Michalis Angeli
Everything posted by Michalis Angeli
  1. sorry, but i want to ask something else about this topic. On my pv panel's datasheet there is the below table. So the global degradation factor on Pmpp is equal to Temperature Coefficents on Pmax ??
  2. Okay, thank you very much!
  3. Thank you!
  4. Thanks for your answer, however which are the best values for mismatch to insert? Because as i saw in a tutorial from PVSYST on Youtube for Aiging gives Imp RMS degradation equal to 0.6%/year and Vmp RMS degradation equal to 0.5%/year. Should i keep that values in my simulation ?
  5. I want to ask, how can i calculate the global degradation factor on aging dialog in order to define it correctly. And wich is the deference with aver. degradation factor?
  6. I would like to ask, if the option Self-Consumption refers to Net Metering Sytems, with self consumption ??
  7. With air crculation, you mean natural air circulation or forced air circulation by motor? If i have an installation in a tiled roof, i check the option Fully Instalated backside? Thank you!
  8. I would like to add this pv module to database. I want to ask if i should define the global degradation factor on Pmpp an degradation sharing of Imp as you can see on the picture, below.
  9. I would like to ask, in dialog aging of Detailed Losses which are the best values to set for Imp & Vmp RMS when i use monocrystal silicon panel ?
  10. I would lke to ask, in what type of installation does "Semi - Integration" refer to?
  11. I would lke to ask, in what type of fully insulated backside does refer to?
  12. Thank you very much for your answer.
  13. Okay, thank you very much. I thought that domes refers to a tiled roof, which has specific slope. Now it's clear!
  14. I have a project that has orientation unlimited shades, i would like to ask, if it is nesecary to check the option use electrical effect in simulation, and i would like to explain me what are these parameters. Thank you!
  15. Michalis Angeli
    DOMES
    I would lke to ask, in what type of installation do the "DOMES" refer to?
  16. In dialog Detailed Losses, we define the cable's length. But in our systems, we don't use main box, so we connect directly the dc cables from pv panels to inverter. So the question is: could i keep the length and section of this cable equal to zero?? Or there is somethnig else that i should do for this case? Thank you!
  17. Can you explain to me which is the different between these types of free-standing (open-rack) systems, fully insulated backside (semi-integration, air duct below the collectors) domes, a manufacturer has measured the U-value on several installations (height about 40 to 70 cm above the ground). Actuall i would like to know how to consider the factor Uc and Uv for an installation on a tiled roof. Thank you
