C. Amorevole Posted April 17 Share Posted April 17 Hi PVsyst, I wish you help me solving the following problem: operating on the 3D scene there is the following screen: I thought to solve the problem working on the "Orientation management" in the 3D scene, but it is an option deactivated: Where may I operate in order to correct this issue? Thank you in advance for the help Link to comment Share on other sites More sharing options...
Michele Oliosi Posted April 17 Share Posted April 17 Hi, The Orientations management works in the fixed tilt tables case, but not for trackers. At the moment in PVsyst, you can have only a single tracker orientation. If you want to proceed by considering the average tracker angles nonetheless, you can change the following advanced parameters (home window > Settings > Edit advanced parameters): This should help you bypass the error. Link to comment Share on other sites More sharing options...
