The *.SHD files are meant for internal use in PVsyst only. We don't provide any description nor ensure maintenance about these files, which have a very complex structure. You can import CAD files from diverse File formats (.DAE, .3DS, .PVC). See the help "Project design > Shadings > Near Shadings: Import "
Please give some more information: - which Inverter model ? - How many strings on each input ? - Which PV module model and how many inseries ?
In PVsyst, the "1990" year is an indicator that the data are not real data fo9r a specified year. See the FAQ "How to obtain meteo data other than for 1990 ?" The Meteonorm data represent averages of at least 10 years of measurements. The period is mentioned in the data. For getting values corresponding to each year of your measured data, you should avail of the corresponding Meteorological data. You can take the ageing of the plant into account by using "Detailed Losses > Ageing" in the project's dialog. You have a tool for simulating the 15-25 operating years in the project's dialog "Advanced simulation > Aging tool". Here you may simulate your operating years with the same Meteo data, or specify a meteo file corresponding to each of your years. You can import your measured data. And even directly compare them to the simulation, using the "Measured Data" button on the main page.
Saving .pan files from PVsyst 7 to pvsyst 6.40
André Mermoud replied to iqbal11's topic in Problems / Bugs
We are indeed preparing a way of saving PAN and OND files in a format compatible with old versions. However in the mean time, for reading a file of V 7 in the versions >= 6.80, you should replace the line Version=7.0.6 by Version=6.80 -
Thank you for your perspicacity. We will correct this in a next version.
OK, well noted. We will suppress this stupid behaviour in batch mode. And put an option for suppressing it also in other situations.
On August 5th, 2020, the web access to the interactive map has been changed by the providers without notice, so that all PVsyst versions cannot use this service anymore. We had to publish a new version 7.0.7, as well as a version 6.88, for reading this service. Therefore the only way of getting the interactive map is to update your PVsyst program to these new versions. However please notice that this Interactive Map is a "comfort" tool, it is not necessary for creating a new site. You can do that by opening the first page "Geographical coordinates", and define explicitly the Site name, the country and the GPS coordinates. Then you import the meteo data in the same way as previously.
adjustment of modules in imported plots (Helios3D eg...)
André Mermoud replied to tecnun's topic in How-to
This is done in the "Module layout" part. You can put your modules in portrait or landscape, and attribute each string to inverters with a great variety of strategies. -
In fact in this tool, we don't need the full one-diode model as the addition of I/V curves is only done at STC values. Therefore PVsyst simply performs a scaling of the I/V curve in voltage and current, with respect to the original model. This is an approximation, however probably largely sufficient for such an "uncertain" random calculation.
Cannot import a workspace zip file of V6.73 to V7.0
André Mermoud replied to WichienTep's topic in How-to
I don't understand well. If your customer has sent a project in a Zipped file, you have to import it by using the main menu option "File > Import projects". This option cannot return a message "This Zip file does not contain a PVsyst Workspace" -
This option of mixing different orientations in a same string is indeed only possible with optimizers. However this is not yet implemented in PVsyst.
The measurement of modules temperature in a field is a delicate operation. To my mind, just gluing the sensor on the backside of the module is not quite correct. The layout of the measurement is very important. Remember that a temperature sensor always measures its own temperature ! See our FAQ "How is evaluated the Module temperature during the simulation ? ". At the end of this post you have a paragraph with our advices: "PV array temperature measurement" Now PVsyst doesn't use the Sandia or NREL thermal model. It proposes a model in which you can adjust the "Thermal Loss factor" (U-value) in order to match you measurements at best. Please read the help "Project design > Array and system losses > Array Thermal losses". NB: expressing temperature differences in terms of percentages doesn't make sense. Percentage with respect to what ? If it is 0°C, this doesn't have a physical meaning. The reference could be anything else (25°C, -273°C, etc) The only way is to express the temperature differences in terms of °C.
it is strongly discouraged to put modules of different orientations in a same string. And especially in 2 opposite orientations. This leads to very high mismatch losses (the current in the string is the current of the worst irradiated module in the string, therefore almost nothing in the morning and the evening). PVsyst doesn't allow to do that. The only way would be to use optimizers, which overcome this problem of currents mismatch. However this is not implemented in PVsyst yet.
If your original data are measured in the horizontal plane, for calculating the GlobInc, you have to use a transposition model. You can use PVsyst for that. - Import your Irradiances data file using "Databases > Import Meteo Data > Custom file". When you are here press F1 for the procedure. NB: PVsyst only works in hourly values. During the import process, it will accumulate your minutes data into hourly values. - In "Databases", open "Meteo Tables and Graphs". Here you can see a table of all your data in hourly, daily or monthly values. You can get the values "Global tilted plane", which is indeed GlobInc or POA.
Portrait VS Landscape configuration. Electrical losses
The position Portrait vs Landscape only affects the electrical losses. Any other discrepancy has probaly another cause. The electrical losses may be calculated: - either using the shading mode option "According to module strings". In this case for sheds or trackers arrangement you should use "Fraction for electrical effect" = 100%. In you "landscape" case, when you have 2 strings on 2 rows, you should define 2 sub-ectangles in the tables. - or using the ModuleLayout option. In your case the rigorous comparison is not possible as the sheds width is about 4 m in 2L, and 1.6 m in 1P configuration. You should keep the GCR constant (adjust the pitch). However the IAM and transposition should be identical. You have probably something different in your layouts. By the way you should only compare the electrical losses. -
PR corrected calculation (no PVSYST software related)
André Mermoud replied to vincenzo_diana's topic in How-to
For the calculation of the weather corrected PR, you need indeed the array temperature, but in hourly values. The expression proposed by the NREL supposes an accumulation/calculation with hourly values. NB: This calculation is done in PVsyst. You can get it under the variable named "Weather corrected PR", i.e. PRTemp. You can show it on the report, by using in the Report's dialog menu: "Settings > General Options > Monthly values table". Here you can choose "Weather corrected PR". -
Simulate use of Y-plug (extra parallel strings) in pvsyst
André Mermoud replied to Mrodriguez's topic in How-to
The use of Y-connectors is not involved in PVsyst in any way. With some inverter, the number of input connectors is specified. But this is not used by PVsyst. The only relevant information is the number of strings effectively connected to the input of each MPPT input. PVsyst doesn't check if this matches the number of connectors. For the use of the option "Use multi-MPPT feature", please read the Help "Project design > Grid-connected system definition > Multi-MPPT inverters: power sharing" -
The mismatch effect is calculated by adding the I/V curves: - In the string (modules in series) we add the Voltages - In the array (several strings in parallel): we add the currents of each string. Now the result of the mismatch loss is the difference of the Pmpp of the complete array curve with respect to the Pmpp of identical modules. The position of the Pmpp (voltage or current) on the curve is "unpredictable". Sometimes you can have 2 different maxima on the P/V curve. This is deeply explained in the tool "Project's dialog > Detailed losses", page "Module quality - LID - Mismatch", button "String voltage study > Detailed study". Especially the first option "Mismatch: General principles". Here you can press F1 for an explanation of the mismatch issues.
This is indeed a delicate question. The PR is defined on the basis of the GlobInc value (i.e. irradiance in the collector plane, also named POA for "plane of Array"). Therefore is seems natural that for the PR evaluation, you measure the irradiance in the POA. However be careful to put your solarimeter in front of your installation (on the first shed), or eventually significantly above, otherwise it will not "see" the albedo contribution, and may have some shading on the diffuse from other sheds. NB: Even if the albedo is not "seen" by the sheds behind, it should be part of the "official" GlobInc. This is taken into account in the transposition model and simulation. But it can also be interesting to measure the irradiance in the horizontal plane, with a solarimeter positioned sufficiently high. In this case you have the uncertainty of the transposition model for obtaining the GlobInc value. However this is more comparable with usual Meteorologic data. Moreover this is valid if you have several plane orientations in your system, for which you will have "transpositions" calculations suited for each orientation. For tracking systems, many people use to position the solarimeter on the axis. In this case the mutual shading of trackers (on the diffuse and albedo) are not part of the measurement (i.e. the measurement is affected by this shading), but they are accounted in the simulation process. Therefore this POA value is not really the waited value for the simulation. In the present time PVsyst doesn't give the opportunity of suppressing the mutual shadings calculations (usually a loss of the order of 2-3%). We should do that in a next version for simulating systems from this measured (but erroneous) POA value. Without this correction, when you resimulate your system the E_Grid will be lower, as the Shading loss is accounted twice. Therefore for comparing this E_Grid to the E_Grid provided by your original simulation, you should multiply it by (1 + ShdLoss[%]/100). The PR that you directly calculate from your measured data is PR_meas = EGrid_meas / (PNom*GlobMeas). However for comparing it to the "real" PR originally calculated using GlobInc, you should use PR_meas = EGrid_meas / (PNom * (GlobMeas *(1 + ShdLoss[%]/100) ).
Defining the south at top in the southern hemisphere is a choice of PVsyst. This is natural as the installations (tables) are oriented towards north. In this way you see them from front. If you define the north at top, in the perspective views you will see the PV installation from its rear side.
No, only global values for the whole system are outputted by the simulation.
