bendesa1962 Posted June 28, 2022 Posted June 28, 2022 (edited) Hi, I keep on running into this error message. I know what it means but I can't just remove it. If I'm correct it means that the number of PV Modules defined in System does not meet the necessary area in the Near Shading part of the software. More specific the total area defined in the rectangular PV Plane area's is not enough for the panels defined in System. Ok that sounds logical. My first question is: If you choose for defining the rectangular size by the option: By modules how is it than possible to get this error message. The modules is know by PVSyst and also shown in the window of rectangular field. You let the program know 20 PV Modules in length and 5 in height. You also give in the X and Y spacing. The software is calculating the area by itself. But actually it's calculation is wrong because I get the error message? Second question: If you choose for defining the rectangular size by the option: By sensitive sizes I have defined 5 PV rectangle faces 4 have the same size for PV Module landscape 20 in length 5 in height I gave the rectangle the dimensions of 6,00 x 46,00 The size of the panels is 2,279 x 1,134 X spacing 0.02 Y spacing 0.02 So total size needed 20 x 2,279 + 19 x 0.02 = 45,96 5 x 1,134 + 4 x 0.02 = 5,75 So that must fit in the defined PV Area 6,00 x 46,00 The 5th PV Rectangle has the following dimensions 12,00 x 37,00 PV Modules Length 16, 10 in height The size of the panels is 2,279 x 1,134 X spacing 0.02 Y spacing 0.02 So total size needed: 16 x 2,279 + 15 x 0.02 = 36,76 10 x 1,134 + 9 x 0.02 = 11,52 The total number of panels defined in System is 560 The total number defined in Near Shading is: 20 x 5 x 4 = 400 16 x 10 = 160 Total 560 Where do I go wrong? Many thx for your contribution Kind regards Ben Edited June 28, 2022 by bendesa1962
Michele Oliosi Posted June 28, 2022 Posted June 28, 2022 Hi, Actually we check the areas orientation by orientation. Hence, it is really important that the orientations are well assigned in the system part. First of all, you can choose either to use the mixed orientation on a single sub-array. Or split into two sub-arrays, one assigned to each orientation. - Mixed orientation: at the bottom of the system window, you should assign strings (using a scrollbar) to this or the other orientation. Make sure that the number of strings has been assigned correctly (wrt the 3D scene) - Subarray per orientation: be sure that the orientations are well assigned. This is done at the top left of the system window. If you still experience issues, you can send us the project at support@pvsyst.com, we'll be sure to check it out. You can export a project via the main window > File > Export projects.
bendesa1962 Posted June 30, 2022 Author Posted June 30, 2022 Hi Michele, Thank you so much for your fast reply. I'm going to look into that Kind regards Ben
fbernard Posted August 17, 2022 Posted August 17, 2022 Hello, I currently have the same kind of trouble. I have 3 differents orientation. Orientation 1 : 0° 38 PV installed Orientation 2 : 90° 399 PV installed Orientation 3 : 180° 38 PV installed But I have only one error message about the orientation 1 about the 3D scene is consiedred lower than the system size. Why only on orientation 1 when 1 and 3 are the same size ?! Thanks for your help.
Lazare Fesnien Posted August 17, 2022 Posted August 17, 2022 Bonjour, Vous avez défini trois orientations avec des surfaces de module PV. Dans votre scène 3D, la surface définie pour l'orientation 1 est beaucoup plus petite que celle définie dans l'onglet système. Pour débloquer cette situation vous devez mettre en cohérence ces deux paramètres. Bonne simulation
