time hours for any reason). I have turned off the auxiliary losses all together, but I am still getting negatives. What other losses are causing these negative values? Is there any way that I can avoid having any negative values all together? Ideally, I would like to 8760 to reflect generation losses due to daytime auxiliary losses (or any losses that are a result of using the sites own power production to cover electricity needs), but i do not have to reflect losses due to pulling electricity from the grid. Is this possible?
Linda Thoren Posted September 20, 2024 Posted September 20, 2024 Hello, If you have defined a transformer that is not disconnected during the night, the negative values could possible come from the Transformer losses. Transformers have a constant iron loss, even if no energy is being produced. To avoid this, you need to enable 'Night Disconnect', in the Ohmic Losses window.
