Panch Karasani
In the Near Shading Tab, when computing the shading factor table i notice that when going from higher Pitch E-W to a lower one induces some shading at low heighta even with backtracking enabled. But then i go back into the construction perspective again and i close it out without changing any of the fields and recomputed the shading factor table, the shading in the low heights is not there anymore.
Is this a glitch on PVsyst? If it is, It would be greatly appreciated if this can be taken, as i would have to run shading factor table twice every time i run simulation going from higher pitch to a lower pitch.
Than k you,
Link to comment
Share on other sites
On 9/9/2022 at 2:30 AM, Michele Oliosi said:
Dear @Panch Karasani
Did you try this with the latest version 7.2.18 ? I believe this bug has been corrected (it is a bug indeed), but if there are still some cases that are uncovered we will fix them asap.
Thanks in advance
Hello Michele Oliosi,
That great to hear, thank you. I have not tired the latest version yet, hopefully that resolves the issues.
Link to comment
