Include 'half-tables' option in Zone editing
jax595
When creating a 3D shading scene, you have the option to fill zones with tables of solar, and you can determine things like the panel tilt, number of panels, portrait or landscape etc.
A feature which I think would be advantageous would be if there was an option to click "include half tables" so that when you fill an area with tables, it will add in a half table at the end of a row if there is space.
I regularly use PVsyst's shading scene to get a quick idea of how much solar can fit in a given area, and often find myself using the Zone editing function, then manually going in and adding in half tables, which can take quite a bit of time.
Of course, this only works if your tables are an even number of panels wide (say you had 2x18 tables, you could have 2x9 half tables for example). Not sure if this might be a coding nightmare for you guys, but thought I'd just at least suggest it as I thought it would be useful to have - thanks! ?
