Vera Posted December 5, 2023 Posted December 5, 2023 I'm currently conducting different scenarios to assess module mismatch losses and their impact on specific production when trackers are positioned on a hill. The outcomes of these simulations are provided below. How can I connect trackers in series within the shade scene? In theory, the section with the lowest production should regulate the current and constrain overall production. Fixed Tilted Plane Specific Production (kWh/kWp/yr): All Panels Horizontal: 1804 All panels at 5° to north: 1721 Panels curving toward the north: 1764 Tilted Tacker Specific Production (kWh/kWp/yr): All Panels Horizontal: 2521 All panels at 5° to north: 2465 Panels curving toward the north: 2515 Thank you!
Michele Oliosi Posted December 7, 2023 Posted December 7, 2023 Hi, You should use the module layout tool (detailed electrical shading calculation), which will estimate the electrical shading losses by adding the IV curves of each submodule. In such a way, you will be defining all these 3D scene modules by their string and inverter attribution.
Vera Posted December 14, 2023 Author Posted December 14, 2023 Thank you for your response. Upon employing the module layout tool to specify the 3D scene modules, I'm observing no variation in the simulation results for the specified production. This seems illogical because the lowest production should control the current and constrain the specified production.
Vera Posted December 14, 2023 Author Posted December 14, 2023 How do I use this in the simulation? every time I exit out of the module layout tool it resets and the calculated specific production hasn't changed after the the modules are defined.
Michele Oliosi Posted December 15, 2023 Posted December 15, 2023 The shadings seem really negligible, because even on 21st of December (worst case), you have only 7.5% electrical loss. You mention, “the lowest production should control the current and constrain the specified production”, this is not necessarily true, thanks to bypass diodes. I think in this case, the bypass diodes are mitigating part of your electrical shading losses. The blue message in the module layout tool is a bit misleading. What it should mean is that you can optionally review the shadings at specific days in the year (assuming clear sky conditions) using the “Shadings 3D” tool. This tool is however just for review. What matters in the end is validating the module layout assignations (you don't need to go to the “Shadings 3D” tab at all if you do not want to review), and running a simulation. You can check that shadings have been computed according to module layout definitions in the simulation report.
