Chen
Everything posted by Chen
  1. Dear PVsyst team: when some solar cell is partial shaded,how to calculate its temperature as shown in the following figure, thanks!
  2. Hi PVsyst team: Did we do some studies about the temperature and convective heat transfer characteristics of PV module due to the different array pitch,or different array tilt angle,or fixed tilted installation horizontal axis N-S installation. such as the pitch of 1# array is 4.5m, and the pitch of 2# array is 5m, in my opinion, the Uc and Uv coefficient will be different for the two array modules. meanwhile,choosing different sopport for photovoltaic modules can also have an impact on the temperature of the modules. Will future software consider these intricate factors? thanks
  3. Thank you very much for your help Regards!
  4. "Imp RMS dispersion are not comparable to a degradation factor. You should first translate into a degradation of the Pmpp. This is done stochastically by PVsyst". sorry, I still feel very confused for this topic. Can you clearly tell users how to operate and take values of Imp RMS dispersion ? Should we take 0.4% by default or other values for Topcon or HJT /IBC different solar modules?Or is there any relevant basis to support filling in this data. thanks!
  5. The Average degradation value obtained from the the module warranty interface is 0.38%/ year. Is 0.38% used in the PV module ageing parameters input settings interface?should we change 0.35% to 0.38%?thanks!
  6. OK,we assume that the degradation given to the user is achievable, that is, in the first year, each solar panel power degradation will not exceed 1%, and starting from the second year, the maximum degradation per year will be 0.35%(the minimum degradation is 0%). According to the upper limit of warranty. "maximum average degradation factor"="1/2 of yearly warranty"="0.175%", right? So at the end of the first year, the minimum power of the module is still 99% of the initial level, and at least 98.65% at the end of the second year, can the average degradation rate from the second year be equal to 0.35%? The worse possible annual degradation rate we assumed in the warranty is 0.35%. "Average degradation factor"+2*"Imp/Vmp RMS dispersion" < "The worse possible annual degradation rate (the upper limit of warranty is 0.35%) " ; so that "Imp/Vmp RMS dispersion"="0.0875%" ,( 0.35% - 0.175%)/2= 0.0875% Thanks for your time!
  7. The 2 sigmas is approximately 65.26% of the hits?
  8. Dear PVsyst team: For the distribution choice is limited to 2 sigmas (95% of the hits) of ageing parameters setting. if there is a clear warranty statement for the annual degradation rate of photovoltaic modules, such as maximum degradation rate 0.35%/ year,maximum 1% for the first year. The slope of the warranty is 0.35%. Can the Im or Vm RMS dispersion be set to 0.35/2 = 0.175 %? thanks!
  9. Hi PVsyst team: Since the modules of new technologies (IBC / HJT) exhibit a very high Fill Factor. so the main contribution to this increase is the VMPP/ VOC ratio more than 86% , and resulting in lower RS(MAX) and poor low light performance. Will your team consider high fill factor module technology in future PVsyst versions? thanks!
  10. the problem is :the value of BRev is limtted to 50 in the PVsyst8.0.8
  11. Electrical shading: a tool used to analyze the impact of extremely low voltage reverse photovoltaic cell characteristics on shading losses. It seems that it doesn't work in version 8.0.8. Can you check it? tks
  12. Hi, PVsyst team: As in the past year or two, there have been some new solar cell technologies in the photovoltaic industry, such as BC cells. Photovoltaic leaders Longi and Aiko are both researching and selling them. Can the current PVsyst model simulate the yield performance of this solar module well, especially the advantage of local shadow shading promoted by manufacturers, especially in mountainous areas, distributed roofs, wind and solar complementary scenes, etc. This advantage is due to the BC's lower breakdown voltage.. If his performance cannot be well simulated, are there any other reference methods ? thanks!
