Estagiario Posted September 4 Share Posted September 4 im only using 4 out of 5 mppt, and in "number of inversor" is just 0.8, not even a full inversor, does it make diference on the simulation?? Link to comment Share on other sites More sharing options...
André Mermoud Posted September 4 Share Posted September 4 I don't understand well. Your system defines indeed 5 MPPT inputs (1+1+2+1). Are you sure that your inverter is defined with 5 MPPT inputs (this is not in the PVsyst database) ? It probably defines 6 MPPT, so that the number of inverters is 0.83 (with one only decimal). The simulation will work correctly. The only effect would be the possible overload losses, as it is not possible to use the Power sharing option with incomplete inverters. Link to comment Share on other sites More sharing options...
