  2. Dear PVsyst team! Please tell me how to calculate losses in DC and AC cables ?
  3. Yesterday
  4. Is there a way to use mixed orientations with numbers different than #1 ad #2?
  5. If you have multiple sub-arrays, you can define individual parameters for each sub-array by using the drop down list in the top of the window
  6. How can I enter the cable length for each line separately? My calculations show 12 lines for panel 18 and 2 lines for panel 19, but it doesn't show up here?
  7. Now how can I enter the length and cross-section of the cable for each string? I can't enter values here, the cell is not lit.
  8. For certain scenarios it is not yet implemented, such as for multi orientation daily sharing. In the case in your print screen it is probably because you do not have a multiple between the number of strings and MPPTs in the second sub-array. You should have an orange warning in that sub-array indicating this. You should here create an additional sub-array for the strings of 19 modules, one sub-array with 2 strings and 1 MPPT and a second with 1 string and 1 MPPT. This is further explained in the following youtube video:
  9. Hello, This can be done in the detailed losses window, Ohmic losses tab.
  10. Why sometimes my SLD doesn't light up even though there are no errors in the system?
  11. Good day everyone! How can I enter data to calculate cable losses?
  12. Getting high quality irradiance measurements in the field can be difficult and the two main sources of errors we see from our users are: Shaded sensors, especially for trackers. This can be identified by comparing your data to clearsky expectation on good weather day, and looking for unexpected decreases. The pattern should repeat from one day to the next. Sensor misalignments, either in azimuth or tilt (or both). Even small discrepancies have an impact. If you can easily download POA irradiance from solargis, chose a clear day and download data for several azimuth and tilt values around your expected geometry. Then check if one of the alternative geometries fits your measured data better. If your sensor is misaligned, you can still use the data in PVsyst as we first decompose POA irradiance into GHI and DHI. You just have to use the real tilt and azimut when importing data.
  13. Last week
  14. Dear all, I am reaching out whoever can help me with this topic. For several projects for which I am assessing the meteo data, there has been a potential misalignment between the on-site plane of array irradiation data registered by sensors (such as pyranometers or solarimeters) and Solargis satellite data. For this reason, I am questioning whether such occurrence has ever been encountered by someone else and if so, what has been the take-away. I am open to discussion on this topic. Thank you and best regards, Vinh
  15. I would like to emphasize the point that in fact Erbs can lead to bias even on hourly time scales! I recently came across this again using diffuse data from DIRINDEX and comparing it to Erbs, i.e. standard PVsyst decomposition. In the winter months in this particular location the Erbs model led to a bias in the monthly sum of diffuse irradiance of between 10% and 18%, i.e. Erbs massively overestimated the diffuse fraction. So it is not only applicable to sub-hourly data.
  16. Dear Carlos, We don't have any specific procedures or instructions regarding existing plants. If PVC format is not available, DAE or 3DS can be used. Then on the import screen you can select the "material" that is used for your trackers and you can define the tracking parameters there. Also for the terrain, you can select its material and PVsyst will import it as a ground object. Here is the link of our help page for importing 3D file, where you will find more details: https://www.pvsyst.com/help/project-design/shadings/near-shadings-import/sketchup-and-other-cad-software.html#scene-details
  17. Dear Pattarporn, don't hesitate to email us your project at support@pvsyst.com so that we can replicate the issues and try to help you.
  18. This looks like an AI bot or something...
  19. Hi, I usually build the 3D scene for new ground mounted projects using a commercially available tool that exports the layout as PVC file and direct imports into PVsyst 3Dscene. this is very fast and useful for trackers. but now I want to evaluate the near shadings of an existing plant (with trackers) with the drone scan and Metashape postprocessing. How do I "assign" the tracker characteristic's to the imported object? is there a preferred file format for pv objects, shading objects and terrain? is there a recommended procedure for this real 3d Scene mounting on PVsyst? is there a recommended software or tool?
  20. Hello, I have run PVsyst 8.0.15 for one project, a Solar Rooftop, and encountered the following issues: Running PVsyst with 3D or Near Shading enabled takes approximately 1 hour and 30 minutes, even though the 3D model does not contain any complex structures. I have therefore set it to run in Fast mode. How can this issue be resolved? In the Detail Loss section, I set the Soiling Loss to 3.5%, and the report correctly shows 3.5%. However, in the Loss Diagram, it displays as 3.25%. How can this discrepancy be corrected? Since I ran the 3D simulation, and the site is expected to have significant shading based on the site survey, I was surprised to find that the Near Shading loss is displayed as a positive value in PVsyst. How can this occur, and is there a way to adjust the settings so that the value appears as negative?
  21. @sauld no you are right, there could be some losses that would be missed by this approximation. Unfortunately this is a compromise, because currently MPPTs can only receive identical strings in the System definition in PVsyst. However for most cases these losses are rather small. The most important is the string to string mismatch (usually shading effects are even smaller because you need a very specific shading pattern for the multi-MPPT to help). You could add an estimate of these losses to the mismatch losses manually. You can estimate them using a tool found from Home window > Tools. There is a similar discussion here (see the last answer by my colleague Luca):
  22. Thank you Jérémie for your promot reply...
  23. Hi! Yes E_Grid is an "active" energy/power. You can find explanation about active, reactive and apparent energy on the page: https://www.pvsyst.com/help/project-design/grid-connected-system-definition/power-factor/index.html?h=power+facto#apparent-reactive-and-active-power-definition The table at the end of the page give you the different definitions: Upon defining a power factor through the menu "Energy Management / Power Factor", the two additional variables EReGrid and EApGrid become available in the detailed results and also appear in the loss diagram.
  24. Hello Toni, The zone editing tool only supports fixed tables and trackers. If you need trackers, please tick the “Create tracking fields” option. For dome structures, there is no direct way to use the Fill Zone tool. However, you can refer to the following forum post, which suggests a possible workaround
  25. This is a known, but benign, issue where the total AC power is not always well recomputed when you have inverters with MPPTs connected to varying DC power. This is due to the total AC power being the sum of each MPPT equivalent AC power, itself based on the power sharing options. This approach is necessary to be able to deal with fraction of inverters, but may lead to small discrepancies in total. We will solve that in a future PVsyst version.
  26. Hi, I am trying to run a stand alone project, but when I choose a bifacial module, the bifacial feature does not seem to show... Isn't it possible to simulate bifacial modules in stand alone projects? If it is not possible, is there a workaround to this? Beste regards, Rafael
  27. Reviving old thread, but I don't think this would be a very accurate way of modeling this issue. As I'm getting higher production total with less total DC nameplate(assuming due to the virtue of multi mppts helping with mismatch between shaded/unshaded sections) In reality the string/s of different wattage module would negatively impact a combiner due to the mismatch of overall Vmp. Unless there is something I'm not thinking about.
  28. Hallo, can you give more explaination about handrail tilt. I cant get it
